  3. Powering with LiPo a mini pro without regulator
25 Posts 5 Posters 18.1k Views 2 Watching
  • Vladut GrecuV Vladut Grecu
    @m26872 said:
    the power loss from extra cycles would be neglectable
    You are right. But 220uA are neglectable aswell. (For me at least)
    m26872M
    m26872M
    m26872
    Sorry, but the 220uA is drawn continously. Since most of my (and many others) battery applications have long sleep durations, the sleep mode power consumption is the first priority. Second is probably limiting the radio usage (meaning you can do things with just the arduino).
    AnticimexA 1 Reply Last reply
      It lasted 2 minutes because you read the sensor way to often. For an extended battery life you need to put the arduino to sleep for as much as possible and read the sensors value very rarely.
      epierreE
      epierreE
      epierre
      @Vladut-Grecu not really, but keep in mind that some sensors need to reach the needed temperature to be read, so you may need to heat for 10 minutes before reading and thus you will drain your battery. Also, even with a slepp, you may need an on/off on powering the gas sensor for it is continuously powered.
      z-wave - Vera -> Domoticz
        Did you consider not recharging the battery over 3.3v? The nrf's 3.3v is a must. You can't go over 3.378v. (tested by me, before the poor little guy fried)
        V
        V
        Viper_Scull
        wrote on last edited by Viper_Scull
        Sorry, I've been swamped the last couple of days.
        LiPo batteries should not go below 3V if I'm not mistaken, so charging it to 3.3V would make me recharge it more often. The sensor is for my folks because they still have butane gas for hot water, so I'd like it to last as long as possible. If, like you say, the chinese clon can't operate at more than 3.378V, I'll stick to 2 x AA batteries.
        As the main power drain occurs when the sensor reads and the radio sends, I thought of measuring the battery just after that happens, which in this case it'd be like a minute or so. Therefore the extra cycles to read the analog input should be negligible.
        About the step up converter, the store has a couple listed. This one http://goo.gl/1gwmm2 has a usb input and the other one http://www.ebay.com/itm/291352631612?rmvSB=true doesn't. The second one is better to use ion this case, isn't it?
        @epierre said in Powering with LiPo a mini pro without regulator:
        So you say the sensor would be continuously powered even though we do a gw.sleep?? The heater has a power consumption of 900mW.
        • Vladut GrecuV
          Vladut GrecuV
          Vladut Grecu
          Neither. Those will boost it till 5v. You need something like this.
          V 1 Reply Last reply
            V
            V
            Viper_Scull
            But that one wouldn't be enough to feed the 5V that the MQ-2 gas sensor requires, would it?
            • m26872M m26872
              AnticimexA
              AnticimexA
              Anticimex
              My take on low power measurement.
              I have not gotten around to actually build it yet but I hope to do some measurements in my "lab" this spring.
              • Vladut GrecuV
                Vladut GrecuV
                Vladut Grecu
                Oh.. for the gas sensor they are ok. Last one (green) seems a little bit more polished. The presence of the usb port is not important, you can solder it off. The usb is the output. Check the picture again. It's your choice.
                  V
                  V
                  Viper_Scull
                  Yes, you're right, it's the output. I didn't take a close look to the image. The green one seems more polished as you say. I'll try with those.
                  That's a very interesting project. In the thread some of you say that if VBatt = Vcc (no regulator like I'd like to have) then using the divider to measure the charge is non-sense and it's way better to use the internal functionality, Am I wrong?
                  AnticimexA m26872M 2 Replies Last reply
                  • V Viper_Scull
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @Viper_Scull
                    I have not looked into how internal measurement is done. So I don't know what constraints that type of measurement has. But for external measurement using a voltage divider allows the measurement point to be biased with respect to the ADC reference voltage and my proposal limits the standby current draw of the voltage divider.
                    But if no regulator is done internal measuring is provable better, how that now can be achieved. I am guessing by using vcc as reference to the ADC.
                    • m26872M
                      m26872M
                      m26872
                      Here's one link about the "internal method".
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        Right. Thanks. That was something along the line with what I expected. I think it is an adequate option as long as you run the Arduino directly off the battery (without regulation). But with regulation it won't work.
                        • V Viper_Scull
                          m26872M
                          m26872M
                          m26872
                          wrote on last edited by m26872
                          #24
                          @Viper_Scull said:
                          "...way better to use the internal functionality, Am I wrong?"
                          Yes, "way better" given that it is a real low-power application. Saving 1uA and 2 resistors isn't always that important.
                          • m26872M m26872
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @m26872
                            This is mostly a matter of opinion. There are several options available. Personally, I will design so that I have three options to choose from depending on the sensor type (and long term measurement data)
                            12.5k
