  2. Bug Reports
  3. Sensor::readMessage()
3 Posts 2 Posters 2.6k Views 1 Watching
  • EasyIoTE
    EasyIoTE
    EasyIoT
    When I ported sensor.cpp to C# i notice:
    boolean Sensor::readMessage() {
    uint8_t len = RF24::getDynamicPayloadSize();
    RF24::read(&msg, len);
    if (!(msg.header.messageType==M_INTERNAL && msg.header.type == I_PING_ACK)) {
    	delay(ACK_SEND_DELAY); // Small delay here to let other side switch to reading mode
    	RF24::stopListening();
    	RF24::openWritingPipe(TO_ADDR(msg.header.last));
    	RF24::write(&radioId, sizeof(uint8_t));
    	RF24::closeReadingPipe(WRITE_PIPE); // Stop listening to write-pipe after transmit
    	RF24::startListening();
    	debug(PSTR("Sent ack msg to %d\n"), msg.header.last);
    uint8_t valid = validate(len-sizeof(header_s));
    boolean ok = valid == VALIDATE_OK;
    // Make sure string gets terminated ok for full sized messages.
    msg.data[len - sizeof(header_s) ] = '\0';
    debug(PSTR("Rx: fr=%d,to=%d,la=%d,ci=%d,mt=%d,t=%d,cr=%d(%s): %s\n"),
    		msg.header.from,msg.header.to, msg.header.last, msg.header.childId, msg.header.messageType, msg.header.type, msg.header.crc, valid==0?"ok":valid==1?"ec":"ev", msg.data);
    return ok;
    Is this correct? Isn't better to first validante message and then send confirmation if it is ok. Like this:
    boolean ok = valid == VALIDATE_OK;**
    if (ok && !(msg.header.messageType==M_INTERNAL && msg.header.type == I_PING_ACK)) {
    return ok;
    EasyIoT framework http://iot-playground.com
      Yes, you're right!
      I will change this.
      • EasyIoTE
        EasyIoTE
        EasyIoT
        Also in RelayActuator.ino
        void setRelayStatus(message_s message) {
        if (message.header.messageType=M_SET_VARIABLE &&
        message.header.type==V_LIGHT) {
        is better:
        if ((message.header.messageType==M_SET_VARIABLE || message.header.messageType==M_ACK_VARIABLE ) &&
        Be careful message.header.messageType=M_SET_VARIABLE and message.header.messageType==M_SET_VARIABLE is not the same.
