  3. Mysensors MQTT gateway
17 Posts 5 Posters 10.7k Views 2 Watching
  • DammeD Damme
    @Yveaux To include textual presentation:
    String PROGMEM s_presentation[] = {"S_DOOR", "S_MOTION", "S_SMOKE", "S_LIGHT", "S_DIMMER", "S_COVER", "S_TEMP", "S_HUM", "S_BARO", "S_WIND",
    "S_RAIN", "S_UV", "S_WEIGHT", "S_POWER", "S_HEATER", "S_DISTANCE", "S_LIGHT_LEVEL", "S_ARDUINO_NODE",
    "S_ARDUINO_REPEATER_NODE", "S_LOCK", "S_IR", "S_WATER", "S_AIR_QUALITY"};
    eats exacly 1592 extra bytes just for the definition (a bit more if we are going to write "S_TEMPERATURE" insted of only "S_TEMP")..
    My thought was almost to just skip those completly and just use [FixedString]/NodeID/SensorID .. In openhab I group stuff in the items-conf and can make groups like I wish, but other programs might work differently.. maybe I should install mosquito and see how they do..
    edit: should be "PROGMEM const char *string_table[] =" or something instead.. but the size shouldn't be much different, we are talking 1.5-2kB extra program size (5-7%)
    @Damme drop the 'S_' prefix saves you 2 bytes per item. I just managed to squeeze it In...
    That's when I figured I still have to do some 'glueing' somewhere on a more capable device (rpi, server,...) which could just as well directly talk to the unmodified ethernet or serial gateway from MySensors... So why go through all the hassle to squeeze it all in a small arduino?
    • DammeD Damme
      Hello
      MQTT Gateway for mysensors.
      https://github.com/Damme/MyMQTT
      Requires mysensors lib 1.4b
      //Daniel
      DammeD
      DammeD
      Damme
      Code Contributor
      Made some major changes, Too tired to write them down. It should be working to be tested out atleast. I have not implemented any auto node id designation yet. I have the code but have a bug to sort out first.
      new address is (openhab): {mqtt="<[my:MyMQTT/042/001/Temperature:state:default]"}
      and openhab supports wildcard ; {mqtt="<[my:MyMQTT/042/#/Humidity:state:default]"}
      for example.
      Definition is in MyMQTT.cpp
      • DammeD Damme
        Z
        Z
        Zeph
        I don't get why it would be that high - at a quick guess those 24 strings should use less than 300 bytes including the pointers and nul terminators. Are they being repeated many times or is there some additional library which gets pulled in when you use them?
        By the way, if you want the strings themselves in progmem (and not just the array of pointers to strings), I think you may need to use different techniques. http://arduino.cc/en/Reference/PROGMEM
        But that's about how much RAM you use; I still don't understand why those two dozen strings would take up 1.5 KBytes of flash.
        DammeD 1 Reply Last reply
        • Z Zeph
          DammeD
          DammeD
          Damme
          Code Contributor
          @Zeph Using progmem already, made one custom function to read out the data and get length at the same time from a string array using index.
          I have been looking a ittle inside the mysensors lib and there are plenty of optimizations to be done.. I might put some time to clean stuff out!
          The exact size differance with and without the strings is ~880bytes, (I put som extra in there) but there are som functions inserted to handle them.
          • DammeD
            DammeD
            Damme
            Code Contributor
            Omfg, I've spent the last week trying to figure out why some messages got sent and others didn't...
            I forgot the frekin "gw.process();" on the receiving end! D'oh!! :| >.< :p
            Well, While dissecting the code I found some bugs I think I've sorted out now..
            So now I'll try to clean code up a bit and then I'll call it beta 0.1
            Anyone tried it?
            • DammeD Damme
              Anyone tried it?
              DammeD
              DammeD
              Damme
              Code Contributor
              And there we have it, beta 0.1
              should work. Please test it! :)
              I'll try to write better documentation as time comes. I'll answer any questions.
              • DammeD Damme
                DammeD
                DammeD
                Damme
                Code Contributor
                @Damme Fail on me, forgot to push the update.. :P Now it's there.
                • bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  Is this for 1.4 beta or 1.3?
                  Just need another ethernet shield and to figure out how to get MQTT to work in Domoticz.
                  • DammeD
                    DammeD
                    Damme
                    Code Contributor
                    Its made for 1.4b
                    • Y
                      Y
                      yuriyts
                      Link
                      broken
