  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.5k Views 30 Watching
  • T tomkxy
    @Anticimex: I found the issue with respect to the gateway sending a message back to the sensor. This is due to the gateway subscribing to all topics on the MQTT broker. Once it receives a message it sends it to the sensor as SET message. I have to resolve that one.
    I think, I still have an issue with signing which I need to get sorted myself first. I will let you know.
    AnticimexA
    AnticimexA
    Anticimex
    @tomkxy Alright. Good to know that you found the root cause for the message issue.
    Regarding signing, from what I could see at least some signed messages did come through, so you should at least have the proper shared states (keys) and configs.
    • T
      tomkxy
      I did a few test with my ATSHA204. I could get it working on an Uno. The I took the chip and placed it on my breadboard with my ProMini. I tried to run the SHA Personaliser Sketch again just to make sure that the chip is somehow working and I received an error message that the device cannot be woken up.
      Since it worked on the Uno (including running the SHA Personalizer) it must be related to the ProMini (3.3V / 8 MHz).
      To what pin do I have to connect the data line?
      AnticimexA 1 Reply Last reply
      • T tomkxy
        AnticimexA
        AnticimexA
        Anticimex
        @tomkxy That sounds strange. I have run on ProMini 3.3V/8MHz without issues.
        Default is to use A3 for the ATSHA204A. It does not really matter which pin you connect it as long as it is usable for digital I/O (and update MY_ATSHA204_PIN accordingly or provide your pin to the MySigningAtsha204 constructor).
        • T
          tomkxy
          How do I change the pin definition if I use A3 on the ProMini?
          • AnticimexA
            AnticimexA
            Anticimex
            A3 is default setting. You can find the definition of MY_ATSHA204_PIN in MyConfig.h.
            • T
              tomkxy
              Yep, it is
              `#define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
              I am just irritate by the 17. So this does map to A3 even on ProMini?
              • T tomkxy
                Yep, it is
                AnticimexA
                AnticimexA
                Anticimex
                @tomkxy yes it does.
                • T
                  tomkxy
                  @Anticimex Unfortunately, I am now in a total state of mess. It seems that nothing works anymore the moment I turn on any signing. For sure, I have a problem with ATSHA204 and the ProMini which I need to sort out separately. I tried them all with my Uno (reading out the config) which worked. When I try to just read the config with my ProMini I get the error cannot wake up device.
                  But now, even soft signing did not work any longer (it worked first, than I made changes and afte. I just receive nonce transmission errors from the sensor to the gateway although both radios are side by side and transmission without signing works perfectly.
                  Btw, what is stored in the EPROM and under what circumstances do I have to clear EPROM first. I changed between the various signing feature (soft signing, HW signing, signing required etc.) back and forth and it seems that this info is stored in EPROM and somehow not cleared?? How does the sensor know that the gateway requires signing? Will it get the info out of EPROM? Will this information be updated during presentation?
                  I think you did a great job on that implementation, the more frustrating it is that I cannot get it to work reliably. I am out for today. May be I find some time tomorrow getting anot ProMini prepared to checkout the issue with the chips.
                  • T tomkxy
                    AnticimexA
                    AnticimexA
                    Anticimex
                    #144
                    @tomkxy The information stored in EEPROM is not specific to any backend. It just informs the node what other nodes require signed messages. At startup, a node broadcasts it's preference to the gateway which then updates it's EEPROM table and replies with its own preference back so the node knows if the gateway wants signed messages as well. If the preferences differ from what is stored in EEPROM already, it is the updated preferences that will replace the stored preferences.
                    The usecases for this is if you were to deploy a new sensor which require signing, it would inform gateway of this at startup. But if you restart your gateway it would loose this unless it was stored in EEPROM (the same goes the other way around) so the EEPROM is used so that the signing rules in the network gets preserved even if nodes dissappear or restart.
                    If you suspect the EEPROM to contain corrupt data, you can clear it with the cleareeorom sketch/example.
                    The typical circumstance you need to clear EEPROM under is when you switch library version, and the reserved region of EEPROM in the library change (and you also use EEPROM in your sketch). Then the library might take some of your sketch data for "it's own" and that can/will lead to unpredictable results.
                      #145
                      Just to say, that I tried some weeks ago ATSHA204A with pro mini and had no problem too. Maybe you should try clear eeprom and retry. Or try with another pro mini. But it should work I think.
                      And for those who want to test excellent work of @Anticimex and @Tekka, I have posted a simple/basic not expensive, 1.8$ for 3 breakouts here : https://oshpark.com/shared_projects/lvvxsHSW . It can be useful for existing nodes too.
                      See you soon
                      TD22057T 1 Reply Last reply
                      • scalzS scalz
                        See you soon
                        TD22057T
                        TD22057T
                        TD22057
                        Good idea - I'm finding soldering the ATSHA chips to be a real pain and a small breakout board would help with that. Is the eeprom pads on your board for people who are just using a mega328 chip? Doesn't a pro-mini already have enough eeprom on board?
                          @TDD22057: eeprom on the breakout is for the new ota in Mysensors (over the air upload sketch) . It is not related to authentication.
                          I made this cheap breakout firstly because I wanted to test the new Mysensors features easily. and I thought it could be useful in some specific case where you don't need to make a pcb for one specific usercase so you use a veroboard and so you can easily add these new features with less pain...
                          Happy it can help some people :smile:
                          • T
                            tomkxy
                            Regarding my issue with the ATSHA204A, I did some testing with the following results. I soldered the ATSHA204A on a small breakout board and loaded the SHAPersonalizer sketch.
                            I tested three configurations:
                            1. Breakout wired to the ProMini without breadboard use
                            2. Breakout wired to a breadboard where the ProMini was plugged
                            3. Breakout and ProMini both plugged to breadboard and connected by wires.
                            Config 3 does not work!!!
                            That means the breadboard significantly changes the electrical characteristics. Is anybody on the forum who is able to explain that?
                              @tomkxy: it is strange. My first tests have been done in you config 3 (atsha breakout and promini both plugged to breadboard). And it worked well for me. Could it be your wire quality??? I had problems with some Dupont wire once...
                              • T
                                tomkxy
                                Well , could be... I had to use different wires female - female, male - female, male - male (for config 3). For the male-male wire I have no other option at the moment.
                                However, I am glad it works now.
                                • T tomkxy
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  Good news! Regarding breadboard issues, it could be that you need an additional decoupling on the VCC line to the atsha204a. And also perhaps a pullup on the SDA signal. Breadboards usually put some more requirements on noise suppression.
                                  • O
                                    O
                                    otto001
                                    I seem to be too stupid (or drunk ;-) ) to get this working with MySigningAtsha204Soft :-(
                                    Is anyone willing to provide a working MyConfig.h and EthernetGateway.ino for this?
                                    There seemed to be some changes and I am sure, I am just too dumb... :-(
                                    • T
                                      tomkxy
                                      Here you go....However, I do not have EthernetGateway but a MQTTClientGateway. May be it is of help.
                                      What is your specific problem?
                                      myconfig.h (key changed)
                                      #ifndef MyConfig_h
                                      #define MyConfig_h
                                      #include <stdint.h>
                                      #define DEBUG
                                      #define BAUD_RATE 115200
                                      #define MY_OTA_FLASH_SS 8
                                      // Flash jdecid
                                      *  Information LEDs blinking
                                      // disabled in the gateway.
                                      //#define WITH_LEDS_BLINKING
                                      // off when blinking
                                      // The RX LED default pin
                                      #define DEFAULT_RX_LED_PIN 6
                                      // The TX LED default pin
                                      #define DEFAULT_TX_LED_PIN 5
                                      // The Error LED default pin
                                      #define DEFAULT_ERR_LED_PIN 4
                                      *  Message Signing Settings
                                      #define MY_SIGNING_FEATURE
                                      #define MY_HMAC_KEY 0x10,0x23,0xBB,0x78,0x77,0x35,0xB0,0x01,0x70,0x47,0xF1,0xDE,0x21,0x94,0x54,0x67,0xEE,0x36,0x72,0x00,0x97,0x12,0xA0,0x0A,0x0F,0x09,0x03,0xE2,0x00,0x31,0xE4,0x41
                                      *  NRF24L01 Driver Defaults
                                      #define RF24_CE_PIN		   9
                                      #define RF24_CS_PIN		   10
                                      #define RF24_CHANNEL	   76
                                      //#define SOFTSPI
                                      #ifdef SOFTSPI
                                      *  RFM69 Driver Defaults
                                      /* 				MyMQTT Client Gateway 0.1b
                                       Created by Norbert Truchsess <norbert.truchsess@t-online.de>
                                       Based on MyMQTT-broker gateway created by Daniel Wiegert <daniel.wiegert@gmail.com>
                                       Based on MySensors Ethernet Gateway by Henrik Ekblad <henrik.ekblad@gmail.com>
                                       http://www.mysensors.org
                                       Requires MySensors lib 1.4b
                                       * Change below; TCP_IP, TCP_PORT, TCP_MAC
                                       This will listen on your selected TCP_IP:TCP_PORT below, Please change TCP_MAC your liking also.
                                       *1 -> NOTE: Keep first byte at x2, x6, xA or xE (replace x with any hex value) for using Local Ranges.
                                       *2 You can use standard pin set-up as MySensors recommends or if you own a IBOARD you may change
                                       the radio-pins below if you hardware mod your iBoard. see [URL BELOW] for more details.
                                       http://forum.mysensors.org/topic/224/iboard-cheap-single-board-ethernet-arduino-with-radio/5
                                       * Don't forget to look at the definitions in libraries\MySensors\MyMQTT.h!
                                       define TCPDUMP and connect serial interface if you have problems, please write on
                                       http://forum.mysensors.org/ and explain your problem, include serial output. Don't forget to
                                       turn on DEBUG in libraries\MySensors\MyConfig.h also.
                                       MQTT_FIRST_SENSORID is for 'DHCP' server in MyMQTT. You may limit the ID's with FIRST and LAST definition.
                                       If you want your manually configured below 20 set MQTT_FIRST_SENSORID to 20.
                                       To disable: set MQTT_FIRST_SENSORID to 255.
                                       MQTT_BROKER_PREFIX is the leading prefix for your nodes. This can be only one char if like.
                                       MQTT_SEND_SUBSCRIPTION is if you want the MyMQTT to send a empty payload message to your nodes.
                                       This can be useful if you want to send latest state back to the MQTT client. Just check if incoming
                                       message has any length or not.
                                       Example: if (msg.type==V_LIGHT && strlen(msg.getString())>0) otherwise the code might do strange things.
                                       * Address-layout is : [MQTT_BROKER_PREFIX]/[NodeID]/[SensorID]/V_[SensorType]
                                       NodeID and SensorID is uint8 (0-255) number.
                                       Last segment is translation of the sensor type, look inside MyMQTT.cpp for the definitions.
                                       User can change this to their needs. We have also left some space for custom types.
                                       Special: (sensor 255 reserved for special commands)
                                       You can receive a node sketch name with MyMQTT/20/255/V_Sketch_name (or version with _version)
                                       To-do:
                                       Special commands : clear or set EEPROM Values, Send REBOOT and Receive reboot for MyMQTT itself.
                                       Be able to send ACK so client returns the data being sent.
                                       ... Please come with ideas!
                                       What to do with publish messages.
                                       Test in more MQTT clients, So far tested in openhab and MyMQTT for Android (Not my creation)
                                       - http://www.openhab.org/
                                       - https://play.google.com/store/apps/details?id=at.tripwire.mqtt.client&hl=en
                                       ... Please notify me if you use this broker with other software.
                                       * How to set-up Openhab and MQTTGateway:
                                       http://forum.mysensors.org/topic/303/mqtt-broker-gateway
                                       Changes by Thomas Krebs <thkrebs@gmx.de>
                                       - Add signing support from MySensors 1.5 and update for MySensors 1.5;
                                       - Restructured code back to a C like implementation following the existing MQTTGateway
                                      #include "MyMQTTClient.h"
                                      #include "PubSubClient.h"
                                      #include <Ethernet.h>
                                      #include <DigitalIO.h>
                                      #include <MsTimer2.h>
                                      #include <Time.h>
                                      #ifdef MY_SIGNING_FEATURE
                                      #include <MySigningNone.h>
                                      //#define DSRTC
                                      #ifdef DSRTC
                                      #include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
                                       * To configure MQTTClientGateway.ino to use an ENC28J60 based board include
                                       * 'UIPEthernet.h' (SPI.h required for MySensors anyway). The UIPEthernet-library can be downloaded
                                      //#include <UIPEthernet.h>
                                       * To execute MQTTClientGateway.ino on Yun uncomment Bridge.h and YunClient.h.
                                       * Do not include Ethernet.h or SPI.h in this case.
                                       * On Yun there's no need to configure local_ip and mac in the sketch
                                       * as this is configured on the linux-side of Yun.
                                      //#include <Bridge.h>
                                      //#include <YunClient.h>
                                      // * Use this for IBOARD modded to use standard MISO/MOSI/SCK, see note *1 above!
                                       #define RADIO_CE_PIN        3			// radio chip enable
                                       #define RADIO_SPI_SS_PIN    8			// radio SPI serial select
                                       #define RADIO_ERROR_LED_PIN A2  		// Error led pin
                                       #define RADIO_RX_LED_PIN    A1  		// Receive led pin
                                       #define RADIO_TX_LED_PIN    A0  		// the PCB, on board LED*/
                                      // * Use this for default configured pro mini / nano etc :
                                      //#define RADIO_CE_PIN        5		// radio chip enable
                                      //#define RADIO_SPI_SS_PIN    6		// radio SPI serial select
                                      //#define RADIO_ERROR_LED_PIN 7		// Error led pin
                                      //#define RADIO_RX_LED_PIN    8		// Receive led pin
                                      //#define RADIO_TX_LED_PIN    9		// the PCB, on board LED*/
                                      // CE_PIN and SPI_SS_PIN for Mega
                                      #define RADIO_CE_PIN        48			// radio chip enable
                                      #define RADIO_SPI_SS_PIN    49			// radio SPI serial select
                                      //replace with ip of server you want to connect to, comment out if using 'remote_host'
                                      uint8_t remote_ip[] =  { 192, 168, 178, 74 };  // Mosquitto broker
                                      //replace with hostname of server you want to connect to, comment out if using 'remote_ip'
                                      //char* remote_ip = "server.local";
                                      //replace with the port that your server is listening on
                                      #define remote_port 1883
                                      //replace with arduinos ip-address. Comment out if Ethernet-startup should use dhcp. Is ignored on Yun
                                      uint8_t local_ip[] = {192, 168, 178, 11};
                                      //replace with ethernet shield mac. It's mandatory every device is assigned a unique mac. Is ignored on Yun
                                      uint8_t mac[] = { 0xA2, 0xAE, 0xAD, 0xA0, 0xA0, 0xA2 };
                                      #if defined remote_ip && defined remote_host
                                      #error "cannot define both remote_ip and remote_host at the same time!"
                                      #ifdef _YUN_CLIENT_H_
                                      YunClient ethClient;
                                      EthernetClient ethClient;
                                      //MyTransportRFM69 transport;
                                      //MySigningNone signer;
                                      MySigningAtsha204Soft signer;
                                      //MySigningAtsha204 signer;
                                      // Hardware profile
                                      MyHwATMega328 hw;
                                      MyMessage msg;
                                      char convBuf[MAX_PAYLOAD * 2 + 1];
                                      uint8_t buffsize;
                                      char buffer[MQTT_MAX_PACKET_SIZE];
                                      volatile uint8_t countRx;
                                      volatile uint8_t countTx;
                                      volatile uint8_t countErr;
                                      void processMQTTMessages(char* topic, byte* payload, unsigned int length);
                                      PubSubClient client(remote_ip, remote_port, processMQTTMessages, ethClient);
                                      // Declare and initialize MySensor instance
                                      // Construct MyMQTTClient (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h, if signing
                                      // feature not to be used, uncomment)
                                      MySensor gw(transport, hw
                                                  , signer
                                      #ifdef WITH_LEDS_BLINKING
                                                  , RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN
                                       * setup
                                        countRx = 0;
                                        countTx = 0;
                                        countErr = 0;
                                        Ethernet.begin(mac, local_ip);
                                        //Bridge.begin();
                                        delay(1000);   // Wait for Ethernet to get configured.
                                        begin();
                                       * loop
                                        if (!client.connected())
                                          client.connect("MySensor");
                                          client.subscribe(MQTT_TOPIC_MASK);
                                        client.loop();
                                       * processRadioMessage
                                       * Receives radio message, parses it and forwards it to the MQTT broker
                                      void processRadioMessage(const MyMessage &message)
                                          rxBlink(1);
                                          sendMQTT(message);
                                       * sendMQTT
                                       * Handles processing of radio messages and eventually publishes it to the MQTT broker
                                      void sendMQTT(const MyMessage &inMsg)
                                        MyMessage msg = inMsg;
                                        buffsize = 0;
                                          return;			//We have no connections - return
                                        if (msg.isAck())
                                      #ifdef DEBUG
                                          Serial.println("msg is ack!");
                                          if (msg.sender == 255 && mGetCommand(msg) == C_INTERNAL
                                              && msg.type == I_ID_REQUEST)
                                            // TODO: sending ACK request on id_response fucks node up. doesn't work.
                                            // The idea was to confirm id and save to EEPROM_LATEST_NODE_ADDRESS.
                                          // we have to check every message if its a newly assigned id or not.
                                          // Ack on I_ID_RESPONSE does not work, and checking on C_PRESENTATION isn't reliable.
                                          uint8_t newNodeID = gw.loadState(EEPROM_LATEST_NODE_ADDRESS) + 1;
                                          if (newNodeID <= MQTT_FIRST_SENSORID)
                                            newNodeID = MQTT_FIRST_SENSORID;
                                          if (msg.sender == newNodeID)
                                            gw.saveState(EEPROM_LATEST_NODE_ADDRESS, newNodeID);
                                          if (mGetCommand(msg) == C_INTERNAL)
                                            if (msg.type == I_CONFIG)
                                              txBlink(1);
                                              if (!gw.sendRoute(
                                                    build(msg, GATEWAY_ADDRESS, msg.sender, 255, C_INTERNAL,
                                                          I_CONFIG, 0).set("M")))
                                                errBlink(1);
                                            else if (msg.type == I_TIME)
                                      #ifdef DEBUG
                                              Serial.println("I_TIME requested!");
                                              txBlink(1);
                                              if (!gw.sendRoute(
                                                          I_TIME, 0).set(now())))
                                                errBlink(1);
                                            else if (msg.type == I_ID_REQUEST && msg.sender == 255)
                                              if (newNodeID >= MQTT_LAST_SENSORID)
                                                return; // Sorry no more id's left :(
                                              txBlink(1);
                                              if (!gw.sendRoute(
                                                          I_ID_RESPONSE, 0).set(newNodeID)))
                                                errBlink(1);
                                            else if (msg.type == I_BATTERY_LEVEL)
                                              strcpy_P(buffer, mqtt_prefix);
                                              buffsize += strlen_P(mqtt_prefix);
                                              buffsize += sprintf(&buffer[buffsize], "/%i/255/BATTERY_LEVEL\0", msg.sender );
                                              msg.getString(convBuf);
                                      #ifdef DEBUG
                                              Serial.print("publish: ");
                                              Serial.print((char*) buffer);
                                              Serial.print(" ");
                                              Serial.println((char*) convBuf);
                                              client.publish(buffer, convBuf);
                                            else if (msg.type == I_SKETCH_NAME)
                                              buffsize += sprintf(&buffer[buffsize], "/%i/255/SKETCH_NAME\0", msg.sender );
                                      #ifdef DEBUG
                                              Serial.print(" ");
                                            else if (msg.type == I_SKETCH_VERSION)
                                              buffsize += sprintf(&buffer[buffsize], "/%i/255/SKETCH_VERSION\0", msg.sender );
                                      #ifdef DEBUG
                                              Serial.print(" ");
                                          else if (mGetCommand(msg) != 0)
                                            if (mGetCommand(msg) == 3)
                                              msg.type = msg.type + (S_FIRSTCUSTOM - 10);	//Special message
                                            if (msg.type > VAR_TOTAL)
                                              msg.type = VAR_TOTAL;		// If type > defined types set to unknown.
                                            buffsize += sprintf(&buffer[buffsize], "/%i/%i/V_%s\0", msg.sender,
        msg.sensor, getType(convBuf, &VAR_Type[msg.type]));
                                      #ifdef DEBUG
                                            Serial.print(" ");
                                       * build
                                       * Constructs a radio message
                                      inline MyMessage& build(MyMessage &msg, uint8_t sender, uint8_t destination, uint8_t sensor,
                                                              uint8_t command, uint8_t type, bool enableAck)
                                        msg.destination = destination;
                                        msg.sender = sender;
                                        msg.sensor = sensor;
                                        msg.type = type;
                                        mSetCommand(msg, command);
                                        mSetRequestAck(msg, enableAck);
                                        mSetAck(msg, false);
                                        return msg;
                                       * getType
                                      char *getType(char *b, const char **index)
                                        char *q = b;
                                        char *p = (char *) pgm_read_word(index);
                                        while (*q++ = pgm_read_byte(p++))
                                        *q = 0;
                                        return b;
                                       * begin
                                       * wraps MySensors begin method; setup of RTC and led timers interrupt
                                      void begin()
                                      #ifdef DEBUG
                                        Serial.begin(BAUD_RATE);
                                      #ifdef DSRTC
                                        // Attach RTC
                                        setSyncProvider(RTC.get);   // the function to get the time from the RTC
                                        setSyncInterval(60);
                                        gw.begin(processRadioMessage, 0, true, 0);
                                        MsTimer2::set(200, ledTimersInterrupt);
                                        MsTimer2::start();
                                      #ifdef DEBUG
                                        Serial.print(getType(convBuf, &VAR_Type[S_FIRSTCUSTOM]));
                                       * processMQTTMessages
                                       * message handler for the PubSubClient
                                        processMQTTMessage(topic, payload, length);
                                       * processes MQTT messages, parses the topic, extracts radio address out of topic and sends them
                                       * to the respective radio
                                      void processMQTTMessage(char* topic, byte* payload,
                                        char *str, *p;
                                        uint8_t i = 0;
                                        buffer[0] = 0;
                                        buffsize = 0;
                                        uint8_t cmd = -1;
                                             str = strtok_r(NULL, "/", &p))
                                          switch (i)
                                            case 0:
                                                if (strcmp_P(str, mqtt_prefix) != 0)
                                                { //look for MQTT_PREFIX
                                                  return;			//Message not for us or malformatted!
                                            case 1:
                                                msg.destination = atoi(str);	//NodeID
                                            case 2:
                                                msg.sensor = atoi(str);		//SensorID
                                            case 3:
                                                char match = 0;			//SensorType
                                                //strcpy(str,(char*)&str[2]);  //Strip VAR_
                                                for (uint8_t j = 0;
                                                     strcpy_P(convBuf, (char*) pgm_read_word(&(VAR_Type[j]))); j++)
                                                  if (strcmp((char*) &str[2], convBuf) == 0)
                                                  { //Strip VAR_ and compare
                                                    match = j;
                                                  if (j >= VAR_TOTAL)
                                                  { // No match found!
                                                    match = VAR_TOTAL;	// last item.
                                                msg.type = match;
                                             case 4:
                                                  // support the command get and set; get will be mapped to a C_REQ and set to C_SET
                                                  if (strcmp(str,MQTT_CMD_SET) == 0)
                                                    cmd = C_SET;
                                                  else if (strcmp(str,MQTT_CMD_GET) == 0) {
                                                    cmd = C_REQ;
                                                  else {
                                      #ifdef DEBUG
                                                    Serial.print("Received unsupported command - ignore: ");
                                                    Serial.println(str);
                                          i++;
                                        }						//Check if packge has payload
                                        if (cmd != -1) {
                                          char* ca;
                                          ca = (char *)payload;
                                          ca += length;
                                          *ca = '\0';
                                          msg.set((const char*)payload);			//Payload
                                          txBlink(1);
                                          // inject time
                                          if ((msg.destination == 0) && (msg.sensor == 199)) {
                                            unsigned long epoch = atol((char*)payload);
                                            if (epoch > 10000) {
                                      #ifdef DSRTC
                                              RTC.set(epoch); // this sets the RTC to the time from controller - which we do want periodically
                                              setTime(epoch);
                                      #ifdef DEBUG
                                            Serial.print("Time recieved ");
                                            Serial.println(epoch);
                                          if (!gw.sendRoute(
                                                build(msg, GATEWAY_ADDRESS, msg.destination, msg.sensor, C_SET, msg.type,
                                                      0)))
                                            errBlink(1);
                                      // Led handling
                                       * ledTimersIntterupt
                                      void ledTimersInterrupt() {
                                        if (countRx && countRx != 255) {
                                          // switch led on
                                          digitalWrite(RADIO_RX_LED_PIN, LOW);
                                        } else if (!countRx) {
                                          // switching off
                                          digitalWrite(RADIO_RX_LED_PIN, HIGH);
                                        if (countRx != 255) {
                                          countRx--;
                                        if (countTx && countTx != 255) {
                                          // switch led on
                                          digitalWrite(RADIO_TX_LED_PIN, LOW);
                                        } else if (!countTx) {
                                          // switching off
                                          digitalWrite(RADIO_TX_LED_PIN, HIGH);
                                        if (countTx != 255) {
                                          countTx--;
                                        if (countErr && countErr != 255) {
                                          // switch led on
                                          digitalWrite(RADIO_ERROR_LED_PIN, LOW);
                                        } else if (!countErr) {
                                          // switching off
                                          digitalWrite(RADIO_ERROR_LED_PIN, HIGH);
                                        if (countErr != 255) {
                                          countErr--;
                                      void rxBlink(uint8_t cnt)
                                        if (countRx == 255)
                                          countRx = cnt;
                                      void txBlink(uint8_t cnt)
                                        if (countTx == 255)
                                          countTx = cnt;
                                      void errBlink(uint8_t cnt)
                                        if (countErr == 255)
                                          countErr = cnt;
                                      O 1 Reply Last reply
                                      • T tomkxy
                                        #ifndef MyConfig_h
                                        #define MyConfig_h
                                        #include <stdint.h>
                                        #define DEBUG
                                        // Flash jdecid
                                        //#define SOFTSPI
                                        #ifdef SOFTSPI
                                         To-do:
                                        #include <Time.h>
                                        //#define DSRTC
                                        #ifdef DSRTC
                                        // Hardware profile
                                        MyHwATMega328 hw;
                                        MyMessage msg;
                                        uint8_t buffsize;
                                                    , signer
                                         * setup
                                          countRx = 0;
                                          countTx = 0;
                                          countErr = 0;
                                          //Bridge.begin();
                                          begin();
                                         * loop
                                          client.loop();
                                            rxBlink(1);
                                            sendMQTT(message);
                                         * sendMQTT
                                          buffsize = 0;
                                          if (msg.isAck())
                                        #ifdef DEBUG
                                                txBlink(1);
                                                if (!gw.sendRoute(
                                                  errBlink(1);
                                        #ifdef DEBUG
                                                txBlink(1);
                                                if (!gw.sendRoute(
                                                  errBlink(1);
                                                txBlink(1);
                                                if (!gw.sendRoute(
                                                  errBlink(1);
                                        #ifdef DEBUG
                                                Serial.print(" ");
                                        #ifdef DEBUG
                                                Serial.print(" ");
                                        #ifdef DEBUG
                                                Serial.print(" ");
                                        #ifdef DEBUG
                                              Serial.print(" ");
                                         * build
                                          msg.type = type;
                                          return msg;
                                         * getType
                                          char *q = b;
                                          *q = 0;
                                          return b;
                                         * begin
                                        void begin()
                                        #ifdef DEBUG
                                        #ifdef DSRTC
                                          // Attach RTC
                                          MsTimer2::start();
                                        #ifdef DEBUG
                                          char *str, *p;
                                          uint8_t i = 0;
                                          buffer[0] = 0;
                                          buffsize = 0;
                                          uint8_t cmd = -1;
                                            switch (i)
                                              case 0:
                                              case 1:
                                              case 2:
                                              case 3:
                                                  for (uint8_t j = 0;
                                                      match = j;
                                                    if (j >= VAR_TOTAL)
                                                  msg.type = match;
                                               case 4:
                                                      cmd = C_SET;
                                                      cmd = C_REQ;
                                                    else {
                                        #ifdef DEBUG
                                            i++;
                                          if (cmd != -1) {
                                            char* ca;
                                            ca += length;
                                            *ca = '\0';
                                            txBlink(1);
                                            // inject time
                                        #ifdef DSRTC
                                                setTime(epoch);
                                        #ifdef DEBUG
                                            if (!gw.sendRoute(
                                                        0)))
                                              errBlink(1);
                                        // Led handling
                                            // switch led on
                                            // switching off
                                            countRx--;
                                            // switch led on
                                            // switching off
                                            countTx--;
                                            // switch led on
                                            // switching off
                                            countErr--;
                                          if (countRx == 255)
                                            countRx = cnt;
                                          if (countTx == 255)
                                            countTx = cnt;
                                            countErr = cnt;
                                        O
                                        O
                                        otto001
                                        @tomkxy Thanks, that helped! I seemed to have two problems:
                                        1. I did not know where to place the necessary includes! Thanks for the examples! Helped me a lot
                                        2)Regarding my problems from above (error: 'DEFAULT_CE_PIN' was not declared in this scope): I removed the whole libraries/MySensors dir and copied it again from the recent devel branch - this helped, error is gone and everything is compiling fine now :-)
                                        Thanks again and cheers,
                                        Otto
                                        • O otto001
                                          Otto
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @otto001 Great! And thanks @tomkxy for helping out. MySensors teamwork at it's best. This is what it's all about :D
