  3. OpenHAB
  4. MQTT & openhab
MQTT & openhab
22 Posts 4 Posters 16.9k Views 2 Watching
  • TotcheT Totche
    Ok, so I leave aside the designer .
    I set-up openhab like => MQTT Broker gateway
    mqtt:mysensor.url=tcp://192.168.1.234:1883
    mqtt:mysensor.clientId=MQTT`
    and for the items
    Group all
    Group node1 (all)
    Group node2 (all)
    Group sketch (all)
    Number node1_temperature "Temperature [%.1f °C]" (node1,all) {mqtt="<[mysensor:MyMQTT/20/10/V_TEMP:state:default]"}
    Number node1_humidite "Humidite [%.1f %%Rh]" (node1,all) {mqtt="<[mysensor:MyMQTT/20/11/V_HUM:state:default]"}```
    The Id are set auto in the sketch
    For the sketch, the serial result is :
    repeater started, id 10
    send: 10-10-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
    send: 10-10-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=18,st=ok:Temp, lumin, hygro
    send: 10-10-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 10-10-0-0 s=0,c=0,t=6,pt=0,l=5,st=ok:1.4.1
    send: 10-10-0-0 s=1,c=0,t=16,pt=0,l=5,st=ok:1.4.1
    send: 10-10-0-0 s=2,c=0,t=7,pt=0,l=5,st=ok:1.4.1
    Temperature : 13.80 C
    send: 10-10-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:13.8
    Luminosite : 79 lx
    send: 10-10-0-0 s=1,c=1,t=23,pt=3,l=2,st=ok:79
    Temperature hygro : 14.00C
    send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:93.0
    Hygrometrie : 93.00%
    Temperature : 13.90 C
    send: 10-10-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:13.9
    Luminosite : 85 lx
    send: 10-10-0-0 s=1,c=1,t=23,pt=3,l=2,st=ok:85
    So at this moment, everything seems to be ok
    openhab.jpg But when i try to select the first line (Tempearture, humidite....), i have a blue line
    The ping works
    Microsoft Windows [version 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation. Tous droits réservés.
    C:\Users\Ludo>ping 192.168.1.234
    Envoi d'une requête 'Ping' 192.168.1.234 avec 32 octets de données :
    Réponse de 192.168.1.234 : octets=32 temps=6 ms TTL=128
    Réponse de 192.168.1.234 : octets=32 temps=1 ms TTL=128
    Statistiques Ping pour 192.168.1.234:
    Paquets : envoyés = 4, reçus = 4, perdus = 0 (perte 0%),
    Durée approximative des boucles en millisecondes :
    Minimum = 1ms, Maximum = 6ms, Moyenne = 2ms
    I read somewhere that Id was autodealed (gw.begin(NULL, AUTO, true);) but my Id node is 10.
    Normaly should'nt be from 20 to 254 ?
    1. So what is wrong with the definitions ?
    2. In the items definition, (mysensor:MyMQTT/20/10/) what are 20 and 10 ?
    Thanks for any help
    TotcheT
    TotcheT
    Totche
    wrote on last edited by Totche
    1. The blue line disappeared when i reduced the text length
    2. id 10 and 11 => ClearEeprom : it's ok now
    But always request node Id for both nodes,
    Same question as above => In the items definition, (mysensor:MyMQTT/20/10/) what are 20 and 10 ?
    • XanderX
      XanderX
      Xander
      "20" is the node id of the sender. Your node id is 10. See: "send: 10-10-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1"
      "10" is the child id of this particular sensor. Your node has the child id's:
      • "0" : send: 10-10-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:13.8
      • "1" : send: 10-10-0-0 s=1,c=1,t=23,pt=3,l=2,st=ok:79
      • "2" : send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:93.0
      20-20-0-0
       |  | | Id of Destination node
       |  | ID of next node
       |  Id of last node this message passed
       Id of sender node (origin)
      s = child-sensor-id, 255 für "interne" Messages
      c = message-type
      t = sub-type
      pt = payload-type (see MyMessage.h)
      l = length of payload
      TotcheT 1 Reply Last reply
      • XanderX Xander
        20-20-0-0
         |  | ID of next node
        c = message-type
        t = sub-type
        TotcheT
        TotcheT
        Totche
        @Xander Thanks for the answer.
        For the auto-dealing with Ids, who did it ? Openhab or the gateway ?, or are the Ids fixed with (mysensor:MyMQTT/20/10/) ?
        • XanderX
          XanderX
          Xander
          The node id is from the gateway. The child id is given by you in your sketch.
          • XanderX Xander
            TotcheT
            TotcheT
            Totche
            @Xander Ok,
            I just keep the gateway and the repeater.
            repeater started, id 255
            req node id
            send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
            req node id
            BMP180 Initialisation OK
            req node id
            Pression : 1010.47 hPa
            req node id
            req node id
            0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
            It seems that the gateway don't give an Id to the repeater
            • TotcheT Totche
              @Xander Ok,
              req node id
              req node id
              req node id
              req node id
              req node id
              TotcheT
              TotcheT
              Totche
              So back to serial gateway.
              req node id
              sensor started, id 255
              req node id
              req node id
              req node id
              req node id
              req node id
              255;255;3;0;3;
              255;255;3;0;3;
              255;255;3;0;3;
              255;255;3;0;3;
              255;255;3;0;3;
              255;255;3;0;3;
              Are you sure that the gateway gives the Id ?
              Ethernet, MQTT and serial gateways never send back ids to the nodes in my case.
              When I force the Id, it's working and the gateway "shows" the values
              repeater started, id 20
              send: 20-20-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
              send: 20-20-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
              send: 20-20-0-0 s=255,c=3,t=11,pt=0,l=17,st=fail:Repeter, pression
              send: 20-20-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
              send: 20-20-0-0 s=0,c=0,t=8,pt=0,l=5,st=ok:1.4.1
              Pression : 998.68 hPa
              send: 20-20-0-0 s=0,c=1,t=4,pt=2,l=2,st=ok:998
              send: 20-20-0-0 s=0,c=1,t=5,pt=0,l=7,st=ok:inconnu
              0;0;3;0;9;read: 20-20-0 s=255,c=0,t=18,pt=0,l=5:1.4.1
              20;255;0;0;18;1.4.1
              0;0;3;0;9;read: 20-20-0 s=255,c=3,t=6,pt=1,l=1:0
              20;255;3;0;6;0
              0;0;3;0;9;read: 20-20-0 s=255,c=3,t=12,pt=0,l=3:1.0
              20;255;3;0;12;1.0
              0;0;3;0;9;read: 20-20-0 s=0,c=0,t=8,pt=0,l=5:1.4.1
              20;0;0;0;8;1.4.1
              0;0;3;0;9;read: 20-20-0 s=0,c=1,t=4,pt=2,l=2:998
              20;0;1;0;4;998
              0;0;3;0;9;read: 20-20-0 s=0,c=1,t=5,pt=0,l=7:inconnu
              20;0;1;0;5;inconnu
              • XanderX
                XanderX
                Xander
                I'm not shure what your configuration is. You have:
                • a sensor node
                • a repeater Node
                • a serial / MQTT Gateway node
                  3 nodes - is this OK?
                Or is your sensor node the repeater too. I don't know if this is possible.
                In case of a repeater node I'm not shure but I think the gateway is allways the "master" of all id's.
                • XanderX Xander
                  • a sensor node
                  • a repeater Node
                  TotcheT
                  TotcheT
                  Totche
                  For now, I have a MQTT controller, one repeater node with a BMP180 sensor (to do the forecast on a long time, as by definition the repeater never sleeps, with a modified sketch and a timer of 1 seconde), and an another node with temperature, luminance and hymidity sensors.
                  After some readings , i think that the gateway doesn't provide the Id, it's the role of the controller
                  => in this discussion, you can read that, it's for Vera controller
                  Your going to want a controller in the long term. For testing you can either hard code the node ID in the sketch (you will want to flash the EEPROM clear sketch when you get a controller)
                  The reason your not seeing the temp on the gateway is because it doesn't get sent if there is no node ID.
                  Basically the node is asking the gateway/controller who am I and the controller isn't responding so it just keeps asking.
                  => I use openHAb instead of Vera, and there is XXX.items file where you define the Ids for node and child
                  Number node1_temp  "Temp [%.1f °C]"     (node1,all)  {mqtt="<[mysensor:MyMQTT/20/10/V_TEMP:state:default]"}
                  Number node1_humid "Humid [%.1f %%Rh]" (node1,all)  {mqtt="<[mysensor:MyMQTT/20/11/V_HUM:state:default]"}
                  So I think that in this case, if the Ids are "constants" in openhab, they can't be randomly dealed by the gateway, and have to be fixed in each node
                  I just tested by giving Id to the nodes, and all seems correct
                  MQTT gateway
                  Started!
                  0;0;3;0;9;read: 20-20-0 s=0,c=1,t=4,pt=2,l=2:1012
                  0;0;3;0;9;read: 21-21-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
                  0;0;3;0;9;read: 21-21-0 s=255,c=3,t=6,pt=1,l=1:0
                  0;0;3;0;9;read: 21-21-0 s=255,c=3,t=11,pt=0,l=18:Temp, lumin, hygro
                  0;0;3;0;9;read: 21-21-0 s=255,c=3,t=12,pt=0,l=3:1.0
                  0;0;3;0;9;read: 21-21-0 s=0,c=0,t=6,pt=0,l=5:1.4.1
                  0;0;3;0;9;read: 21-21-0 s=1,c=0,t=16,pt=0,l=5:1.4.1
                  0;0;3;0;9;read: 21-21-0 s=2,c=0,t=7,pt=0,l=5:1.4.1
                  0;0;3;0;9;read: 21-21-0 s=0,c=1,t=0,pt=7,l=5:20.1
                  0;0;3;0;9;read: 21-21-0 s=1,c=1,t=23,pt=3,l=2:20
                  0;0;3;0;9;read: 21-21-0 s=2,c=1,t=1,pt=7,l=5:59.0
                  Repeater node
                  Pression : 1012.27 hPa
                  send: 20-20-0-0 s=0,c=1,t=4,pt=2,l=2,st=ok:1012
                  Sensors node
                  sensor started, id 21
                  send: 21-21-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                  send: 21-21-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                  send: 21-21-0-0 s=255,c=3,t=11,pt=0,l=18,st=ok:Temp, lumin, hygro
                  send: 21-21-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                  send: 21-21-0-0 s=0,c=0,t=6,pt=0,l=5,st=ok:1.4.1
                  send: 21-21-0-0 s=1,c=0,t=16,pt=0,l=5,st=ok:1.4.1
                  send: 21-21-0-0 s=2,c=0,t=7,pt=0,l=5,st=ok:1.4.1
                  Temperature : 20.10 C
                  send: 21-21-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:20.1
                  Luminosite : 20 lx
                  send: 21-21-0-0 s=1,c=1,t=23,pt=3,l=2,st=ok:20
                  Temperature hygro : 19.00C
                  send: 21-21-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:59.0
                  Hygrometrie : 59.00%
                  Luminosite : 20 lx
                  • TotcheT
                    TotcheT
                    Totche
                    Re,
                    I tried to use MYSController without success
                    The IP is 192.168.1.234:1883 for the MQTT controller , but I can't read any values with the browser and MYSController.
                    And as you can see in the serial monitors, the nodes seem to discuss together.
                    I don't know how to check the communication with the MQTT gateway, apparently the problem comes from him
                    Any tips, ?
                    • XanderX
                      XanderX
                      Xander
                      I use a client ( MQTT.fx http://www.jensd.de/wordpress/?cat=50 ) to test the mqtt gateway. Please see my post: http://forum.mysensors.org/topic/953/how-to-know-the-node-ids-assigned-by-the-mqtt-gateway-to-the-sensors/2
                      With this tool I can see if the gateway is working and which id's are used. Then I configure OpenHAB accordingly.
                      • XanderX Xander
                        TotcheT
                        TotcheT
                        Totche
                        @Xander Thanks ;)
                        Very great link, now I can see what is sent.
                        1)-
                        2- The ip in MQTT.fx is the same as in openhab.cfg
                        3- test.items
                        Group all
                        Group meteo //(all)
                        Group noeud_1  (meteo)
                        Group noeud_2  (meteo)
                        //Group sketch (all)
                        Number noeud1_temperature  "Temperature [%.1f °C]"    (noeud_1, all)  {mqtt="<[mysensor:MyMQTT/21/0/V_TEMP:state:default]"}
                        Number noeud1_luminosite   "Luminosite [%.0f Lux]"  (noeud_1, all)  {mqtt="<[mysensor:MyMQTT/21/1/V_LIGHT_LEVEL:state:default]"}
                        Number noeud1_humidite     "Humidite [%.0f Rh]"     (noeud_1, all)  {mqtt="<[mysensor:MyMQTT/21/2/V_HUM:state:default]"}
                        4- openHAB runtime
                        Launching the openHAB runtime...
                        osgi> 2015-04-01 20:28:05.432 [INFO ] [.o.core.internal.CoreActivator] - openHAB
                         runtime has been started (v1.6.2).
                        2015-04-01 20:28:06.066 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service
                        has been started
                        2015-04-01 20:28:06.189 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Disco
                        very initialization completed.
                        2015-04-01 20:28:07.134 [INFO ] [penhab.io.rest.RESTApplication] - Started REST
                        API at /rest
                        2015-04-01 20:28:15.943 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model
                         'test.sitemap'
                        2015-04-01 20:28:16.055 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model
                         'test.items'
                        2015-04-01 20:28:16.653 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Class
                        ic UI at /openhab.app
                        nothing :(
                        PS : i don't see the repeater with the barometer, I need to dissociate them so one nano more :(
                        • GuyPG
                          GuyPG
                          GuyP
                          Did you restart openHAB after you entered the MQTT gateway IP address in the configuration file? You don't need to restart when changing items, or sitemaps.
                          You should check that openHAB has made a connection to the MQTT gateway.
                          netstat -an |grep 1883
                          root@openHAB:~# netstat -an |grep 1883
                          tcp6       0      0 192.168.40.201:42199    192.168.40.200:1883     ESTABLISHED
                          root@openHAB:~#
                          Do you see it listed? If not restart the gateway, it should connect within a few minutes.
                          • GuyPG GuyP
                            root@openHAB:~#
                            TotcheT
                            TotcheT
                            Totche
                            @GuyP Thanks for reply
                            I'm using windows 7, so I can't use your command, and see if connection is made
                            The IP in openHAB is set since the beginning, and I never changed.
                            • XanderX
                              XanderX
                              Xander
                              ... but "netstat -an" should work!
                              • XanderX Xander
                                TotcheT
                                TotcheT
                                Totche
                                @Xander I have that
                                C:\Users\Totche>netstat -an|find "1883"
                                  TCP    0.0.0.0:1883           0.0.0
                                  UDP    10.10.10.170:61883
                                • GuyPG
                                  GuyPG
                                  GuyP
                                  that shows you have a listener, but nothing connected!
                                  Are you running the gateway on this PC? if so the openhab configuration should be localhost or 127.0.0.1:1883.
                                  • GuyPG GuyP
                                    TotcheT
                                    TotcheT
                                    Totche
                                    @GuyP Now I can see that
                                      TCP    192.168.1.13:25638     192.168.1.134:1883     ESTABLISHED
                                      UDP    0.0.0.0:61883          *:*
                                    The last Ip 192.168.1.234 was out of range with the router definitions
                                    But no more values in openHAB, pfff
                                    • TotcheT
                                      TotcheT
                                      Totche
                                      And tonight, the weird is back
                                        TCP    0.0.0.0:1883           0.0.0.0:0              LISTENING
                                      In openHAB.fx, I can see the msgs from the node, so I suppose that the ethernet connection is working
                                      With MYSController, nothing displayed, no node network
                                      With the serial, I can see the exchanges between node and the MQTTgateway
                                      So what's wrong ? The Gateway, a port redirection ????
                                      tekkaT 1 Reply Last reply
                                      • TotcheT Totche
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Totche Just for clarification: MYSController is not compatible with MQTT gateways but with serial gw. .
                                        • tekkaT tekka
                                          TotcheT
                                          TotcheT
                                          Totche
                                          #22
                                          @tekka Ah OK, it's better to know it, thanks; ;)
                                          And I found the error this morning and it works great......
                                          To create the configuration file for openHAB, I made a copy/paste of the Mysensors example., and I haven't seen it was a space character at the beginning of each lines.
                                          I removed it, and it's working fine.now
                                          So be carefull with the spaces, it was a stupid mistake and boring to find.
                                          I have done this test 5 times, so I'm sure that it's the problem.
                                          Thank you everybody....
