  3. Help!!! Binary & Relay Compilation Not Working
15 Posts 4 Posters 5.4k Views 1 Watching
  • jeylitesJ
    jeylitesJ
    jeylites
    wrote on last edited by jeylites
    My bad. I copied the wrong sketch to this chat. I have revised the sketch and it complies but it's not working... :( Please see sketch above.
    • jeylitesJ
      jeylitesJ
      jeylites
      This is the serial message I get
      repeater started, id 12
      send: 12-12-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
      send: 12-12-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
      read: 0-0-12 s=255,c=3,t=6,pt=0,l=1:M
      send: 12-12-0-0 s=255,c=3,t=11,pt=0,l=5,st=ok:Relay
      send: 12-12-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
      send: 12-12-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Alarm Pannel
      send: 12-12-0-0 s=255,c=3,t=1,pt=0,l=3,st=ok:1.0
      send: 12-12-0-0 s=0,c=0,t=0,pt=0,l=5,st=ok:1.4.1
      setup for switch: 5 complete
      send: 12-12-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
      read: 0-0-12 s=255,c=3,t=1,pt=0,l=10:1435918408
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @jeylites
        fyi, just pick one name...
        gw.sendSketchInfo("Relay", "1.0");
        gw.sendSketchInfo("Alarm Pannel", "1.0");
        What is this supposed to be doing? it looks like:
        reporting the state of three reed switches
        actuating a relay
        Why are you using the dalays? time?
        hard to really understand what you are trying to do here...
        • jeylitesJ
          jeylitesJ
          jeylites
          @BulldogLowell
          Essentially, I will like to combine Array Binary and Relay Actuator in one sketch.
          • BulldogLowellB
            BulldogLowellB
            BulldogLowell
            three binary switches and a single relay?
            • jeylitesJ
              jeylitesJ
              jeylites
              yes sir !
              • jeylitesJ
                jeylitesJ
                jeylites
                @BulldogLowell
                Any ideas how I can get this to work?
                Moshe LivneM BulldogLowellB 2 Replies Last reply
                • jeylitesJ jeylites
                  @BulldogLowell
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  @jeylites it looks like you are overwriting i somewhere inside the loop. can you try to add prints of the value of i at several strategic points to see when it becomes 5? I would suggest to add one (and also print BUTTON_PIN[i]) before "msg[i].sensor = i;", one after "// Setup the button" and print i with the BUTTON_PIN[i].
                  • jeylitesJ
                    jeylitesJ
                    jeylites
                    @Moshe-Livne
                    I'm going to try fix it as suggested. But the thing is it complies....
                      @Moshe-Livne
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @jeylites Alas compiling is not a guarantee against memory overwrites....as button_pin should have shown 4 and not 5 i assume that either the index (i) got corrupt or the button_pin array.
                        @BulldogLowell
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        @jeylites
                        I think this is what you want. I cannot test it right now, but it does compile:
                        #define NUMBER_OF_REEDS 3
                        const int relayPin = 3;
                        const int reedPin[NUMBER_OF_REEDS] = {4, 5, 6};
                        int reedState[NUMBER_OF_REEDS];
                        Bounce debouncer[NUMBER_OF_REEDS] = Bounce();
                        MyMessage msg[NUMBER_OF_REEDS];
                          gw.sendSketchInfo("Test", "1.0a");
                          gw.present(0, S_LIGHT);
                          pinMode(relayPin, OUTPUT);
                          digitalWrite(relayPin, gw.loadState(0));
                          for (int i = 0; i < NUMBER_OF_REEDS; i++)
                            debouncer[i].attach(reedPin[i]);
                            debouncer[i].interval(5);
                            pinMode(reedPin[i], INPUT_PULLUP);
                            gw.present(i, S_DOOR);
                            gw.wait(250);
                            debouncer[i].update();
                            if (value != reedState[i])
                              gw.send(msg[i+1].set(value), false); // device number mismatch here because of the array
                              reedState[i] = value;
                              Serial.print("updating state for switch: ");
                              Serial.print(reedPin[i]);
                              Serial.print(" state: ");
                              Serial.println(reedState[i]);
                        void incomingMessage(const MyMessage &message)
                          if (message.type == V_LIGHT)
                            int newState = message.getBool();
                            digitalWrite(relayPin, newState);
                            gw.saveState(0, newState);
                            Serial.print(F("Incoming change for relay, New state: "));
                            Serial.println(newState);
                        EDIT: Updated to correct debounce class errors
                        • BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @jeylites
                          to turn relay off automatically after two minutes (and send the updated "off status" to controller... try something like this untested code:
                          unsigned long relayTimer;
                          MyMessage relayMessage(0,V_LIGHT);
                              gw.wait(250);
                            if (millis() - relayTimer > 2 * 60 * 1000UL && digitalRead(relayPin)) // two minute timer
                              digitalWrite(relayPin, LOW);
                              gw.saveState(0, false);
                              gw.send(relayMessage.set(false), true);
                              if (newState)
                                relayTimer = millis();
