  3. Introducing MySensors on nRF24LE1
myscontrollernrf24le1soc
37 Posts 18 Posters 35.1k Views 18 Watching
  • Z
    Z
    Zeph
    wrote on last edited by Zeph
    Great work indeed!
    However, the source link (at this time) fails...
    tekkaT 1 Reply Last reply
    • Z Zeph
      Great work indeed!
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      @Zeph goo.gl changed the ToS. link updated. thanks
        impressive work. very good idea!
        • Ivan ZI
          Ivan ZI
          Ivan Z
          What is the current in transmition and idle mode?
          Did you realize sleep?
          • tbowmoT
            tbowmoT
            tbowmo
            hmm 8051 instruction set.. Now that's an old mcu then.. Remember them from back in the beginning of the 90's
            Thought they where long forgotten, and dead, now that there are newer (and probably more efficient) mcu cores available.
            Actually, just found my final exam project I made 20 years ago based on an 80535. An EPROM burner, that could program up to 27c512 :) And one had to use UV lamps to erase the chips again (Getting all nostalgic here :))
            • G
              G
              gbfromhb
              This looks very cool. I understand the concept, and I'm more of a software guy then an electronics guy, but I have not done anything like this. Would you be able to provide a step by step or point me to something that could get me from code to getting it onto the chip. Thanks great idea.
              • Ivan ZI Ivan Z
                tekkaT
                tekkaT
                tekka
                You may find the information in the product specs.
                No, not yet.
                • G gbfromhb
                  tekkaT
                  tekkaT
                  tekka
                  Since everything is pretty much POC at the moment, no time so far to compile a doc. However, uVision Keil is the official IDE supporting those MCUs (compiler, simulator, flashing, and debugging). You will also find some information (e.g. SDK, open-source programmer, etc.) by simply searching for "nRF24LE1" ...
                  More to follow...
                  • Z
                    Z
                    Zeph
                    Checking aliexpress:
                    http://www.aliexpress.com/item/NRF24LE1-NRF24L01-MCU-Wireless-Transceiver-DIP-Wireless-Communication-Module-nE/32230173245.html
                    At those sizes and prices, this could be a very interesting option. Looking forward to hearing about your progress.
                    • G
                      G
                      gbfromhb
                      wrote on last edited by gbfromhb
                      Thank you tekka. I suspect you given me the clues I need.
                      • tekkaT tekka
                        First impression of MySensors running on nRF24LE1. Reporting temperature / humidity from DHT22, VCC voltage and millis() timer.
                        This SoC has many interesting features (SPI, 2-Wire, Serial, GPIO, ADC, RNG, AES accelerator, etc. ) and sub uA sleeping modes - without the need to solder a RF module. However, flash size limited to 16kB - still more than enough for many (peripheral) sensors... :)
                        Readings in MYSController:
                        Compiling with SDCC and nRF24LE1 SDK.
                        Source (Proof of concept/POC, non-optimized) here.
                        alexSV
                        @tekkaYou can follow any responses to publish libraries (MyMessage.h MyMessage.cpp, ...) adapt to the SDCC compiler?
                        • A alexSV
                          tekkaT
                          tekkaT
                          tekka
                          For the example above the standard MyMessage.h library was used. All other dependencies can be found in the nRF24LE1 SDK from nordic.
                          A 1 Reply Last reply
                          • tekkaT tekka
                            alexSV
                            wrote on last edited by alexSV
                            @tekka sdсс not support __attribute ((packed)). Or do you use a different compiler?
                            sdcc --model-large --std-sdcc99 -Iinclude -I../SDK/_target_sdcc_nrf24le1_32/include -I../SDK/include -I./aes/include -c src/main.c -o "obj/"
                            include/MyMessage.h:308: syntax error: token -> '(' ; column 18
                            make: *** [obj/main.rel] Ошибка 1
                            (attribute((packed));)
                            and
                            src/main.c:74: syntax error: token -> 'outMsg' ; column 16
                            • A alexSV
                              and
                              tekkaT
                              tekkaT
                              tekka
                              @alexSV remove __attribute ((packed)) from the .h file.
                              A DwaltD 2 Replies Last reply
                              • tekkaT tekka
                                alexSV
                                @tekka Thanks - works
                                • tekkaT tekka
                                  DwaltD
                                  DwaltD
                                  Dwalt
                                  @tekka Nice project. This would be very useful for small, battery powered, binary sensors. What did you use to program the nRF24LE1?
                                  • DwaltD Dwalt
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Dwalt I used this programmer.
                                    • J
                                      J
                                      Justin Decker
                                      wrote on last edited by Justin Decker
                                      #21
                                      I've done a lot of work on this chip. Nothing for this project though.
                                      You can take a look here.
                                      https://hackaday.io/project/6270-io-node
                                      @tekka I released my code under GPL3.
                                      • D
                                        demon1977
                                        • D
                                          demon1977
                                          wrote on last edited by demon1977
                                          #23
                                          sdcc --model-large --std-sdcc99-Iinclude -I../nRF24LE1_SDK/_target_sdcc_nrf24le1_32/include -I../nRF24LE1_SDK/
                                          include -L../nRF24LE1_SDK/ -c main.c
                                          Have:
                                          main.c:374: warning 158: overflow in implicit constant conversion
                                          What is this error and how to fix it?
