  3. Can't build librf24-bcm on Banana Pi
12 Posts 2 Posters 7.0k Views 3 Watching
  • G Offline
    G Offline
    GreenSystemes
    Hi !
    I'm here because I have some problems with my Banana Pi.
    I downloaded the Zip file on : https://github.com/mysensors/Raspberry
    Read the README file and do the following step :
    sudo apt-get update
    sudo apt-get upgrade
    raspi-config
    and then enabled SPI module.
    At the end of the config, an error appeared
    FATAL: Module spi-bcm2708 not found.
    I ignored this error and tried to build librf24-bcm.
    cd Raspberry-Master/librf24-bcm
    make all
    the result is
    g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv6zk -D BCM2835_PERI_BASE=0x -c RF24.cpp
    gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv6zk -D BCM2835_PERI_BASE=0x -c bcm2835.c
    bcm2835.c: In function ‘bcm2835_init’:
    bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1208:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1209:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1210:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1211:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1212:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1213:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1214:28: error: invalid suffix "x" on integer constant
    bcm2835.c:1228:83: error: invalid suffix "x" on integer constant
    bcm2835.c:1232:81: error: invalid suffix "x" on integer constant
    bcm2835.c:1236:81: error: invalid suffix "x" on integer constant
    bcm2835.c:1239:83: error: invalid suffix "x" on integer constant
    bcm2835.c:1242:83: error: invalid suffix "x" on integer constant
    bcm2835.c:1246:83: error: invalid suffix "x" on integer constant
    bcm2835.c:1249:83: error: invalid suffix "x" on integer constant
    bcm2835.c:1253:79: error: invalid suffix "x" on integer constant
    Makefile:52: recipe for target 'bcm2835.o' failed
    make: *** [bcm2835.o] Error 1
    someone has an idea ?
    • J Offline
      J Offline
      Jan Gatzke
      @GreenSystemes said:
      Banana Pi.
      I think the problem is, that the banana pi uses another cpu and needs another spi driver. As the Raspberry master seems to compile against the broadcom driver there will be no easy fix for this.
      • G Offline
        G Offline
        GreenSystemes
        Agreed ! But if I do :
        sudo raspi-config
        It should work ... but here, there is an error :
        Now, I merged these files : https://github.com/LeMaker/bcm2835_BP with mysensors Lib and it partially works. I can compile but PiGateway doesn't work ...
        Nobody used a Banana Pi with mySensors before ?
        • J Offline
          J Offline
          Jan Gatzke
          Bcm stands for Broadcom. And there is no broadcom chip in the banana pi. You need to enable spi and then customize the source and port it to the banana pi.
          • G Offline
            G Offline
            GreenSystemes
            To enable SPI, I run :
            sudo modprobe spi-sun7i
            sudo raspi-config
            I got :
            But when I check in /dev/ SPI seems enabled
            ls /dev/spi*
            Now, when I execute PiGatewaySerial, I have a "check wires" message. But it can still be the drivers, or maybe I plugged the NRF on the wrong SPI port ?
            • J Offline
              J Offline
              Jan Gatzke
              Not sure what you are going to do with raspiconfig. Just addspi-sun7i to /etc/modules. The banana pi seems to have two spi busses. Could it be you have to connect the nrf to the other one? Or change the bus in the source code if hard coded? I don't have a banana pi and never used a pi as gateway. Still I wanna help. :D
              • G Offline
                G Offline
                GreenSystemes
                I'll try the second SPI bus but it seems be the good bus.
                After add spi-sun7i in /etc/modules, what i'm supposed to do ? reboot ? just try to run PiGateway ?
                • J Offline
                  J Offline
                  Jan Gatzke
                  Nothing. It's just for automatic modprobe on boot. Does lsmos show the module as loaded?
                  • G Offline
                    G Offline
                    GreenSystemes
                    the result of lsmod :
                    Module                  Size  Used by
                    spidev                  6217  12
                    spi_sun7i              17802  0
                    mali_drm                2608  0
                    drm                   209226  1 mali_drm
                    mali                  111427  0
                    ump                    52415  1 mali
                    • J Offline
                      J Offline
                      Jan Gatzke
                      Looks good.
                      • G Offline
                        G Offline
                        GreenSystemes
                        okay thank you for your help,
                        i'm trying an other way to run mysensors, i'll post a fix when it works.
                        • J Offline
                          J Offline
                          Jan Gatzke
                          wrote on last edited by Jan Gatzke
                          I just had another look at this. There is an nrf24 library for the banana pi: https://github.com/bearpawmaxim/librf24-sunxi/tree/master/src
                          The raspberry gateway must be ported to this lib. Doesn't look to complicated.
