  3. Dimmer sensor
Dimmer sensor
24 Posts 9 Posters 17.8k Views 3 Watching
  • C4VetteC C4Vette
    @blacey
    You're sketch looks really nice and I would like to use it but I started already with the 1.4 libraries. Any chance you will rewrite it for 1.4? I've had a look at it but it's to complicated for me to understand.
    wrote on last edited by hek
    @C4Vette
    I did a quick 1.4 conversion just now.
    Note that I haven't verified it with any real hardware or anything.
    I will include it in the examples folder for 1.4 when someone has verified it.
    https://codebender.cc/example/MySensor/DimmableLEDActuator
    C4VetteC boblasureB 2 Replies Last reply
      @C4Vette
      C4VetteC
      C4VetteC
      C4Vette
      wrote on last edited by C4Vette
      @hek
      That is great! Thank you very much, it worked first time. I have a LED-strip with a 50N06 FET connected to 12v and a 10K pull-down on the gate. Flawless!
      Well, maybe one tiny little thing: when the dimmer is at 100% and I press the minus it always goes to 80% instead of 90%.
      But this is not something in the sketch but in the library.
      About the part:
      // hek comment: Is this really nessesary?
      gw.send( dimmerMsg.set(currentLevel) );
      I left that out and there is no difference at all
      Edit: I tried about every markdown possibility there is to create a code-block but it doesn't work. Sorry.
        @C4Vette
        boblasureB
        boblasureB
        boblasure
        wrote on last edited by boblasure
        @hek * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
        How do you add more outputs to this? I would like to add PWM 5 and 6 to this. I am using the EasyIot controller. @blacey
        blaceyB 1 Reply Last reply
          That was actually a @blacey comment.
          • boblasureB boblasure
            blaceyB
            blaceyB
            blacey
            @boblasure So you effectively want 3 children, one for each PWM? You will need to extend the sketch to handle two additional pins/children. @korttoma has already done the work...
            Here is his sketch that handles four channels.
            https://codebender.cc/sketch:44740
            boblasureB 1 Reply Last reply
            • blaceyB blacey
              boblasureB
              boblasureB
              boblasure
              @blacey Awesome, thanks for that! And thanks to @korttoma
              • jeylitesJ
                jeylitesJ
                jeylites
                  mainali
                  Can this dimmer sketch be used to control the speed of a fan ? If yes then what are the changes I need to do to this sketch. As part of a project I am working on, I intend to control a AC 230V fan using arduino. I was planning to create a sketch which explicitly controls a AC FAN.
                  By doing this am I reinventing the wheel or someone has done this already which I can use.
                  jeylitesJ 1 Reply Last reply
                  • M mainali
                    jeylitesJ
                    jeylitesJ
                    jeylites
                    @mainali http://forum.mysensors.org/topic/647/mysensored-230v-motion-sensor-with-light-level/6
                      mainali
                      I have the dimmer circuit with me already. I am looking for the sketch to integrate this with the sensor and send message to the gateway using MQTT for controlling the speed of the fan.
                      Note: I am using a custom controller build using Ruby on Rails(WIP). and ruby-mqtt to send message to the MQTT gateway which is running mysensor code.
                      • M mainali
                        jeylitesJ
                        jeylitesJ
                        jeylites
                        @mainali I don't think I have what you're looking for :( ...
                        • korttomaK
                          korttomaK
                          korttoma
                          Would this be of any help? ->
                          https://codebender.cc/sketch:44734
                            mainali
                            I have kind of implemented the fan control with a new message type V_FAN, but anyways I will check this out and revert after testing
                              mainali
                              Can the dimmer led actuator example be used to dim a AC 60w incandescent bulb connected 220v connection. If yes what are the modification needed.
                              when it comes to controlling the speed of a FAN or dimming a normal tungsten filament bulb. I have found so many answers but not a single one which explains all.
                              ferpandoF 1 Reply Last reply
                              • korttomaK
                                korttomaK
                                korttoma
                                All the dimmer examples does is to change the level on an PWM output according to a 0-100% dimmer slider in the controller. What you connect to the PWM output is up to you. In the example sensor device I posted I have connected a transistor that controls the speed of a 12VDC fan.
                                I have also maid another sensor that shows as a dimmer in the controller but in the arduino it controls 3 relays instead ( there are not so many rules you have to follow here you can create what you need, that's the beauty of MySensors ).
                                • M mainali
                                  ferpandoF
                                  ferpandoF
                                  ferpando
                                  @mainali
                                  Dimming AC current is far more complex than dimming DC from the hardware perpective.
                                  Do a search on the internet about it and come back with a solution that fits your needs.
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    #23
                                    • jeylitesJ
                                      jeylitesJ
                                      jeylites
                                      wrote on last edited by jeylites
                                      #24
                                      @mainali
                                      This circuit might help with what you are doing. See attached. Try building this circuit and connect "signal & ground" to dimmer LED actuator PWM. Again I can't stress enough be careful with AC power!!!
