  3. OpenHAB
  4. MQTT & openhab
MQTT & openhab
22 Posts 4 Posters 16.9k Views 2 Watching
  • TotcheT Totche
    @Xander Ok,
    I just keep the gateway and the repeater.
    repeater started, id 255
    req node id
    send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
    req node id
    BMP180 Initialisation OK
    req node id
    Pression : 1010.47 hPa
    req node id
    req node id
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
    It seems that the gateway don't give an Id to the repeater
    TotcheT
    TotcheT
    Totche
    wrote on last edited by Totche
    So back to serial gateway.
    req node id
    sensor started, id 255
    req node id
    req node id
    req node id
    req node id
    req node id
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    Are you sure that the gateway gives the Id ?
    Ethernet, MQTT and serial gateways never send back ids to the nodes in my case.
    When I force the Id, it's working and the gateway "shows" the values
    repeater started, id 20
    send: 20-20-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
    send: 20-20-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    send: 20-20-0-0 s=255,c=3,t=11,pt=0,l=17,st=fail:Repeter, pression
    send: 20-20-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 20-20-0-0 s=0,c=0,t=8,pt=0,l=5,st=ok:1.4.1
    Pression : 998.68 hPa
    send: 20-20-0-0 s=0,c=1,t=4,pt=2,l=2,st=ok:998
    send: 20-20-0-0 s=0,c=1,t=5,pt=0,l=7,st=ok:inconnu
    0;0;3;0;9;read: 20-20-0 s=255,c=0,t=18,pt=0,l=5:1.4.1
    20;255;0;0;18;1.4.1
    0;0;3;0;9;read: 20-20-0 s=255,c=3,t=6,pt=1,l=1:0
    20;255;3;0;6;0
    0;0;3;0;9;read: 20-20-0 s=255,c=3,t=12,pt=0,l=3:1.0
    20;255;3;0;12;1.0
    0;0;3;0;9;read: 20-20-0 s=0,c=0,t=8,pt=0,l=5:1.4.1
    20;0;0;0;8;1.4.1
    0;0;3;0;9;read: 20-20-0 s=0,c=1,t=4,pt=2,l=2:998
    20;0;1;0;4;998
    0;0;3;0;9;read: 20-20-0 s=0,c=1,t=5,pt=0,l=7:inconnu
    20;0;1;0;5;inconnu
    • XanderX
      XanderX
      Xander
      I'm not shure what your configuration is. You have:
      • a sensor node
      • a repeater Node
      • a serial / MQTT Gateway node
        3 nodes - is this OK?
      Or is your sensor node the repeater too. I don't know if this is possible.
      In case of a repeater node I'm not shure but I think the gateway is allways the "master" of all id's.
      TotcheT 1 Reply Last reply
      • XanderX Xander
        • a sensor node
        • a repeater Node
        TotcheT
        TotcheT
        Totche
        @Xander Thanks for the answer
        For now, I have a MQTT controller, one repeater node with a BMP180 sensor (to do the forecast on a long time, as by definition the repeater never sleeps, with a modified sketch and a timer of 1 seconde), and an another node with temperature, luminance and hymidity sensors.
        After some readings , i think that the gateway doesn't provide the Id, it's the role of the controller
        => in this discussion, you can read that, it's for Vera controller
        Your going to want a controller in the long term. For testing you can either hard code the node ID in the sketch (you will want to flash the EEPROM clear sketch when you get a controller)
        The reason your not seeing the temp on the gateway is because it doesn't get sent if there is no node ID.
        Basically the node is asking the gateway/controller who am I and the controller isn't responding so it just keeps asking.
        => I use openHAb instead of Vera, and there is XXX.items file where you define the Ids for node and child
        Number node1_temp  "Temp [%.1f °C]"     (node1,all)  {mqtt="<[mysensor:MyMQTT/20/10/V_TEMP:state:default]"}
        Number node1_humid "Humid [%.1f %%Rh]" (node1,all)  {mqtt="<[mysensor:MyMQTT/20/11/V_HUM:state:default]"}
        So I think that in this case, if the Ids are "constants" in openhab, they can't be randomly dealed by the gateway, and have to be fixed in each node
        I just tested by giving Id to the nodes, and all seems correct
        MQTT gateway
        Started!
        0;0;3;0;9;read: 20-20-0 s=0,c=1,t=4,pt=2,l=2:1012
        0;0;3;0;9;read: 21-21-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
        0;0;3;0;9;read: 21-21-0 s=255,c=3,t=6,pt=1,l=1:0
        0;0;3;0;9;read: 21-21-0 s=255,c=3,t=11,pt=0,l=18:Temp, lumin, hygro
        0;0;3;0;9;read: 21-21-0 s=255,c=3,t=12,pt=0,l=3:1.0
        0;0;3;0;9;read: 21-21-0 s=0,c=0,t=6,pt=0,l=5:1.4.1
        0;0;3;0;9;read: 21-21-0 s=1,c=0,t=16,pt=0,l=5:1.4.1
        0;0;3;0;9;read: 21-21-0 s=2,c=0,t=7,pt=0,l=5:1.4.1
        0;0;3;0;9;read: 21-21-0 s=0,c=1,t=0,pt=7,l=5:20.1
        0;0;3;0;9;read: 21-21-0 s=1,c=1,t=23,pt=3,l=2:20
        0;0;3;0;9;read: 21-21-0 s=2,c=1,t=1,pt=7,l=5:59.0
        Repeater node
        Pression : 1012.27 hPa
        send: 20-20-0-0 s=0,c=1,t=4,pt=2,l=2,st=ok:1012
        Sensors node
        sensor started, id 21
        send: 21-21-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
        send: 21-21-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
        send: 21-21-0-0 s=255,c=3,t=11,pt=0,l=18,st=ok:Temp, lumin, hygro
        send: 21-21-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
        send: 21-21-0-0 s=0,c=0,t=6,pt=0,l=5,st=ok:1.4.1
        send: 21-21-0-0 s=1,c=0,t=16,pt=0,l=5,st=ok:1.4.1
        send: 21-21-0-0 s=2,c=0,t=7,pt=0,l=5,st=ok:1.4.1
        Temperature : 20.10 C
        send: 21-21-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:20.1
        Luminosite : 20 lx
        send: 21-21-0-0 s=1,c=1,t=23,pt=3,l=2,st=ok:20
        Temperature hygro : 19.00C
        send: 21-21-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:59.0
        Hygrometrie : 59.00%
        Luminosite : 20 lx
        • TotcheT
          TotcheT
          Totche
          Re,
          I tried to use MYSController without success
          The IP is 192.168.1.234:1883 for the MQTT controller , but I can't read any values with the browser and MYSController.
          And as you can see in the serial monitors, the nodes seem to discuss together.
          I don't know how to check the communication with the MQTT gateway, apparently the problem comes from him
          Any tips, ?
          • XanderX
            XanderX
            Xander
            I use a client ( MQTT.fx http://www.jensd.de/wordpress/?cat=50 ) to test the mqtt gateway. Please see my post: http://forum.mysensors.org/topic/953/how-to-know-the-node-ids-assigned-by-the-mqtt-gateway-to-the-sensors/2
            With this tool I can see if the gateway is working and which id's are used. Then I configure OpenHAB accordingly.
            • XanderX Xander
              TotcheT
              TotcheT
              Totche
              @Xander Thanks ;)
              Very great link, now I can see what is sent.
              1)-
              2- The ip in MQTT.fx is the same as in openhab.cfg
              mqtt:mysensor.url=tcp://192.168.1.234:1883
               mqtt:mysensor.clientId=MQTT
              3- test.items
              Group all
              Group meteo //(all)
              Group noeud_1  (meteo)
              Group noeud_2  (meteo)
              //Group sketch (all)
              Number noeud1_temperature  "Temperature [%.1f °C]"    (noeud_1, all)  {mqtt="<[mysensor:MyMQTT/21/0/V_TEMP:state:default]"}
              Number noeud1_luminosite   "Luminosite [%.0f Lux]"  (noeud_1, all)  {mqtt="<[mysensor:MyMQTT/21/1/V_LIGHT_LEVEL:state:default]"}
              Number noeud1_humidite     "Humidite [%.0f Rh]"     (noeud_1, all)  {mqtt="<[mysensor:MyMQTT/21/2/V_HUM:state:default]"}
              4- openHAB runtime
              Launching the openHAB runtime...
              osgi> 2015-04-01 20:28:05.432 [INFO ] [.o.core.internal.CoreActivator] - openHAB
               runtime has been started (v1.6.2).
              2015-04-01 20:28:06.066 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service
              has been started
              2015-04-01 20:28:06.189 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Disco
              very initialization completed.
              2015-04-01 20:28:07.134 [INFO ] [penhab.io.rest.RESTApplication] - Started REST
              API at /rest
              2015-04-01 20:28:15.943 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model
               'test.sitemap'
              2015-04-01 20:28:16.055 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model
               'test.items'
              2015-04-01 20:28:16.653 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Class
              ic UI at /openhab.app
              nothing :(
              PS : i don't see the repeater with the barometer, I need to dissociate them so one nano more :(
              • GuyPG
                GuyPG
                GuyP
                Did you restart openHAB after you entered the MQTT gateway IP address in the configuration file? You don't need to restart when changing items, or sitemaps.
                You should check that openHAB has made a connection to the MQTT gateway.
                netstat -an |grep 1883
                root@openHAB:~# netstat -an |grep 1883
                tcp6       0      0 192.168.40.201:42199    192.168.40.200:1883     ESTABLISHED
                root@openHAB:~#
                Do you see it listed? If not restart the gateway, it should connect within a few minutes.
                • GuyPG GuyP
                  root@openHAB:~#
                  TotcheT
                  TotcheT
                  Totche
                  @GuyP Thanks for reply
                  I'm using windows 7, so I can't use your command, and see if connection is made
                  The IP in openHAB is set since the beginning, and I never changed.
                  • XanderX
                    XanderX
                    Xander
                    ... but "netstat -an" should work!
                    • XanderX Xander
                      TotcheT
                      TotcheT
                      Totche
                      @Xander I have that
                      C:\Users\Totche>netstat -an|find "1883"
                        TCP    0.0.0.0:1883           0.0.0
                        UDP    10.10.10.170:61883
                      • GuyPG
                        GuyPG
                        GuyP
                        that shows you have a listener, but nothing connected!
                        Are you running the gateway on this PC? if so the openhab configuration should be localhost or 127.0.0.1:1883.
                        • GuyPG GuyP
                          TotcheT
                          TotcheT
                          Totche
                          @GuyP Now I can see that
                            TCP    192.168.1.13:25638     192.168.1.134:1883     ESTABLISHED
                            UDP    0.0.0.0:61883          *:*
                          The last Ip 192.168.1.234 was out of range with the router definitions
                          But no more values in openHAB, pfff
                          • TotcheT
                            TotcheT
                            Totche
                            And tonight, the weird is back
                              TCP    0.0.0.0:1883           0.0.0.0:0              LISTENING
                            In openHAB.fx, I can see the msgs from the node, so I suppose that the ethernet connection is working
                            With MYSController, nothing displayed, no node network
                            With the serial, I can see the exchanges between node and the MQTTgateway
                            So what's wrong ? The Gateway, a port redirection ????
                            tekkaT 1 Reply Last reply
                            • TotcheT Totche
                              tekkaT
                              tekkaT
                              tekka
                              @Totche Just for clarification: MYSController is not compatible with MQTT gateways but with serial gw. .
                              • tekkaT tekka
                                TotcheT
                                TotcheT
                                Totche
                                #22
                                @tekka Ah OK, it's better to know it, thanks; ;)
                                And I found the error this morning and it works great......
                                To create the configuration file for openHAB, I made a copy/paste of the Mysensors example., and I haven't seen it was a space character at the beginning of each lines.
                                I removed it, and it's working fine.now
                                So be carefull with the spaces, it was a stupid mistake and boring to find.
                                I have done this test 5 times, so I'm sure that it's the problem.
                                Thank you everybody....
