  3. Can not compile on Arduino Nano ESP 32
15 Posts 2 Posters 3.2k Views 2 Watching
  • C
    C
    ctodor
    I'm trying to compile one of the example on Arduino Nano ESP32. (MySensors version 2.3.2)
    Am I doing something wrong?
    ***Compiling debug version of 'SoilMoistSensor' for 'Arduino Nano ESP32 (nano_nora)'
    esp32-hal-uart.c: In function uartSetPins
    esp32-hal-uart.c: 153:9: warning: 'return' with no value, in function returning non-void
    return
    esp32-hal-uart.c:149: note declared here
    bool uartSetPins(uint8_t uart_num, int8_t rxPin, int8_t txPin, int8_t ctsPin, int8_t rtsPin)
    mysensors.h:61: In file included from
    SoilMoistSensor.ino:73: from
    MyHwESP32.cpp: In function bool hwInit()
    MyHwESP32.cpp: 30:48: error: no matching function for call to 'USBCDC::begin(long unsigned int, SerialConfig)
    MY_SERIALDEVICE.begin(MY_BAUD_RATE, SERIAL_8N1)
    USB.h:21: In file included from
    HardwareSerial.h:201: from
    arduino.h:184: from
    SoilMoistSensor.ino: from
    USBCDC.h:70: note candidate void USBCDC begin(long unsigned int)
    void begin(unsigned long baud=0)
    USBCDC.h:70: note candidate expects 1 argument, 2 provided
    SoilMoistSensor.ino: In function void loop()
    SoilMoistSensor.ino: 143:17: error: call of overloaded 'sleep(uint32_t&)' is ambiguous
    sleep(SLEEP_TIME)
    unistd.h:23: In file included from
    unistd.h:4: from
    pthread.h:25: from
    pthread.h:21: from
    gthr-default.h:48: from
    gthr.h:151: from
    atomicity.h:35: from
    basic_string.h:39: from
    string:52: from
    stdexcept:39: from
    array:39: from
    tuple:39: from
    functional:54: from
    Error compiling project sources
    HardwareSerial.h:49: from
    arduino.h:184: from
    Debug build failed for project 'SoilMoistSensor'
    SoilMoistSensor.ino: from***
    • E
      E
      eiten
      @ctodor said in Can not compile on Arduino Nano ESP 32:
      USBCDC
      Can you please attach your sketch?
      C 1 Reply Last reply
      • E eiten
        USBCDC
        C
        C
        ctodor
        @eiten
        It is the SoilMoistSensor.ino skecth from MySensor example.
        *// Enable debug prints to serial monitor
        //#define MY_GATEWAY_ESP32
        //#define MY_RADIO_RF24
        //#define MY_RADIO_NRF5_ESB
        #define MY_RADIO_RFM69
        //#define MY_RADIO_RFM95
        #include <math.h> // Conversion equation from resistance to %
        // Setting up format for reading 3 soil sensors
        #define NUM_READS (int)10 // Number of sensor reads for filtering
        #define CHILD_ID 0
        MyMessage msg(CHILD_ID, V_LEVEL);
        uint32_t SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
        long buffer[NUM_READS];
        int idx;
        /// @brief Structure to be used in percentage and resistance values matrix to be filtered (have to be in pairs)
        typedef struct {
        int moisture; //!< Moisture
        long resistance; //!< Resistance
        } values;
        const long knownResistor = 4700; // Constant value of known resistor in Ohms
        int supplyVoltage; // Measured supply voltage
        int sensorVoltage; // Measured sensor voltage
        values valueOf[NUM_READS]; // Calculated moisture percentages and resistances to be sorted and filtered
        int i; // Simple index variable
        // initialize the digital pins as an output.
        // Pin 6,7 is for sensor 1
        // initialize the digital pin as an output.
        // Pin 6 is sense resistor voltage supply 1
        pinMode(6, OUTPUT);
        // Pin 7 is sense resistor voltage supply 2
        pinMode(7, OUTPUT);
        sendSketchInfo("Soil Moisture Sensor Reverse Polarity", "1.0");
        present(CHILD_ID, S_MOISTURE);
        measure(6,7,1);
        Serial.print ("\t");
        Serial.println (average());
        long read1 = average();
        measure(7,6,0);
        long read2= average();
        long sensor1 = (read1 + read2)/2;
        Serial.print ("resistance bias =" );
        Serial.println (read1-read2);
        Serial.print ("sensor bias compensated value = ");
        Serial.println (sensor1);
        Serial.println ();
        //send back the values
        send(msg.set((int32_t)ceil(sensor1)));
        // delay until next measurement (msec)
        sleep(SLEEP_TIME);
        void measure (int phase_b, int phase_a, int analog_input)
        // read sensor, filter, and calculate resistance value
        // Noise filter: median filter
        for (i=0; i<NUM_READS; i++) {
        	// Read 1 pair of voltage values
        	digitalWrite(phase_a, HIGH);                 // set the voltage supply on
        	delayMicroseconds(25);
        	supplyVoltage = analogRead(analog_input);   // read the supply voltage
        	digitalWrite(phase_a, LOW);                  // set the voltage supply off
        	delay(1);
        	digitalWrite(phase_b, HIGH);                 // set the voltage supply on
        	sensorVoltage = analogRead(analog_input);   // read the sensor voltage
        	digitalWrite(phase_b, LOW);                  // set the voltage supply off
        	// Calculate resistance
        	// the 0.5 add-term is used to round to the nearest integer
        	// Tip: no need to transform 0-1023 voltage value to 0-5 range, due to following fraction
        	long resistance = (knownResistor * (supplyVoltage - sensorVoltage ) / sensorVoltage) ;
        	delay(1);
        	addReading(resistance);
        	Serial.print (resistance);
        // Averaging algorithm
        void addReading(long resistance)
        buffer[idx] = resistance;
        idx++;
        if (idx >= NUM_READS) {
        idx = 0;
        long average()
        long sum = 0;
        for (int cnt = 0; cnt < NUM_READS; cnt++) {
        sum += buffer[cnt];
        return (long)(sum / NUM_READS);
        • E
          E
          eiten
          wrote on last edited by eiten
          Your board seems to use USBCDC to communicate with the PC. So in the file /hal/architecture/ESP32/MyHwESP32.cpp, line 30, you have to change MY_SERIALDEVICE.begin(MY_BAUD_RATE, SERIAL_8N1); to MY_SERIALDEVICE.begin(MY_BAUD_RATE);.
          Furthermore, as ESP32 implements the function sleep(uint32_t) iself, you need to change line 147 in the sketch from sleep(SLEEP_TIME); to sleep(SLEEP_TIME, false);.
          Hope this helps!
          Regards, Ei
          • E
            E
            eiten
            As an additional info, sleep will not work on the ESP in version 2.3.2. Try the developement branch from the github if you need sleep, there I implemented this.
            • E eiten
              C
              C
              ctodor
              @eiten Thx for the info.
              "Try the developement branch from the github": can you give me the url?
              • E
                E
                eiten
                @ctodor of course:
                https://github.com/mysensors/MySensors/tree/development does contain sleep code for ESP. You can download the library here as a zip file.
                • E eiten
                  @ctodor of course:
                  C
                  C
                  ctodor
                  @eiten :+1:
                  E 1 Reply Last reply
                  • C ctodor
                    @eiten :+1:
                    E
                    E
                    eiten
                    @ctodor did you succeed?
                    • E eiten
                      C
                      C
                      ctodor
                      @eiten
                      Sorry for the late response, but I didn't had time to work on it until today.
                      Yes, I was able to compile but not to upload. After "uploading", the Arduino NANO ESP 32 disconects from the PC.
                      I must reset the board in order to be able to upload another sketch.
                      • E
                        E
                        eiten
                        OK, so I suppose the build flags are incorrect. Do you use PlatformIO? Then, you could try:
                        build_flags =
                        	-D ARDUINO_USB_MODE=1
                        	-D ARDUINO_USB_CDC_ON_BOOT=1
                        If you are on the Arduino IDE, you have to set Tools -> USB-Mode -> CDC-Mode. Ore something similar, I don't have the Arduino IDE installed ATM. IIRC, monitor speed must be set to 460800.
                        • E eiten
                          build_flags =
                          C
                          C
                          ctodor
                          wrote on last edited by ctodor
                          @eiten Yep, I was able to upload the sketch after I've set Tools -> USB-Mode -> CDC-Mode.
                          Thank you for your help.
                          Well, I think I rushed with the conclusion.
                          Somehow, the bord is now in infinite boot loop:
                          0;255;0;0;18;2.3.2
                          ESP-ROM:esp32s3-20210327
                          Build:Mar 27 2021
                          rst:0x8 (TG1WDT_SYS_RST),boot:0x2b (SPI_FAST_FLASH_BOOT)
                          Saved PC:0x4200d223
                          SPIWP:0xee
                          mode:DIO, clock div:1
                          load:0x3fce3808,len:0x44c
                          load:0x403c9700,len:0xbe4
                          load:0x403cc700,len:0x2a68
                          entry 0x403c98d4
                          repetes over and over
                          • E
                            E
                            eiten
                            That's strange. Is it exactly the code from above? It seems, it is in gateway mode, but in your sketch, you commented out the gateway option...
                            • E eiten
                              C
                              C
                              ctodor
                              @eiten You are right. It is not the same sketch. The previuos sketch seems to work fine (I used it just to make sure I am able to compile and upload).
                              Now I'm trying to upload a sketch where the ardunio runs as gateway and this is what a need , a gateway that receives messages from a few magnetic door sensors.
                              But please, don't waste your time with me. I think I'm going to write my simple protocol to do such a simple task.
                              Thank you very much for your effort.
                              • E
                                E
                                eiten
                                @ctodor You are very welcome
