  3. Multi Button Relay switch
43 Posts 13 Posters 29.8k Views 8 Watching
  • jeylitesJ jeylites
    @AWI Thank you so much. This is awesome! I bet so many people is going to benefit from this script.
    I had some time off today and ran the script. It didn't work the fist time, but I made some minor changes to "Relay_ON & Relay_OFF and also activated " Start State of Relays" and it worked. I'm guessing it didn't the first time because my relays are Active Low.
    Also, while toying around with it, I realize that it doesn't send back the status of the relay & actuator to the Controller (Homeseer). On Homeseer, suppose you have it at “ON” there is a maker that indicates its state and vice versa. I noticed that worked on Binary Switch & Motion Sensor but not on Relay & Relay Button Actuator sketch. Don't know if it's a script or Homeseer issue though.
    Again, thanks, everyone who helped pointing out the problem. I'm new to My Sensor and I'm glad to be here and making progress.
    #define RELAY_ON 0 //switch around for relay HIGH/LOW state
    #define RELAY_OFF 1
    jeylitesJ
    jeylitesJ
    jeylites
    wrote on last edited by jeylites
    #26
    @AWI I just realize another thing. The is a long delay for the sensor to sends its presentation during inclusion mode. Is there something to do with the number of sensors in one node or sketch? Essentially, I would have to reset the sensor several times to get it discovered.
    It's pretty quick on a single or double sensor node.
    AWIA 1 Reply Last reply
      AWIA
      AWIA
      AWI
      @jeylites I don't have experience with Homeseer as controller.and don't fully understand your questions, so just give it a shot..
      The multi relay sketch is firing a large amount of messages to the gateway/ controller during presentation. If you have transmission problems and/or a slow controller it could get into trouble. I suggest you monitor on the serial port of the sensor if there are "fail" messages. (need to turn on DEBUG = default) If there are it could be a power problem or...
      The real fun (and headache) is in the debugging :) The serial monitor can give you lost of clues
      Depending on how long is "long". there are also 250 ms delays between the individual presentations of the relays. ..'
      have fun ;)
      jeylitesJ 1 Reply Last reply
      • AWIA AWI
        have fun ;)
        jeylitesJ
        jeylitesJ
        jeylites
        @AWI
        I think you're right on the controller. I've been getting some glitch running HS3 on Mac. I don't know if its a plugin or software issue, but I will like to get to the bottom of it. In addition, a buddy of mine is loaning his Vera edge so I might run some test on that too.
        Meanwhile, will take your advice on serial monitor and will let you know the outcome. Cheers!
        • Q
          Q
          quocanhcgd
          Thanks for sharing.
          I have a problem with this scripts. My relay auto start then off every gateway check node. How can i fix it?
          • jeylitesJ
            jeylitesJ
            jeylites
            @quocanhcgd
            You will need to activate this line pinMode(Relays[i].relayPin, OUTPUT);
            It should work right after.
            Q 1 Reply Last reply
              @quocanhcgd
              Q
              Q
              quocanhcgd
              I activated this line but no result. may be openhab work wrong? What the controller you use?
              @jeylites said:
              @quocanhcgd
              • Q quocanhcgd
                @jeylites said:
                @quocanhcgd
                jeylitesJ
                jeylitesJ
                jeylites
                @quocanhcgd Homeseer
                  jeylitesJ
                  jeylitesJ
                  jeylites
                  #33
                  @quocanhcgd
                  I have tested the sketch on vera Ui7 & Homeseer but I don't know why it takes a very long time for the sketch to send individual presentations of the relay to the controller. Sometimes it doesn't send it at all. I have changed power supply as @AWI suggested and the relays are not connected to the Arduino at this time. Still nothing. Anyone here knows what the fail messages are. Below is the serial messages I got....
                  repeater started, id 2
                  send: 2-2-0-0 s=255,c=0,t=18,pt=0,l=5,st=fail:1.4.1
                  send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
                  send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=16,st=ok:MultiRelayButton
                  send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:0.9b
                  send: 2-2-0-0 s=0,c=1,t=2,pt=2,l=2,st=fail:1
                  send: 2-2-0-0 s=0,c=0,t=3,pt=0,l=5,st=fail:1.4.1
                  send: 2-2-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:1
                  send: 2-2-0-0 s=1,c=0,t=3,pt=0,l=5,st=fail:1.4.1
                  send: 2-2-0-0 s=2,c=1,t=2,pt=2,l=2,st=fail:1
                  send: 2-2-0-0 s=2,c=0,t=3,pt=0,l=5,st=fail:1.4.1
                  send: 2-2-0-0 s=3,c=1,t=2,pt=2,l=2,st=fail:0
                  send: 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
                  send: 2-2-0-0 s=3,c=0,t=3,pt=0,l=5,st=fail:1.4.1
                    @quocanhcgd
                    AWIA
                    AWIA
                    AWI
                    @jeylites I would suggest you take a closer look at the hardware. Almost all messages are failing and in most cases radio reception is the cause. Have you used capacitors on the radio's?
                    • AWIA AWI
                      jeylitesJ
                      jeylitesJ
                      jeylites
                      @AWI
                      No. Now that you mention it. I'm going to work on that. What does "st=fail:1.4.1" mean?
                      • sj44kS
                        sj44kS
                        sj44k
                        That there is an issue in the radio communication, and most probably the reason why it's taking so long, as all the failed transmissions will be retransmitted.
                        Like mentioned above (and on the webpage) you should install the capacitors on the radio.
                        Check the decoupling capacitor part of this page how to do this :
                        http://www.mysensors.org/build/connect_radio
                        • jeylitesJ
                          jeylitesJ
                          jeylites
                          #37
                          Still get the same error message despite putting a 4.7uf cap across GND and VCC (3.3v) on the radio for both sensor and gateway. But I don't get any fail messages using a different My Sensor sketch. What is error message: "st=fail:1.4.1" suggesting?
                          repeater started, id 1
                          send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                          send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                          read: 0-0-1 s=255,c=3,t=6,pt=0,l=1:M
                          send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=16,st=ok:MultiRelayButton
                          send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:0.9b
                          send: 1-1-0-0 s=0,c=1,t=2,pt=2,l=2,st=ok:0
                          send: 1-1-0-0 s=0,c=0,t=3,pt=0,l=5,st=fail:1.4.1
                          send: 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:0
                          send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=5,st=fail:1.4.1
                          send: 1-1-0-0 s=2,c=1,t=2,pt=2,l=2,st=ok:0
                          send: 1-1-0-0 s=2,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                          send: 1-1-0-0 s=3,c=1,t=2,pt=2,l=2,st=ok:1
                          send: 1-1-0-0 s=3,c=0,t=3,pt=0,l=5,st=fail:1.4.1
                          read: 0-0-1 s=2,c=1,t=2,pt=2,l=2:0
                          This is an ack from gateway
                            AWIA
                            AWIA
                            AWI
                            @jeylites What I read from the log is that there seems to be a little problem with sending a bunch of messages after another. (intermittent failures) probably because the radio power supply is not keeping up. Possible solutions: hardware: increase the capacitor size (eg. 47 uF) ; software: avoid sending messages after another and put a delay in between (like the 250ms delay used in your original setup() code).
                            Fail:1..4.1 means that something went wrong in communication with MySensors version 1.4.1. The good news is that the number of fail messages is decreasing with respect to the earlier log :clap:
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              @jeylites you can also try adding some delay between each gw.send or gw.present. In my case it did the difference.
                              ESP8266 GW + mySensors 2.3.2
                              Alexa / Google Home
                              • jeylitesJ
                                jeylitesJ
                                jeylites
                                I have put a 47uf, 100V capacitor in parallel with GND and 3.3V on the radio side and needless to say, it did help in reducing the number of fails. I have yet to receive my 5V to 3.3 radio adapter from China so I'm currently running of a two 1.5Vdc battery wired in series to the NRF radio.
                                In addition, I've also put a 250ms delay between sending messages after another. With every precaution in place, I'm still getting these same messages. I'm only having this problem with this particular sketch.
                                send: 2-2-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                                send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                                read: 0-0-2 s=255,c=3,t=6,pt=0,l=1:M
                                send: 2-2-0-0 s=0,c=1,t=2,pt=2,l=2,st=ok:0
                                send: 2-2-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:0
                                send: 2-2-0-0 s=2,c=1,t=2,pt=2,l=2,st=ok:1
                                send: 2-2-0-0 s=3,c=1,t=2,pt=2,l=2,st=ok:1
                                • rvendrameR
                                  rvendrameR
                                  rvendrame
                                  Maybe it worth a try, to remove the ACK requests? Remove the last 'true' from every gw.send line:
                                    gw.send(msg[i].set(Relays[i].relayState? true : false) ) ;
                                  Some fake radios don't play well with ACK messages. At least it worked for me.
                                  Alexa / Google Home
                                  • rvendrameR rvendrame
                                    jeylitesJ
                                    jeylitesJ
                                    jeylites
                                    #42
                                    @rvendrame
                                    Ever since I removed ACK & true, I have not been having any fails at all.
                                    Everything works and I have posted the final sketch in Array Relay Button Actuator as linked below... Hope it comes in handy. Thanks again MYS community!
                                    http://forum.mysensors.org/topic/1299/array-relay-button-actuator/12
                                    • SzmaluS
                                      SzmaluS
                                      Szmalu
                                      wrote on last edited by Szmalu
                                      #43
