  3. MQTT ethernet gateway Works great for 3+ hours then stops
24 Posts 6 Posters 15.6k Views
  • MagiskeM
    MagiskeM
    Magiske
    Have had this problem. And I am pretty sure it's a power issue. Running 5v lines on a 3.3v. Works flawless when I pipe the ethernet lines through a 74LVC245 or when I replaced my "base station" with a Uno+Shield.
    So try a level shifter or try running it with a 3.3v(3.7v) power supply to test ?(Remember to set the Arduino to 8Mhz so it's not overclocked)
    /Mads
    GuyPG 1 Reply Last reply
    • MagiskeM Magiske
      /Mads
      GuyPG
      GuyPG
      GuyP
      /Mads
      Interesting... I am running the whole circuit at 3.3Volts from a regulator (LE33CZ-TR) and I have a capacitor across the power lines as well. But it's clocked at 16Mhz..
      I don't have an 8Mhz crystal at hand to test with. I guess I could try the internal clock.
      • MagiskeM
        MagiskeM
        Magiske
        Just rechecking the specs, and the ENC28J60 should be 5v tolerant ? I ran my at 8mhz using the internal clock.
        So if it was the levelshift or 8mhz that "fixed" mine is a good question.
        Have to add that the Uno+Shield I am using now for the gateway is a W5100 simply because I ordered the W5100 shield when I started having the issues.
        (And this have also been running flawless from day one!)
        • GuyPG
          GuyPG
          GuyP
          I setup a continuous ping every 60 seconds to the MQTT gateway and when it stops working the pings stop as well. I also see that the "Green and Yellow" LEDS on the ENC28J60 are no longer lit.
          • MagiskeM
            MagiskeM
            Magiske
            Sounds like the same issue I had.. Some time it would run for a day other times it would stop responding after an hour or so.
            After reboot it was back right away. So it looks like the ENC28J60 chip is crashing.
            For me fideling with it and droppinglines to 3.3v running at 8mhz worked(And working was having it up and running for at least 3-4 days compared to "normal"). But I remember seeing others having ENC28J60 issues to ?? Maybe you should check to see if you are running latest ENC28J60 Lib ??
            • GuyPG
              GuyPG
              GuyP
              I've been doing a great deal of research on this and I think I might have found the issue.
              It seems that the radio is very sensitive to power changes... In my original circuit I had the Arduino and the radio running from the 3.3v line. Since I moved it to the 5Volts line the Gateway has stayed up for over a day now.
              So to sum up. Everything is now powered by 5Volts except the radio which is 3.3v from the LE33CZ-TR regulator. I have it powered direct from a USB power adapter as well rather than the Uno I did have.
              Once I have etched and tested I will post the circuit and PCB layout.
              • GuyPG
                GuyPG
                GuyP
                So to follow up.. yes indeed it seems that the power was my issue.
                the connector just above the Radio is the 5Volts and ground. The Single connection on the other side is serial TX so I can see the serial diagnostics.
                • A
                  AlinClaudiu
                  @Magiske said:
                  ENC28J60
                  you connected ENC28J60 to 5v?
                  http://www.alban.ro/category/arduino
                  • A AlinClaudiu
                    @Magiske said:
                    ENC28J60
                    GuyPG
                    GuyPG
                    GuyP
                    @AlinClaudiu said:
                    @Magiske said:
                    ENC28J60
                    Yes, the ENC28J60 and the Arduino are running on 5V. The only thing connected to the 3.3Volt regulator is the Radio, NRF24L01+
                    • GuyPG
                      GuyPG
                      GuyP
                      And now in it's 3D Printed case..
                      • GuyPG
                        GuyPG
                        GuyP
                        I was still seeing it stop working. However after further diagnostics it seems the issue lies with the ethernet side of things, the Arduino and Radio still continue to function.
                        I tried to use the Arduino to reboot it's self, which didn't work, but also would not have rebooted the ethernet modules and thus would not have solved this.
                        I've ended up building a 555 timer circuit which is triggered from the Arduino (Digital pin 3), the time fires and triggers a relay to remove power from everything for 2 seconds. Thus we end up with a complete reboot.
                        Here's my circuit diagram, take 5Volts directly and then PWR is fed into my previous circuit that way when the relay clicks over all power to the Arduino and ethernet is removed.
                        • pit007P
                          pit007P
                          pit007
                          wrote on last edited by pit007
                          #21
                          Have you try to init the ENC all ~2 hours or by detecting the connection lost ? (brute force style, but better as powerdown all with a relais)
                          • GuyPG
                            GuyPG
                            GuyP
                            Well it's very simple to detect if the network has gone away.
                            In the processEthernetMessage() function, it checks
                            if (client) {
                            if there's a client connection then the network must be working. If not then either the network has stopped or nothing is connected. Well OpenHAB always maintains a connection.
                            So I've just added the
                            part to say the connection has gone. I also setup a timeout by counting the micros() since boot. so it's not constantly firing the reboot.
                            I then raise digital pin 3 which is linked to my 555 timer circuit, which causes the power cycle.
                            unsigned long resetCounter = micros();
                            int rebootAborted = 0;
                            void processEthernetMessages() {
                            	char inputString[MQTT_MAX_PACKET_SIZE] = "";
                            	uint8_t inputSize = 0;
                            	EthernetClient client = server.available();
                            	if (client) {
                                            resetCounter=micros();
                                            if (rebootAborted) {
                                              Serial.println("Rebooting Aborted");
                                              rebootAborted = 0;
                            		while (client.available()) {
                            			char inChar = client.read();
                            			inputString[inputSize] = inChar;
                            			inputSize++;
                            #ifdef TCPDUMP
                            		Serial.print("<<");
                            		char buf[4];
                            		for (uint8_t a=0; a<inputSize; a++) { sprintf(buf,"%02X ", (uint8_t)inputString[a]); Serial.print(buf); } Serial.println("");
                            		gw.processMQTTMessage(inputString, inputSize);
                                      if ((micros() - resetCounter) >= 100000000 && !client.connected() && !rebootAborted) {
                                          rebootAborted = 1;
                                          Serial.println("Rebooting");
                                          pinMode(3,OUTPUT);
                                          digitalWrite(3,HIGH);
                                          delay(100);
                                          digitalWrite(3,LOW);
                            • pit007P
                              pit007P
                              pit007
                              #23
                              Yes - noooo :-) Right - you are able to detect the connection loss (good to know) but why do you not trigger the NE555, but to re-init the ENC28. Have you try if it response via SPI ?
                              • GuyPG
                                GuyPG
                                GuyP
                                It completely locks up.. I tried to talk with at the same point but it doesn't seem to listen to anything
