  3. Multi Button Relay switch
43 Posts 13 Posters 30.3k Views 8 Watching
  • jeylitesJ jeylites
    @quocanhcgd Homeseer
    jeylitesJ
    jeylitesJ
    jeylites
    wrote on last edited by jeylites
    #33
    @quocanhcgd
    I have tested the sketch on vera Ui7 & Homeseer but I don't know why it takes a very long time for the sketch to send individual presentations of the relay to the controller. Sometimes it doesn't send it at all. I have changed power supply as @AWI suggested and the relays are not connected to the Arduino at this time. Still nothing. Anyone here knows what the fail messages are. Below is the serial messages I got....
    repeater started, id 2
    send: 2-2-0-0 s=255,c=0,t=18,pt=0,l=5,st=fail:1.4.1
    send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
    send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=16,st=ok:MultiRelayButton
    send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:0.9b
    send: 2-2-0-0 s=0,c=1,t=2,pt=2,l=2,st=fail:1
    send: 2-2-0-0 s=0,c=0,t=3,pt=0,l=5,st=fail:1.4.1
    send: 2-2-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:1
    send: 2-2-0-0 s=1,c=0,t=3,pt=0,l=5,st=fail:1.4.1
    send: 2-2-0-0 s=2,c=1,t=2,pt=2,l=2,st=fail:1
    send: 2-2-0-0 s=2,c=0,t=3,pt=0,l=5,st=fail:1.4.1
    send: 2-2-0-0 s=3,c=1,t=2,pt=2,l=2,st=fail:0
    send: 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
    send: 2-2-0-0 s=3,c=0,t=3,pt=0,l=5,st=fail:1.4.1
    AWIA 1 Reply Last reply
      @quocanhcgd
      AWIA
      AWIA
      AWI
      @jeylites I would suggest you take a closer look at the hardware. Almost all messages are failing and in most cases radio reception is the cause. Have you used capacitors on the radio's?
      jeylitesJ 1 Reply Last reply
      • AWIA AWI
        jeylitesJ
        jeylitesJ
        jeylites
        @AWI
        No. Now that you mention it. I'm going to work on that. What does "st=fail:1.4.1" mean?
        • sj44kS
          sj44kS
          sj44k
          That there is an issue in the radio communication, and most probably the reason why it's taking so long, as all the failed transmissions will be retransmitted.
          Like mentioned above (and on the webpage) you should install the capacitors on the radio.
          Check the decoupling capacitor part of this page how to do this :
          http://www.mysensors.org/build/connect_radio
          • jeylitesJ
            jeylitesJ
            jeylites
            #37
            Still get the same error message despite putting a 4.7uf cap across GND and VCC (3.3v) on the radio for both sensor and gateway. But I don't get any fail messages using a different My Sensor sketch. What is error message: "st=fail:1.4.1" suggesting?
            repeater started, id 1
            send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
            send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
            read: 0-0-1 s=255,c=3,t=6,pt=0,l=1:M
            send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=16,st=ok:MultiRelayButton
            send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:0.9b
            send: 1-1-0-0 s=0,c=1,t=2,pt=2,l=2,st=ok:0
            send: 1-1-0-0 s=0,c=0,t=3,pt=0,l=5,st=fail:1.4.1
            send: 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:0
            send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=5,st=fail:1.4.1
            send: 1-1-0-0 s=2,c=1,t=2,pt=2,l=2,st=ok:0
            send: 1-1-0-0 s=2,c=0,t=3,pt=0,l=5,st=ok:1.4.1
            send: 1-1-0-0 s=3,c=1,t=2,pt=2,l=2,st=ok:1
            send: 1-1-0-0 s=3,c=0,t=3,pt=0,l=5,st=fail:1.4.1
            read: 0-0-1 s=2,c=1,t=2,pt=2,l=2:0
            This is an ack from gateway
              AWIA
              AWIA
              AWI
              @jeylites What I read from the log is that there seems to be a little problem with sending a bunch of messages after another. (intermittent failures) probably because the radio power supply is not keeping up. Possible solutions: hardware: increase the capacitor size (eg. 47 uF) ; software: avoid sending messages after another and put a delay in between (like the 250ms delay used in your original setup() code).
              Fail:1..4.1 means that something went wrong in communication with MySensors version 1.4.1. The good news is that the number of fail messages is decreasing with respect to the earlier log :clap:
              • rvendrameR
                rvendrameR
                rvendrame
                @jeylites you can also try adding some delay between each gw.send or gw.present. In my case it did the difference.
                ESP8266 GW + mySensors 2.3.2
                Alexa / Google Home
                • jeylitesJ
                  jeylitesJ
                  jeylites
                  I have put a 47uf, 100V capacitor in parallel with GND and 3.3V on the radio side and needless to say, it did help in reducing the number of fails. I have yet to receive my 5V to 3.3 radio adapter from China so I'm currently running of a two 1.5Vdc battery wired in series to the NRF radio.
                  In addition, I've also put a 250ms delay between sending messages after another. With every precaution in place, I'm still getting these same messages. I'm only having this problem with this particular sketch.
                  send: 2-2-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                  send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                  read: 0-0-2 s=255,c=3,t=6,pt=0,l=1:M
                  send: 2-2-0-0 s=0,c=1,t=2,pt=2,l=2,st=ok:0
                  send: 2-2-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:0
                  send: 2-2-0-0 s=2,c=1,t=2,pt=2,l=2,st=ok:1
                  send: 2-2-0-0 s=3,c=1,t=2,pt=2,l=2,st=ok:1
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    Maybe it worth a try, to remove the ACK requests? Remove the last 'true' from every gw.send line:
                      gw.send(msg[i].set(Relays[i].relayState? true : false) ) ;
                    Some fake radios don't play well with ACK messages. At least it worked for me.
                    Alexa / Google Home
                    • rvendrameR rvendrame
                      jeylitesJ
                      jeylitesJ
                      jeylites
                      #42
                      @rvendrame
                      Ever since I removed ACK & true, I have not been having any fails at all.
                      Everything works and I have posted the final sketch in Array Relay Button Actuator as linked below... Hope it comes in handy. Thanks again MYS community!
                      http://forum.mysensors.org/topic/1299/array-relay-button-actuator/12
                      • SzmaluS
                        SzmaluS
                        Szmalu
                        wrote on last edited by Szmalu
                        #43
