  3. Introducing MySensors on nRF24LE1
myscontrollernrf24le1soc
37 Posts 18 Posters 35.1k Views 18 Watching
  • Ivan ZI
    Ivan ZI
    Ivan Z
    What is the current in transmition and idle mode?
    Did you realize sleep?
    tekkaT 1 Reply Last reply
    • tbowmoT
      tbowmoT
      tbowmo
      hmm 8051 instruction set.. Now that's an old mcu then.. Remember them from back in the beginning of the 90's
      Thought they where long forgotten, and dead, now that there are newer (and probably more efficient) mcu cores available.
      Actually, just found my final exam project I made 20 years ago based on an 80535. An EPROM burner, that could program up to 27c512 :) And one had to use UV lamps to erase the chips again (Getting all nostalgic here :))
      • G
        G
        gbfromhb
        This looks very cool. I understand the concept, and I'm more of a software guy then an electronics guy, but I have not done anything like this. Would you be able to provide a step by step or point me to something that could get me from code to getting it onto the chip. Thanks great idea.
        • Ivan ZI Ivan Z
          tekkaT
          tekkaT
          tekka
          You may find the information in the product specs.
          No, not yet.
          • G gbfromhb
            tekkaT
            tekkaT
            tekka
            Since everything is pretty much POC at the moment, no time so far to compile a doc. However, uVision Keil is the official IDE supporting those MCUs (compiler, simulator, flashing, and debugging). You will also find some information (e.g. SDK, open-source programmer, etc.) by simply searching for "nRF24LE1" ...
            More to follow...
            • Z
              Z
              Zeph
              wrote on last edited by Zeph
              Checking aliexpress:
              http://www.aliexpress.com/item/NRF24LE1-NRF24L01-MCU-Wireless-Transceiver-DIP-Wireless-Communication-Module-nE/32230173245.html
              At those sizes and prices, this could be a very interesting option. Looking forward to hearing about your progress.
              • G
                G
                gbfromhb
                wrote on last edited by gbfromhb
                Thank you tekka. I suspect you given me the clues I need.
                • tekkaT tekka
                  First impression of MySensors running on nRF24LE1. Reporting temperature / humidity from DHT22, VCC voltage and millis() timer.
                  This SoC has many interesting features (SPI, 2-Wire, Serial, GPIO, ADC, RNG, AES accelerator, etc. ) and sub uA sleeping modes - without the need to solder a RF module. However, flash size limited to 16kB - still more than enough for many (peripheral) sensors... :)
                  Readings in MYSController:
                  Compiling with SDCC and nRF24LE1 SDK.
                  Source (Proof of concept/POC, non-optimized) here.
                  alexSV
                  @tekkaYou can follow any responses to publish libraries (MyMessage.h MyMessage.cpp, ...) adapt to the SDCC compiler?
                  • A alexSV
                    tekkaT
                    tekkaT
                    tekka
                    For the example above the standard MyMessage.h library was used. All other dependencies can be found in the nRF24LE1 SDK from nordic.
                    A 1 Reply Last reply
                    • tekkaT tekka
                      alexSV
                      wrote on last edited by alexSV
                      @tekka sdсс not support __attribute ((packed)). Or do you use a different compiler?
                      sdcc --model-large --std-sdcc99 -Iinclude -I../SDK/_target_sdcc_nrf24le1_32/include -I../SDK/include -I./aes/include -c src/main.c -o "obj/"
                      include/MyMessage.h:308: syntax error: token -> '(' ; column 18
                      make: *** [obj/main.rel] Ошибка 1
                      (attribute((packed));)
                      and
                      src/main.c:74: syntax error: token -> 'outMsg' ; column 16
                      • A alexSV
                        and
                        tekkaT
                        tekkaT
                        tekka
                        wrote on last edited by tekka
                        @alexSV remove __attribute ((packed)) from the .h file.
                        A DwaltD 2 Replies Last reply
                        • tekkaT tekka
                          alexSV
                          @tekka Thanks - works
                          • tekkaT tekka
                            DwaltD
                            DwaltD
                            Dwalt
                            @tekka Nice project. This would be very useful for small, battery powered, binary sensors. What did you use to program the nRF24LE1?
                            • DwaltD Dwalt
                              tekkaT
                              tekkaT
                              tekka
                              @Dwalt I used this programmer.
                              • J
                                J
                                Justin Decker
                                wrote on last edited by Justin Decker
                                #21
                                I've done a lot of work on this chip. Nothing for this project though.
                                You can take a look here.
                                https://hackaday.io/project/6270-io-node
                                @tekka I released my code under GPL3.
                                • D
                                  demon1977
                                  • D
                                    demon1977
                                    wrote on last edited by demon1977
                                    #23
                                    sdcc --model-large --std-sdcc99-Iinclude -I../nRF24LE1_SDK/_target_sdcc_nrf24le1_32/include -I../nRF24LE1_SDK/
                                    include -L../nRF24LE1_SDK/ -c main.c
                                    Have:
                                    main.c:374: warning 158: overflow in implicit constant conversion
                                    What is this error and how to fix it?
                                    • J
                                      J
                                      jobarjo
                                      Thanks a lot for this, that's exactly what I was looking for.
                                      This is very cheap, small, and low power.
                                      I'm still waiting to receive one to try.
                                      Please note the existance of existing libraries including a wiring library which looks great:
                                      https://hackaday.io/project/5794-nrf24le1-wiring-library
                                      It is written by Justin who just posted above.
                                      There is also a rf24.h there, I don't know if it is compatible with arduino's lib?
                                      It seems you have made your own digitalRead/Write?
                                      I'm still very new to all this.
                                      I will start to setup a dev environment (ubuntu) and try to compile your stuff.
                                      Do you plan something else?
                                      Create a library? Is MySensor only C++? Is there a plan to create a C MySensor library?
                                      Too bad that most MySensor examples are in C++...
                                      Would you like to create a github repo?
                                      J 1 Reply Last reply
                                      • J jobarjo
                                        J
                                        J
                                        Justin Decker
                                        @jobarjo thanks for taking a look. The Wiring library isn't much more than a bunch of macros for the SDK. I chose to do it that way because SDCC will keep unused code in the output it generates. So yes, there is most everything you would expect if you are coming from arduino. digitalRead etc are all there.
                                        There is also a very alpha version of the RF24 library. It is in C of course, so a small amount of porting is needed.
                                        Let me know if you run into any problems. I am busy with another project at the moment with the nrf51822 SoC which is actually similarly priced and much more capable, although much more cumbersome to work with at the moment.
                                        • J
                                          J
                                          jobarjo
                                          @Justin-Decker said:
                                          nrf51822
                                          module costs 6.18 euro on ebay, 32 bit arm 16k sram, 256k flash!!
                                          compatible with nrf24 radio and bluetooth smart.
                                          I'm impressed!
                                          Seems compatible with arm mbed, and there even exists arduino add-on ? (looks like commercial...)
                                          I will look at existence of linux tools, will order one, and see if porting mysensor on this is easy...
