  3. MQTT Client gateway
MQTT Client gateway
91 Posts 33 Posters 66.3k Views 14 Watching
  • TD22057T
    TD22057T
    TD22057
    Does anyone have a version of this reworked for the new 1.5 client? Looking through the MySensor class, it looks like a lot of the code in MyMQTTClient.cpp can be removed as it's now in the sensor class. I'd like to use this for my gateway as it's a much better system than the broker gateway that's in the standard library but it needs to support message signing and the newer 1.5 code base. If someone else finished this already I'll just use that, otherwise I'll start working on it. I have family coming in town so I don't expect to get much done in the next week but assuming that the MQTT code is working fine (I have no experience with that writing an MQTT client), it shouldn't take much work to refactor the client to use the new MySensor base.
    • T
      tomkxy
      I just did an adaptation. I removed the MyMQTTClient.cpp completely. It looks codewise more than the MQTTGateway. I am in the process of testing it.
      You can find it here https://github.com/tomkxy/Arduino.git in the branch MQTTClient.
      • G
        G
        Gambituk
        wrote on last edited by Gambituk
        #45
        @tomkxy Any updates to this? my setup has been running well for a long time, but i am itchy to see if it will survive with 1.5.. i know i should just leave it alone :D but i cannot help but tinker with it.
        • T
          tomkxy
          Well it seems to work. Only point I saw and don't understand is that the gateway tries to send a message back to the sensor which does not seem to be an ACK. See my post here http://forum.mysensors.org/topic/1782/gateway-is-sending-command-1-type-1-c-1-t-1-message-to-sensor but so far no feedback on that. Functional wise it works, at least with my test temp and humidity sensor.
          • R
            R
            ruslan
            Please help! This MQTT client gateway fails to compile. I use 1.6.5. IDE, 1.5 library. Applied patches as suggested by ntruchsess and still get this error:
            MyMQTTClient.cpp: In constructor 'MyMQTTClient::MyMQTTClient(PubSubClient, uint8_t, uint8_t)':
            MyMQTTClient.cpp:108: error: no matching function for call to 'MySensor::MySensor(uint8_t&, uint8_t&)'
                 MySensor(_cepin, _cspin), buffsize(0)
            MyMQTTClient.cpp:108:41: note: candidates are:
            In file included from MyMQTTClient.h:16:0,
                             from MyMQTTClient.cpp:14:
            R:\Arduino\libraries\MySensors/MySensor.h:153:2: note: MySensor::MySensor(MyTransport&, MyHw&)
            R:\Arduino\libraries\MySensors/MySensor.h:153:2: note:   no known conversion for argument 1 from 'uint8_t {aka unsigned char}' to 'MyTransport&'
            R:\Arduino\libraries\MySensors/MySensor.h:144:7: note: MySensor::MySensor(const MySensor&)
             class MySensor
            R:\Arduino\libraries\MySensors/MySensor.h:144:7: note:   candidate expects 1 argument, 2 provided
            MyMQTTClient.cpp: In member function 'void MyMQTTClient::begin(rf24_pa_dbm_e, uint8_t, rf24_datarate_e, uint8_t, uint8_t, uint8_t)':
            MyMQTTClient.cpp:148: error: 'setupRepeaterMode' was not declared in this scope
               setupRepeaterMode();
            MyMQTTClient.cpp:154: error: 'setupRadio' was not declared in this scope
               setupRadio(paLevel, channel, dataRate);
            MyMQTTClient.cpp:155: error: 'BASE_RADIO_ID' was not declared in this scope
               RF24::openReadingPipe(WRITE_PIPE, BASE_RADIO_ID);
            MyMQTTClient.cpp:157: error: cannot call member function 'void RF24::startListening()' without object
               RF24::startListening();
            • T
              tomkxy
              Did you have a look at my repository above? Functional wise it is the same adapted for version 1.5. I have it in use for quite a while now.
              • R
                R
                ruslan
                to tomkhy: your gateway sketch compiles, but Arduino runs out of memory (I use Nano with W5100 ethernet module, SOFTSPI enabled). It does fit with MY_SIGNING_FEATURE and DEBUG disabled, but I need debug - somehow it is not registering with MQTT server. Please tell me how to reduce memory footprint.
                greglG 1 Reply Last reply
                • T
                  tomkxy
                  I am using this sketch with a Mega exactly because of that problem. If you post your MQTTClientGateway sketch I can have a look. If you use Mosquito as MQTT broker you may also post the Mosquito config file.
                  • R
                    R
                    ruslan
                    Many thanks to @tomkhy!
                    I built my MQTT client with his code. No modifications were needed.
                    BTW, Will this or any other code get included into the official MySensors library?
                    • T
                      tomkxy
                      It is now in the Development branch.
                      • A
                        ahhk
                        wrote on last edited by ahhk
                        #53
                        can this run on ESP8266 (as wifi-mqttclient-gateway), too?
                        Greetings
                        Andreas
                        • T
                          tomkxy
                          I don't know, you have to try it. What I can say that with signing support enabled it doesn't fit into the memory of a ProMini. I run it in a Mega.
                          • R ruslan
                            greglG
                            greglG
                            gregl
                            Looks like you have it working now, but just incase, Previously when I have had memory issues , I have upgraded my bootloader to use Optiboot which gives you a little bit more.
                            HTH
                            • A ahhk
                              Greetings
                              Andreas
                              mlava
                              @ahhk
                              Hello all, first post here and a bit new to the mysensors field.
                              I also want to know the answer as to whether this will run on the ESP8266 as hope to run a wifi gateway.
                              Thanks in advance! :)
                              • C
                                C
                                chris021
                                Also keen to run this on an ESP8266 would be a great for bridging.
                                • John ConnollyJ
                                  John ConnollyJ
                                  John Connolly
                                  OK. I've got the gateway to compile and get the following:
                                  Started!
                                  0;0;3;0;9;read: 110-110-0 s=1,c=1,t=0,pt=7,l=5:13.2
                                  0;0;3;0;9;read: 105-105-0 s=0,c=1,t=1,pt=7,l=5:70.0
                                  0;0;3;0;9;read: 110-110-0 s=0,c=1,t=1,pt=7,l=5:58.3
                                  0;0;3;0;9;read: 105-105-0 s=0,c=1,t=1,pt=7,l=5:69.9
                                  0;0;3;0;9;read: 110-110-0 s=0,c=1,t=1,pt=7,l=5:58.2
                                  0;0;3;0;9;read: 105-105-0 s=0,c=1,t=1,pt=7,l=5:69.8
                                  0;0;3;0;9;read: 110-110-0 s=1,c=1,t=0,pt=7,l=5:13.3
                                  0;0;3;0;9;read: 110-110-0 s=0,c=1,t=1,pt=7,l=5:58.5
                                  I can ping the MQTTClinetGateway from another machine and I've confirmed Mosquitto is running OK with a series of pub/subs from other machines/devices and that side of things is working perfectly fine.
                                  I'm not seeing any of the above gateway readings publish to my broker. Thoughts?
                                  Cheers.
                                  • T
                                    tomkxy
                                    Following points to verify and check:
                                    • is the gateway connected to the broker. As far as I remember you can check that by subscribiing to Mosquitto status messages
                                    mosquitto_sub -v -t \$SYS/#
                                    If not check what the authentication method is mosquitto is. If it allows anonymous access make sure that "MQTT_AUTH_REQUIRED" is not defined in the MQTTClientGateway sketch. If username and password are set correctly.
                                    It seems that you are not using signing. So ensure that your MQTTClientGateway is compiled with the signing feature disabled. That are the two points I can imagine now provided that you are sure that you have of course a working ethernet connection.
                                    • John ConnollyJ
                                      John ConnollyJ
                                      John Connolly
                                      I downloaded and installed the development branch and got the MQTTClientGateway running on an UNO with a W5100 shield (that I'm suspicious of, in terms of its reliability). The sketch runs great for a while publishing data to Mosquitto on my Mac Mini, but then stops responding after a while. I'm pretty sure the cause of the problem is the ethernet shield as it bombs out when running other sketches - the webserver one for example.
                                      I have a few of these ENC28J60 boards and I'd like to use one of those instead, but have had some problems.
                                      http://www.aliexpress.com/item/ENC28J60-LAN-Ethernet-Network-Board-Module-for-arduino-25MHZ-Crystal-AVR-51-LPC-STM32-3-3V/1956963721.html
                                      I notice in the MQTTClientGateway sketch that I should just need to comment out the one W5100 Ethernet.h library and substitute with the UIPEthernet.h one, but I tried that and had no joy. Does anyone have a working sketch based on the ENC28J60 that they could post, along with the wiring diagram to connect that board in along with any additional tweaks necessary to get it running on an Uno? Thanks in advance. Cheers.
                                      • siodS
                                        siodS
                                        siod
                                        wrote on last edited by siod
                                        #61
                                        Hi Guys,
                                        I get this:
                                        Started!
                                        0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
                                        0;0;3;0;9;version mismatch
                                        Also the Gateway does not answer to pings. Any suggestions?
                                        edit: after a rebbot I get valid readings in the Serial monitor of the Arduino IDE now:
                                        0;0;3;0;9;read: 20-20-0 s=3,c=1,t=16,pt=2,l=2:1
                                        0;0;3;0;9;read: 20-20-0 s=3,c=1,t=16,pt=2,l=2:0
                                        But still, can´t ping the gw. Double checked IP and Port, seems to be fine.
                                        still learning...
                                        • John ConnollyJ
                                          John ConnollyJ
                                          John Connolly
                                          I've ordered a new W5100 module - this time the red mini W5100 board missing the SD Card slot to see if I have better luck. Still keen to see code for an ENC based MQTTClientGateway though, as this will take a while to arrive... ;)
