  3. IR distance sensor with relay and repeater not working
8 Posts 2 Posters 3.7k Views 1 Watching
  • F Offline
    F Offline
    floris
    i cant make my IR distance-repeater-relay sensor to work. It doesnt go into the repeatermode and i cant switch the relays. the distancesensor does work.. anyone any idea?
    // Example sketch showing how to control physical relays.
    // This example will remember relay state even after power failure.
    #include <DistanceGP2Y0A21YK.h>
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    #define CHILD_ID_DISTANCE 100
    DistanceGP2Y0A21YK Dist;
    // unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
    int numSensors=0;
    boolean receivedConfig = true;
    boolean metric = true;
    int distance;
    int lastDistance=0;
    int loopCounter=0;
    MyMessage msg(1,V_LIGHT);
    MyMessage msgdist(CHILD_ID_DISTANCE,V_DISTANCE);
    Dist.begin(0);
    gw.begin(NULL, AUTO, true);
    gw.sendSketchInfo("RelayDistanceFloris", "1.0");
    gw.present(CHILD_ID_DISTANCE,S_DISTANCE);
    // Fetch relay status
    gw.present(sensor, S_LIGHT);
    pinMode(pin, OUTPUT);
    boolean savedState = gw.loadState(sensor);
    digitalWrite(pin, savedState?RELAY_ON:RELAY_OFF);
    gw.send(msg.set(savedState? 1 : 0));
    distance = Dist.getDistanceCentimeter();
    if (distance != lastDistance) {
    lastDistance = distance;
    gw.send(msgdist.set(distance));
    gw.sleep(50000);
    if (message.type==V_LIGHT) {
    boolean relayState = message.getBool();
    digitalWrite(message.sensor-1+RELAY_1, relayState?RELAY_ON:RELAY_OFF);
    gw.saveState(message.sensor, relayState);
    gw.send(msg.set(relayState? 1 : 0));
    B 1 Reply Last reply
    • F floris
      int numSensors=0;
      int distance;
      int lastDistance=0;
      int loopCounter=0;
      Dist.begin(0);
      gw.sleep(50000);
      B Offline
      B Offline
      BulldogLowell
      @floris said:
      gw.sleep(50000);
      it is sleeping, so it won't respond to repeater
      gw.sleep(50000);
      you need to keep the sensor awake if you plan on using the sensor as a repeater.
      think about using a millis( ) timer to check the distances every so many seconds....
      • F Offline
        F Offline
        floris
        Hi, thanks. if i disable that sleep, than i get a flipstorm from the distanceinfo. (and i still cant control my relay) i thought i would let send the distanceinfo each 5 seconds (for testing) and for the rest a no sleep mode for repeating and receiving for the relay...
        • F floris
          B Offline
          B Offline
          BulldogLowell
          @floris
          post your code between three 'backticks' (reverse apostrophe like this:
          <<<< three back ticks here
          code
          code
          etc
          code
          <<<< three more back ticks here
          so it can be more easily read...
          try to edit your loop( ) function to look like this:
            static unsigned long lastTime = millis();
            if (millis() - lastTime >= 5000UL) // update the distance every 5 seconds
          • F Offline
            F Offline
            floris
            wrote on last edited by floris
            Hi, ok. now i have changed it to this: But my relays doest react...
               int numSensors=0;
            int distance;
            int lastDistance=0;
            int loopCounter=0;
            Dist.begin(0);
            F 1 Reply Last reply
            • F floris
                 int numSensors=0;
              int distance;
              int lastDistance=0;
              int loopCounter=0;
              Dist.begin(0);
              F Offline
              F Offline
              floris
              Yessss. i guesss i have got it working!!!! thanks for the help! Floris
                  int numSensors=0;
              int distance;
              int lastDistance=0;
              int loopCounter=0;
                 Dist.begin(0);
                    gw.sendSketchInfo("RelayDistanceRepeaterFloris", "1.0");
              • F floris
                    int numSensors=0;
                int distance;
                int lastDistance=0;
                int loopCounter=0;
                   Dist.begin(0);
                B Offline
                B Offline
                BulldogLowell
                :+1:
                • F Offline
                  F Offline
                  floris
                  well.. i guess not..... It seems that its working for a short while. after that 1 of the relays does not respond anymore, when i set on relay on, both of the relays are going on? any help where my sketch is wrong?
                  Floris
                      int numSensors=0;
                  int distance;
                  int lastDistance=0;
                  int loopCounter=0;
                     Dist.begin(0);
                  12.2k
