  2. Announcements
  3. šŸ’¬ What's all the fuss about?
34 Posts 18 Posters 20.2k Views 20 Watching
  • bjacobseB
    bjacobseB
    bjacobse
    @matias_sams said in šŸ’¬ What's all the fuss about?:
    state? "true": "false"
    It's known in C language as conditional operator
    https://en.wikipedia.org/wiki/%3F:#C
    • mfalkviddM
      #25
      To add to the previous answer, in the relay example sketch, ? is used to handle that some relays are active low, some are active high.
      From the sketch:
      • Matias_SAMSM
        Matias_SAMSM
        Matias_SAMS
        Thank you very much community, you are great!
        • T
          TalhaYounis
          Hi, I'm working on project of mobile app to measure the CO2, LPG gas , Smog through MQ135 and MQ7 sensors. Kindly help me what should I do??
          Give me suggestions....Thank you
          • T TalhaYounis
            Welcome to the MySensors forum @talhayounis
            Th best way to get started with MySensors is to first read the getting started guide. Then you can move on to https://www.mysensors.org/build/gas which has an example sketch to use with MQ135 and MQ7.
            The best way is usually to get a gateway and a simple node running, and then expand from that.
            • V
              V
              viti
              • V
                V
                viti
                • V viti
                  [[topic:post-is-deleted]]
                  @viti please stop crossposting your questions!
                  • Z
                    Z
                    ZhangCan
                    Smaller sensors require lighter lenses (for equivalent angle of view, zoom range, build quality and aperture range).
                    • I
                      I
                      IceTalon
                      Banned
                      Hi everyone, I’m new here and happy to join the forum. Looking forward to learning and sharing with you all.
                      • skywatchS
                        skywatchS
                        skywatch
                        Welcome - I hope you find it inspiring, educational and practical. There is lots to learn and more to achieve.
                        With your input, this post could be even better šŸ’—
