  2. Bug Reports
  3. Repeater nood keeps looping... and doesnt reach gw.
26 Posts 5 Posters 13.4k Views 4 Watching
    wrote on last edited by hek
    So it is messages from the node controlling relays that is problematic? Sound like the classic underpowering problem discussed here on many occasions. Relays should not be powered from the Arduino.
    • sundberg84S
      sundberg84S
      It is not...and the problem isnt from the relay.
      The message keeps looping in the repeater even if the relay is plugged out. The problem is in the repeater (which also is powered from USB and not arduino)
        What does the repeater logs say?
        EDIT: Ok it is the repeater log above.
          @sundberg84 said:
          0-0-103 s=255,c=3,t=6,pt=0,l=1,sg=0:M
          send: 0-100-0-103 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
          Looks like gateway (read from node 0) is sending out multiple values that gets repeated by repeater.
          Weird. Do you have the same type/brand of NRF radio on all nodes/gateway? Could the controller be involved here somehow? Do you have a log from gateway?
          • sundberg84S
            sundberg84S
            Well, on the GW and Repeater i use a radio with long antenna... the other one is same batch normal nrf radio.
            The log from domoticz or gateway is pretty much nothing/no unusual activity... :(
            Atleast there is not multiple send from the GW and i dont see anything in MYSController either.
            Next step is to try to rebuild the repeater to exclude hardware (as the radio...) and also blank new installation of domoticz.
            I'll keep you posted...
            MysLOG
            13 2015-08-14 13:20:45 RX 102 INTERNAL PRESENTATION NO ARDUINO_RELAY 1.5
            14 2015-08-14 13:20:45 RX 102 INTERNAL INTERNAL NO CONFIG 0
            15 2015-08-14 13:20:45 TX 102 INTERNAL INTERNAL NO CONFIG M
            16 2015-08-14 13:20:49 RX 102 INTERNAL INTERNAL NO SKETCH_NAME Relay - 103
            17 2015-08-14 13:20:49 RX 102 INTERNAL INTERNAL NO SKETCH_VERSION 1.5
            18 2015-08-14 13:20:49 RX 102 1 - LIGHT PRESENTATION NO LIGHT
            Domoticz log
            2015-08-14 13:20:50.264 MySensors: Node: 102, Sketch Name: Relay - 103
            2015-08-14 13:20:50.266 MySensors: Node: 102, Sketch Version: 1.5
            • sundberg84S
              sundberg84S
              -Clean domoticz install - only two nodes installed (Relay 103, Repeter 100 and GW) but same error.
              -Changed radio but no effect (and i guess there should not since i have st=ok)
              I notised that it loops also in the GW.
              Logs:
              Repeter (Same as above, loops until a st=fail or another/new info comes in
              GW (Ethernet)
              0;0;3;0;9;read: 100-100-0 s=1,c=1,t=16,pt=0,l=1:1
              100;1;1;0;16;1
              0;0;3;0;9;read: 100-100-0 s=255,c=0,t=18,pt=0,l=3:1.5
              100;255;0;0;18;1.5
              0;0;3;0;9;read: 100-100-0 s=255,c=3,t=6,pt=1,l=1:0
              100;255;3;0;6;0
              100;255;3;0;6;M0;0;3;0;9;send: 0-0-100-100 s=255,c=3,t=6,pt=0,l=1,st=ok:M
              0;0;3;0;9;read: 100-100-0 s=255,c=3,t=11,pt=0,l=15:Repeater+ - 100
              100;255;3;0;11;Repeater+ - 100
              0;0;3;0;9;read: 100-100-0 s=255,c=3,t=12,pt=0,l=3:1.0
              100;255;3;0;12;1.0
              0;0;3;0;9;read: 100-100-0 s=1,c=0,t=1,pt=0,l=0:
              100;1;0;0;1;
              0;0;3;0;9;read: 102-100-0 s=255,c=0,t=18,pt=0,l=3:1.5
              102;255;0;0;18;1.5
              0;0;3;0;9;read: 102-100-0 s=255,c=3,t=6,pt=1,l=1:100
              102;255;3;0;6;100
              102;255;3;0;6;M0;0;3;0;9;send: 0-0-100-102 s=255,c=3,t=6,pt=0,l=1,st=ok:M
              0;0;3;0;9;read: 0-100-102 s=255,c=3,t=6,pt=0,l=1:M
              --keeps looping
              Switch change:
              0;0;3;0;9;read: 0-100-102 s=1,c=1,t=2,pt=2,l=2:0
              0;0;3;0;9;send: 0-0-100-102 s=1,c=1,t=2,pt=2,l=2,st=ok:0
              This affects my relays and my outdoor sensor (all powered with 5 volt usb chargers...) either there was some sort of thunderstorm killing them all at the same time or i dont know what... :( (all volts are within range though)
              Power Issues i guess becuase now i cant read the serial-logs from the relays anymore... just wingdings letters... all i can see there is that it does not loop.
              :boom:
              • U
                U
                uandy
                wrote on last edited by uandy
                I have the same problem:
                  MySensors Debug                 receive raw 0;0;3;0;9;send: 0-0-4-11 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                  MySensors Debug                 receive raw 0;0;3;0;9;read: 0-4-11 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                It happens when the gateway tries to send a new state to a node.
                Also, I have a similar problem sending sketch name and version for some nodes:
                MySensors Debug                 receive raw 0;0;3;0;9;read: 0-4-11 s=255,c=3,t=11,pt=0,l=15,sg=0:Get Sketch Name
                  MySensors Debug                 receive raw 0;0;3;0;9;send: 0-0-4-11 s=255,c=3,t=11,pt=0,l=15,sg=0,st=ok:Get Sket
                  MySensors Debug                 receive raw 0;0;3;0;9;read: 0-4-11 s=255,c=3,t=2,pt=0,l=11,sg=0:Get Version
                  MySensors Debug                 receive raw 0;0;3;0;9;send: 0-0-4-11 s=255,c=3,t=2,pt=0,l=11,sg=0,st=ok:Get Versi
                I use Indigo as a controller, with connected Mysensors serial gateway.
                • barduinoB
                  barduinoB
                  barduino
                  I have the same problem.
                  If someone could try to replicate this:
                  • Default SerialGW (from examples)
                  • Default RepeaterNode (from examples)
                  • Send message from GW to another node (254;4;1;0;2;1)
                  This is what i get
                  Startup GW
                  Startup repeater
                  send: 253-253-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
                  send: 253-253-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                  repeater started, id=253, parent=0, distance=1
                  send: 253-253-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,st=ok:Repeater Node
                  send: 253-253-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                  Gatweway after repeater started
                  0;0;3;0;9;read: 253-253-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  253;255;3;0;6;0
                  0;0;3;0;9;read: 253-253-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Repeater Node
                  253;255;3;0;11;Repeater Node
                  0;0;3;0;9;read: 253-253-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                  253;255;3;0;12;1.0
                  Then I type 254;4;1;0;2;1 on the gatweway serial log and press send
                  I get hundresds of these on the gateway
                  0;0;3;0;9;send: 0-0-253-254 s=4,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                  0;0;3;0;9;read: 0-253-254 s=4,c=1,t=2,pt=0,l=1,sg=0:1
                  and the same on the repeater node
                  read: 0-0-254 s=4,c=1,t=2,pt=0,l=1,sg=0:1
                  send: 0-253-0-254 s=4,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                  There is no controller here, manually assigned ID's.
                  • sundberg84S
                    sundberg84S
                    @barduino I have tried new hardware on repeater and my next thought was to clean GW eeprom and reload scetch.
                    Im just guessing here - but maybe an old route stored in eeprom thats causing problem?
                    Since three people now report this - i guess its inside the code somewhere...
                    Its frustrating - all my sensors not using the repeater works fine... but my networks isnt much of a network without my repeater.
                    • U
                      U
                      uandy
                      I am not sure, but may be it's problem of the new API version 1.5. Early I used 1.4, and all was ok.
                      • sundberg84S
                        sundberg84S
                        Maybe I should try adding some log/debug lines in the lib files... @hek do you have any good start point/specific file that you think i should look in?
                          Strange. Might be something not working as intended in 1.5. We should probably ping @celonunes who did the last couple of changes in the routing here.
                          • U
                            U
                            uandy
                            I have reloaded my repeater node with Mysensors API 1.4.2. And all work fine! Now I use serial gateway (1.5) + repeater node (1.4.2) + sensors (1.5). And it works.
                            • sundberg84S
                              sundberg84S
                              and i can also comfirm @uandy that this is working here as well.
                              Ethernet 1.4, Repeater 1.4.2 and Sensor 1.5
                              So the problem must be in the 1.5 repeater routing.
                                Trying to re-create your setup here.
                                  Seeing the same thing here.
                                  Getting closer.. the repeater seems to pick up "0" incorrectly from its routing table. In your case it should be 103.
                                    Ok, with some help from @celonunes I think we found the problem.
                                    It has been pushed to master.. just one little eeprom write that was missing. ;)
                                    barduinoB 1 Reply Last reply
                                    • sundberg84S
                                      sundberg84S
                                      @hek and @celonunes GREAT job - thank you.
                                      You have saved my homeautomation system :)
                                        barduinoB
                                        barduinoB
                                        barduino
                                        Thanks @hek!
                                        Working fine now
                                        • sundberg84S
                                          sundberg84S
                                          @hek Correct me if im wrong - but can this been a bug from 1.4?
                                          I had 1.4 on another laptop, uploaded the repeaterscetch there... then my last relay (new and 1.5) didnt work (stupid me - i didnt check repeter log though) - bu I changed computer reuploaded the new 1.5 and the new relay worked.
                                          Can be a good to know for people upgrading to 1.5 - if my finding is correct they should upgrade repeaters asap.
