  3. Time to move to ESPHome?
7 Posts 5 Posters 1.9k Views 5 Watching
  • C
    C
    chrishiscox
    So I have been a user of MySensors for as long as I can rememeber, probably 12 - 15 years. I am so gratteful to the peoplie that developed and nutured a complex system in a simple way.
    I have hit a juncture - my gateway has failed.
    Due to system location I need the wifi ethernet gateway,and have used a Lolin NodeMCU V3 for years. Now I need to reflash and I cannot get it to flash and operate with any software or IDE mix.
    Is there a table of known variants of working Arduino IDE and boards and MySensors library that work together?
    Alternatives to MySensors such as ESPhome will work for me, but losing the nRF2401 is going to be difficult, its robust and has worked almost flawlessly, I aslo dont wish rebuild 8 different projects around the house.
    I can move to a ESP32, but the code so far fails to compile. I can use a D1 mini, lots of choice but almost no compatibility.
    Any one got ideas?
    • OldSurferDudeO
      OldSurferDudeO
      OldSurferDude
      I have a solution for you. I call it the Wireless Serial Cable
      It is a ESP device (eg. ESP-12F) flashed with the SBBridge version of Tasmota. Connected to it serially is an Arduino nano that is programmed as a serial bridge. The MySensors Home Assistant integration handles the other end.
      All for about US$10.
      Let me know if this works for you. I hope it does.
      • OldSurferDudeO
        OldSurferDudeO
        OldSurferDude
        I just couldn't get into ESPHome. It seems like a good idea. IMHO, though, MySensors and/or Tasmota pretty much covers everything I do.
        • TheoLT
          TheoLT
          TheoL
          Not sure why but when I checked it it had limitations. And I don't want my sensors and such running over a Wifi network.
          • F
            F
            fsgraz
            I needed to add my Victron devices to mycontroller v1, so I've created a Esphome device that includes the Victrons and 2 Mopeka Tank Pro devices, all via BLE Advertisement
            Playing around with the topics, I have been able to declare a node name/id for each of these BLE devices.
            each BLE device has a node name/id, childs name/id.
            sensor example:
            sensor:
            Victron IP22
            • platform: victron_ble
              victron_ble_id: victron_ip22
              type: BATTERY_VOLTAGE
              state_topic: "${mys_prefix}/${mys_gateway}/${node_victron_ip22}/${child_victron_voltage}/${C_SET}/${mys_ack}/${V_VOLTAGE}"
            on mycontroller I've created a mysensors mqtt virtual gateway, and voila'.
            from now on I can use Esphome to create other nodes, also in separate devices. I just need to keep track of the used node ids, that must be static.
            Node and sensors presentation is handled as well
            • B
              B
              buxtronix
              I stick with MySensors for anything I cannot get power to (many nodes in hidden places around the house) or for simple low power sensing. I do have lots of ESPHome, but it basically requires running power or frequent battery changes so I only use it where I have power nearby.
              Some of my nodes have been running for around 5 years on the same set of AAs, I don't think there's anything else that can achieve that longevity.
              I do find it a shame that the main docs site here is very outdated and doesn't list any of the newer transports (PJON, CC1101, SX...) which gives the impression that the project is abandoned.
              • OldSurferDudeO
                OldSurferDudeO
                OldSurferDude
                I have learned the hard way, many times, "If it's not broken, don't fix it". MySensors fills a niche, very low power, very low cost, sensors (albeit, DIY). The range is about the same as Bluetooth. The data is usually a boolean or an integer.
                So let us not say, abanddoned but at a development plateau. A mature technology that still has legs.
