  3. OpenHAB
  4. MQTT & openhab
MQTT & openhab
22 Posts 4 Posters 16.9k Views 2 Watching
  • TotcheT
    TotcheT
    Totche
    wrote on last edited by Totche
    I'm stuck with openhab configuration => Embedded browser not available.
    No more handles [Could not detect registered XULRunner to use]
    org.eclipse.swt.SWTError: No more handles [Could not detect registered XULRunner to use]
    	at org.eclipse.swt.SWT.error(SWT.java:4387)
    	at org.eclipse.swt.browser.Mozilla.create(Mozilla.java:695)
    	at org.eclipse.swt.browser.Browser.<init>(Browser.java:99)
    	at org.eclipse.ui.internal.browser.BrowserViewer.<init>(BrowserViewer.java:224)
    	at org.eclipse.ui.internal.browser.WebBrowserView.createPartControl(WebBrowserView.java:48)
    	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:138)
    	at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:155)
    	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:313)
    	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    	at java.lang.reflect.Method.invoke(Unknown Source)
    	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:861)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:841)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:113)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:321)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:242)```
    Which versions have to be installed for java and eclipse ?
    I read the forums but it's obscure....
    EDit : It seems that it's not possible to have the designer working (some answers in other forums)
    TotcheT 1 Reply Last reply
    • TotcheT Totche
      TotcheT
      TotcheT
      Totche
      Ok, so I leave aside the designer .
      I set-up openhab like => MQTT Broker gateway
      mqtt:mysensor.url=tcp://192.168.1.234:1883
      mqtt:mysensor.clientId=MQTT`
      and for the items
      Group all
      Group node1 (all)
      Group node2 (all)
      Group sketch (all)
      Number node1_temperature "Temperature [%.1f °C]" (node1,all) {mqtt="<[mysensor:MyMQTT/20/10/V_TEMP:state:default]"}
      Number node1_humidite "Humidite [%.1f %%Rh]" (node1,all) {mqtt="<[mysensor:MyMQTT/20/11/V_HUM:state:default]"}```
      The Id are set auto in the sketch
      For the sketch, the serial result is :
      repeater started, id 10
      send: 10-10-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
      send: 10-10-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
      send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=18,st=ok:Temp, lumin, hygro
      send: 10-10-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
      send: 10-10-0-0 s=0,c=0,t=6,pt=0,l=5,st=ok:1.4.1
      send: 10-10-0-0 s=1,c=0,t=16,pt=0,l=5,st=ok:1.4.1
      send: 10-10-0-0 s=2,c=0,t=7,pt=0,l=5,st=ok:1.4.1
      Temperature : 13.80 C
      send: 10-10-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:13.8
      Luminosite : 79 lx
      send: 10-10-0-0 s=1,c=1,t=23,pt=3,l=2,st=ok:79
      Temperature hygro : 14.00C
      send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:93.0
      Hygrometrie : 93.00%
      Temperature : 13.90 C
      send: 10-10-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:13.9
      Luminosite : 85 lx
      send: 10-10-0-0 s=1,c=1,t=23,pt=3,l=2,st=ok:85
      So at this moment, everything seems to be ok
      openhab.jpg But when i try to select the first line (Tempearture, humidite....), i have a blue line
      The ping works
      Microsoft Windows [version 6.1.7601]
      Copyright (c) 2009 Microsoft Corporation. Tous droits réservés.
      C:\Users\Ludo>ping 192.168.1.234
      Envoi d'une requête 'Ping' 192.168.1.234 avec 32 octets de données :
      Réponse de 192.168.1.234 : octets=32 temps=6 ms TTL=128
      Réponse de 192.168.1.234 : octets=32 temps=1 ms TTL=128
      Statistiques Ping pour 192.168.1.234:
      Paquets : envoyés = 4, reçus = 4, perdus = 0 (perte 0%),
      Durée approximative des boucles en millisecondes :
      Minimum = 1ms, Maximum = 6ms, Moyenne = 2ms
      I read somewhere that Id was autodealed (gw.begin(NULL, AUTO, true);) but my Id node is 10.
      Normaly should'nt be from 20 to 254 ?
      1. So what is wrong with the definitions ?
      2. In the items definition, (mysensor:MyMQTT/20/10/) what are 20 and 10 ?
      Thanks for any help
      • TotcheT Totche
        and for the items
        Group all
        Group node1 (all)
        Group node2 (all)
        Group sketch (all)
        Luminosite : 79 lx
        Luminosite : 85 lx
        The ping works
        Thanks for any help
        TotcheT
        TotcheT
        Totche
        1. The blue line disappeared when i reduced the text length
        2. id 10 and 11 => ClearEeprom : it's ok now
        But always request node Id for both nodes,
        Same question as above => In the items definition, (mysensor:MyMQTT/20/10/) what are 20 and 10 ?
        • XanderX
          XanderX
          Xander
          "20" is the node id of the sender. Your node id is 10. See: "send: 10-10-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1"
          "10" is the child id of this particular sensor. Your node has the child id's:
          • "0" : send: 10-10-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:13.8
          • "1" : send: 10-10-0-0 s=1,c=1,t=23,pt=3,l=2,st=ok:79
          • "2" : send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:93.0
          20-20-0-0
           |  | | Id of Destination node
           |  | ID of next node
           |  Id of last node this message passed
           Id of sender node (origin)
          s = child-sensor-id, 255 für "interne" Messages
          c = message-type
          t = sub-type
          pt = payload-type (see MyMessage.h)
          l = length of payload
          • XanderX Xander
            20-20-0-0
             |  | ID of next node
            c = message-type
            t = sub-type
            TotcheT
            TotcheT
            Totche
            @Xander Thanks for the answer.
            For the auto-dealing with Ids, who did it ? Openhab or the gateway ?, or are the Ids fixed with (mysensor:MyMQTT/20/10/) ?
            • XanderX
              XanderX
              Xander
              The node id is from the gateway. The child id is given by you in your sketch.
              • XanderX Xander
                TotcheT
                TotcheT
                Totche
                @Xander Ok,
                I just keep the gateway and the repeater.
                repeater started, id 255
                req node id
                send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
                req node id
                BMP180 Initialisation OK
                req node id
                Pression : 1010.47 hPa
                req node id
                req node id
                0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
                It seems that the gateway don't give an Id to the repeater
                • TotcheT Totche
                  @Xander Ok,
                  req node id
                  req node id
                  req node id
                  req node id
                  req node id
                  TotcheT
                  TotcheT
                  Totche
                  So back to serial gateway.
                  req node id
                  sensor started, id 255
                  req node id
                  req node id
                  req node id
                  req node id
                  req node id
                  255;255;3;0;3;
                  255;255;3;0;3;
                  255;255;3;0;3;
                  255;255;3;0;3;
                  255;255;3;0;3;
                  255;255;3;0;3;
                  Are you sure that the gateway gives the Id ?
                  Ethernet, MQTT and serial gateways never send back ids to the nodes in my case.
                  When I force the Id, it's working and the gateway "shows" the values
                  repeater started, id 20
                  send: 20-20-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                  send: 20-20-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                  send: 20-20-0-0 s=255,c=3,t=11,pt=0,l=17,st=fail:Repeter, pression
                  send: 20-20-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                  send: 20-20-0-0 s=0,c=0,t=8,pt=0,l=5,st=ok:1.4.1
                  Pression : 998.68 hPa
                  send: 20-20-0-0 s=0,c=1,t=4,pt=2,l=2,st=ok:998
                  send: 20-20-0-0 s=0,c=1,t=5,pt=0,l=7,st=ok:inconnu
                  0;0;3;0;9;read: 20-20-0 s=255,c=0,t=18,pt=0,l=5:1.4.1
                  20;255;0;0;18;1.4.1
                  0;0;3;0;9;read: 20-20-0 s=255,c=3,t=6,pt=1,l=1:0
                  20;255;3;0;6;0
                  0;0;3;0;9;read: 20-20-0 s=255,c=3,t=12,pt=0,l=3:1.0
                  20;255;3;0;12;1.0
                  0;0;3;0;9;read: 20-20-0 s=0,c=0,t=8,pt=0,l=5:1.4.1
                  20;0;0;0;8;1.4.1
                  0;0;3;0;9;read: 20-20-0 s=0,c=1,t=4,pt=2,l=2:998
                  20;0;1;0;4;998
                  0;0;3;0;9;read: 20-20-0 s=0,c=1,t=5,pt=0,l=7:inconnu
                  20;0;1;0;5;inconnu
                  • XanderX
                    XanderX
                    Xander
                    I'm not shure what your configuration is. You have:
                    • a sensor node
                    • a repeater Node
                    • a serial / MQTT Gateway node
                      3 nodes - is this OK?
                    Or is your sensor node the repeater too. I don't know if this is possible.
                    In case of a repeater node I'm not shure but I think the gateway is allways the "master" of all id's.
                    • XanderX Xander
                      • a sensor node
                      • a repeater Node
                      TotcheT
                      TotcheT
                      Totche
                      For now, I have a MQTT controller, one repeater node with a BMP180 sensor (to do the forecast on a long time, as by definition the repeater never sleeps, with a modified sketch and a timer of 1 seconde), and an another node with temperature, luminance and hymidity sensors.
                      After some readings , i think that the gateway doesn't provide the Id, it's the role of the controller
                      => in this discussion, you can read that, it's for Vera controller
                      Your going to want a controller in the long term. For testing you can either hard code the node ID in the sketch (you will want to flash the EEPROM clear sketch when you get a controller)
                      The reason your not seeing the temp on the gateway is because it doesn't get sent if there is no node ID.
                      Basically the node is asking the gateway/controller who am I and the controller isn't responding so it just keeps asking.
                      => I use openHAb instead of Vera, and there is XXX.items file where you define the Ids for node and child
                      Number node1_temp  "Temp [%.1f °C]"     (node1,all)  {mqtt="<[mysensor:MyMQTT/20/10/V_TEMP:state:default]"}
                      Number node1_humid "Humid [%.1f %%Rh]" (node1,all)  {mqtt="<[mysensor:MyMQTT/20/11/V_HUM:state:default]"}
                      So I think that in this case, if the Ids are "constants" in openhab, they can't be randomly dealed by the gateway, and have to be fixed in each node
                      I just tested by giving Id to the nodes, and all seems correct
                      MQTT gateway
                      Started!
                      0;0;3;0;9;read: 20-20-0 s=0,c=1,t=4,pt=2,l=2:1012
                      0;0;3;0;9;read: 21-21-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
                      0;0;3;0;9;read: 21-21-0 s=255,c=3,t=6,pt=1,l=1:0
                      0;0;3;0;9;read: 21-21-0 s=255,c=3,t=11,pt=0,l=18:Temp, lumin, hygro
                      0;0;3;0;9;read: 21-21-0 s=255,c=3,t=12,pt=0,l=3:1.0
                      0;0;3;0;9;read: 21-21-0 s=0,c=0,t=6,pt=0,l=5:1.4.1
                      0;0;3;0;9;read: 21-21-0 s=1,c=0,t=16,pt=0,l=5:1.4.1
                      0;0;3;0;9;read: 21-21-0 s=2,c=0,t=7,pt=0,l=5:1.4.1
                      0;0;3;0;9;read: 21-21-0 s=0,c=1,t=0,pt=7,l=5:20.1
                      0;0;3;0;9;read: 21-21-0 s=1,c=1,t=23,pt=3,l=2:20
                      0;0;3;0;9;read: 21-21-0 s=2,c=1,t=1,pt=7,l=5:59.0
                      Repeater node
                      Pression : 1012.27 hPa
                      send: 20-20-0-0 s=0,c=1,t=4,pt=2,l=2,st=ok:1012
                      Sensors node
                      sensor started, id 21
                      send: 21-21-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                      send: 21-21-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                      send: 21-21-0-0 s=255,c=3,t=11,pt=0,l=18,st=ok:Temp, lumin, hygro
                      send: 21-21-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                      send: 21-21-0-0 s=0,c=0,t=6,pt=0,l=5,st=ok:1.4.1
                      send: 21-21-0-0 s=1,c=0,t=16,pt=0,l=5,st=ok:1.4.1
                      send: 21-21-0-0 s=2,c=0,t=7,pt=0,l=5,st=ok:1.4.1
                      Temperature : 20.10 C
                      send: 21-21-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:20.1
                      Luminosite : 20 lx
                      send: 21-21-0-0 s=1,c=1,t=23,pt=3,l=2,st=ok:20
                      Temperature hygro : 19.00C
                      send: 21-21-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:59.0
                      Hygrometrie : 59.00%
                      Luminosite : 20 lx
                      • TotcheT
                        TotcheT
                        Totche
                        Re,
                        I tried to use MYSController without success
                        The IP is 192.168.1.234:1883 for the MQTT controller , but I can't read any values with the browser and MYSController.
                        And as you can see in the serial monitors, the nodes seem to discuss together.
                        I don't know how to check the communication with the MQTT gateway, apparently the problem comes from him
                        Any tips, ?
                        • XanderX
                          XanderX
                          Xander
                          I use a client ( MQTT.fx http://www.jensd.de/wordpress/?cat=50 ) to test the mqtt gateway. Please see my post: http://forum.mysensors.org/topic/953/how-to-know-the-node-ids-assigned-by-the-mqtt-gateway-to-the-sensors/2
                          With this tool I can see if the gateway is working and which id's are used. Then I configure OpenHAB accordingly.
                          • XanderX Xander
                            TotcheT
                            TotcheT
                            Totche
                            @Xander Thanks ;)
                            Very great link, now I can see what is sent.
                            1)-
                            2- The ip in MQTT.fx is the same as in openhab.cfg
                            3- test.items
                            Group all
                            Group meteo //(all)
                            Group noeud_1  (meteo)
                            Group noeud_2  (meteo)
                            //Group sketch (all)
                            Number noeud1_temperature  "Temperature [%.1f °C]"    (noeud_1, all)  {mqtt="<[mysensor:MyMQTT/21/0/V_TEMP:state:default]"}
                            Number noeud1_luminosite   "Luminosite [%.0f Lux]"  (noeud_1, all)  {mqtt="<[mysensor:MyMQTT/21/1/V_LIGHT_LEVEL:state:default]"}
                            Number noeud1_humidite     "Humidite [%.0f Rh]"     (noeud_1, all)  {mqtt="<[mysensor:MyMQTT/21/2/V_HUM:state:default]"}
                            4- openHAB runtime
                            Launching the openHAB runtime...
                            osgi> 2015-04-01 20:28:05.432 [INFO ] [.o.core.internal.CoreActivator] - openHAB
                             runtime has been started (v1.6.2).
                            2015-04-01 20:28:06.066 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service
                            has been started
                            2015-04-01 20:28:06.189 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Disco
                            very initialization completed.
                            2015-04-01 20:28:07.134 [INFO ] [penhab.io.rest.RESTApplication] - Started REST
                            API at /rest
                            2015-04-01 20:28:15.943 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model
                             'test.sitemap'
                            2015-04-01 20:28:16.055 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model
                             'test.items'
                            2015-04-01 20:28:16.653 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Class
                            ic UI at /openhab.app
                            nothing :(
                            PS : i don't see the repeater with the barometer, I need to dissociate them so one nano more :(
                            • GuyPG
                              GuyPG
                              GuyP
                              Did you restart openHAB after you entered the MQTT gateway IP address in the configuration file? You don't need to restart when changing items, or sitemaps.
                              You should check that openHAB has made a connection to the MQTT gateway.
                              netstat -an |grep 1883
                              root@openHAB:~# netstat -an |grep 1883
                              tcp6       0      0 192.168.40.201:42199    192.168.40.200:1883     ESTABLISHED
                              root@openHAB:~#
                              Do you see it listed? If not restart the gateway, it should connect within a few minutes.
                              • GuyPG GuyP
                                root@openHAB:~#
                                TotcheT
                                TotcheT
                                Totche
                                @GuyP Thanks for reply
                                I'm using windows 7, so I can't use your command, and see if connection is made
                                The IP in openHAB is set since the beginning, and I never changed.
                                • XanderX
                                  XanderX
                                  Xander
                                  ... but "netstat -an" should work!
                                  • XanderX Xander
                                    TotcheT
                                    TotcheT
                                    Totche
                                    @Xander I have that
                                    C:\Users\Totche>netstat -an|find "1883"
                                      TCP    0.0.0.0:1883           0.0.0
                                      UDP    10.10.10.170:61883
                                    • GuyPG
                                      GuyPG
                                      GuyP
                                      that shows you have a listener, but nothing connected!
                                      Are you running the gateway on this PC? if so the openhab configuration should be localhost or 127.0.0.1:1883.
                                      • GuyPG GuyP
                                        TotcheT
                                        TotcheT
                                        Totche
                                        @GuyP Now I can see that
                                          TCP    192.168.1.13:25638     192.168.1.134:1883     ESTABLISHED
                                          UDP    0.0.0.0:61883          *:*
                                        The last Ip 192.168.1.234 was out of range with the router definitions
                                        But no more values in openHAB, pfff
                                        • TotcheT
                                          TotcheT
                                          Totche
                                          And tonight, the weird is back
                                            TCP    0.0.0.0:1883           0.0.0.0:0              LISTENING
                                          In openHAB.fx, I can see the msgs from the node, so I suppose that the ethernet connection is working
                                          With MYSController, nothing displayed, no node network
                                          With the serial, I can see the exchanges between node and the MQTTgateway
                                          So what's wrong ? The Gateway, a port redirection ????
                                          tekkaT 1 Reply Last reply
