  3. Making Code for Weather Station
8 Posts 4 Posters 4.5k Views 2 Watching
  • B
    B
    Brutus
    wrote on last edited by Brutus
    I'm new to the mysensors community and have a question about compiling the needed code.
    I have ordered several parts to make my own Weather Station:
    Serial Gateway:
    • Arduino Nano USB V3.0
    • NRF24L01+ Wireless Tranceiver
    Weather Station:
    • Pro mini Arduino 3.3V
    • BH1750FVI Digital Light Intensity Sensor
    • BMP085 Digital Baromatic Pressure Sensor.
    • DHT22 Digital Temperature and Humidity Sensor
    • Rain Weather Module Detection Sensor
    Later on I would like to add a Wind sensor to make the weather station complete.
    I can see on the forum and website that there are several codes for the sensor. But what to do when you will connect all the sensors together?
    Thnx for the help so far.
    Greetings Brutus.
    SparkmanS 1 Reply Last reply
    • B Brutus
      Serial Gateway:
      Weather Station:
      Greetings Brutus.
      SparkmanS
      SparkmanS
      Sparkman
      @Brutus Hi Brutus, welcome to the forum. You need to take the different sketches and combine them into one sketch. Sometimes this is not straight-forward as certain sketches are designed for the sensor to go to sleep for a period of time, some, like the DHT22, can only send data periodically, etc. If you search the forum, others have posted details about their weather stations, so you can check those first and potentially use their sketches as starting points. If you run into issues with your own sketch once you have developed it, post it here and the board members will jump in and try and help out.
      Al
      • HeinzH
        HeinzH
        Heinz
        wrote on last edited by Heinz
        I have already merged the sketch for a dht-22 and a bmp085 sensor. You can take the sketch as a starting point
        https://github.com/windkh/mysensors/blob/master/WeatherStationSensor/WeatherStationSensor.ino
        Always have look at the memory consumption of your sketch. Merging too many sketches into one will eat up your memory very quickly.
        • sundberg84S
          sundberg84S
          Here is some imspiration from my weather-sensor (without rain though): My outdoor weather sensor
          • HeinzH
            HeinzH
            Heinz
            @sundberg84 nice project. I noticed that the code in your weatherstation makes use of the buggy forecast algorithm. You should update your sketch to have reliable data in future.
            • sundberg84S
              sundberg84S
              THanks. I din but forgot to update the post.
              • B
                B
                Brutus
                Thnx guys for all your answers.
                I will look into the possibilities to merge some sketches.
                @Heinz Most people use less sensors then I will do. U think that it will not fit on the Arduino Nano ?
                Greetings.
                • HeinzH
                  HeinzH
                  Heinz
                  @Brutus
                  Yes, memory on the nano is limited. I already ran out of memory when merging ketches, but fortunately the compiler tells you that at compile time.
