  3. MySensors power consumption
battery powered
23 Posts 9 Posters 20.0k Views 1 Watching
  • Z
    Z
    Zeph
    The nano has some drain for the USB interface chip and PS. That may be where the extra current goes in sleep mode. You may need to disable that, or switch to a different Arduino.
    The clock speed when powered up may not be very important if you sleep most of the time and only power up briefly. It depends on the ratios (on time: sleep time and on power:sleep power).
    (For some applications, it's better to use full speed when powered up in order to get things done faster to power down sooner; but if your active cycle mostly waits on a slow sensor or on the radio anyway, a slow MCU clock may allow completing the powerup cycle about as soon as a fast clock, in which case the slower clock would at worst not hurt and may help some. You'd have to be sure when using a new library that it fully adapts to the slower clock speed)
    • EasyIoTE EasyIoT
      @daulagari I'm using http://www.ebay.com/itm/231083181020 and MOSFET transistor as switch connected to DO pin. But this is not ideal solution for temp/hum measurement. It's better to use low voltage sensor for example HTU21T which can be connected directly to 2 AA batteries. It's just proof of concept for other sensors which require minimum 3,3V.
      @jonnyfishman my sleep consumption is about 6uA (not mA).
      Z
      Z
      Zeph
      How are you connecting the MOSFET to the boost regulator?
      • Z
        Z
        Zeph
        Do you know a good source for HTU-21T?
        I find some sources for HTU-21D (http://www.findchips.com/search/htu21) the ones that are not out of stock and sell small quantities tend to be pricey and/or have a large shipping charge.
        EasyIoTE 1 Reply Last reply
        • Z Zeph
          EasyIoTE
          EasyIoTE
          EasyIoT
          @Zeph lowering frequency can increase power consumption because of slower execution, but it also mean that you can use lower voltage (direct battery connection and no step up regulator).
          I'm using P channel MOSFET SI2333DDS-T1-GE3. It has low internal resistance G is conencted to Arduino DO, S to 3.3 V and D to switch regulator.
          I got my HTI21T on ebay.
          EasyIoT framework http://iot-playground.com
          • D
            dzairo
            Hi.
            I read last post .. and don't understand something ..
            If use ATmega328P version with internal 8Mhz or 1Mhz(if divide) then you can connect directly 2xAA or 2x AAA cell .. its total 3V ..
            and THI21T is sensor that working from 1.5V to 3.6V .. then you don't need step up converter..
            I make my self sensor with ATmega328P , run on 8Mhz internal RC oscillator , to TIMER2 I connect 32kHz crystal .
            I measure VBAT by divider 1M and 390K with 1.1 internal reference and temperature with NTC 10k sensor as divider 10k and NTC sensor ..
            I use free MCU pin to controll temperature divider for lower power consumption.. my consumption is 10uA with TIMER2 working and WDG enable .
            regards
            • D dzairo
              Hi.
              regards
              EasyIoTE
              EasyIoTE
              EasyIoT
              @dzairo You need step up regulator if you use DHT22. If you use HTU21T you do not need step up regulator if you use 2 AA batteries. In second case will batteries last much longer than in first case.
              D 1 Reply Last reply
              • EasyIoTE EasyIoT
                dzairo
                sorry... my mistake .. DHT22 is different like HTU22T .. sorry..
                • pit007P
                  pit007P
                  pit007
                  wrote on last edited by pit007
                  #21
                  @daulagari and @dzairo
                  You wrote about consumptions of 6uA and 10uA. I know that i can reach down to 1uA (or 10uA) with 3V, intRC, timer2 and ext 32kHz. Not clear for me is the consumption and the mode of the nrf24. Is this current included in your setup and do you disable the radio bei switching off the power of the module ? -Pit
                  • D
                    dzairo
                    hi. this power consumption is when radio is in power down , on mcu working only timer2 as rtc and watch dog .. if don't need watch dog then can disable and you will have less power consumption.. but I don't know if have bigger consumption watch dog or timer2 .. depend what you need ..
                    • pit007P
                      pit007P
                      pit007
                      Of cource it's powered down :-) - but is his done by a sw-command via SPI (and also the pwr-up) or by transistor ? I'm surprised about the quality of the rNF - the power down seems very good?
