  3. single-click, double-click, long-press button possible with MySensors?
5 Posts 4 Posters 1.5k Views 4 Watching
  • dirkcD Offline
    dirkcD Offline
    dirkc
    Hi all,
    has anyone yet implemented some kind of multi tap button with MySensors?
    Such as single-click, double-click, long-press, ... ?
    I think, I cannot work with interrupts, as I can get a HIGH/LOW once only and cannot count for long-press? Correct? And a battery mode node cannot be used either (with smartSleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_2),...) because I have to check for e.g. a long-press which might last some seconds ...
    Thanks in advance for any comment or code example?
    Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
    • E Offline
      E Offline
      eiten
      hey @dirkc, maybe you can trigger your interrupt to rising and falling edge and use millis() to see how long the press was?
      • ZenBlizzardZ Offline
        ZenBlizzard
        Yes, it's definitely possible to detect single click, double click, and long press with MySensors. You can use interrupts on both rising and falling edges and track the time with millis() to determine how long the button is held.
        For example:
        Short press = single click
        Two quick presses = double click
        Hold longer than a threshold = long press
        Just make sure to debounce the button to avoid false triggers. If your node is battery-powered and using smartSleep(), handling long presses can be trickier—might be better to stay awake during the press in that case.
        • J Offline
          J Offline
          JeeLet
          https://forum.arduino.cc/t/partage-boutons-poussoirs/361656
          https://forum.arduino.cc/t/tutoriel-la-bibliotheque-onebutton/1136825
          • dirkcD Offline
            dirkcD Offline
            dirkc
            @ZenBlizzard , yes thanks, thats the point. How to deal with smartSleep() and battery lifetime.
