change pin 12 assignment
SOFTSPI is a software implementation of the SPI protocol which permits the use of any digital IO for use in the SPI bus.
If you are not using SOFTSPI, you use HW accelerated SPI, and that means you are bound to the specific pins on the MCU that has this capability. You cannot choose which pin to use in this case. -
DigitialIO is included with the MySensors libraries and should not need to be downloaded separately. @hek and @Anticimex, it looks like there are two places to uncomment the #define SOFTSPI line: RF24_config.h and MyConfig.h. Can you confirm where this should be done or does it not matter? @s3bb0 did you delete all of the 1.4 files before copying in the 1.5 ones and then restart the IDE?
Al -
Al -
i tried to change it in MyConfig.h and installed 1.5 and even 1.4 again but still errors....
var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/PinIO.cpp.o: In function
PinIO::begin(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/PinIO.cpp:43: multiple definition ofPinIO::begin(unsigned char)'
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/PinIO.cpp.o:/Users/..../Documents/Arduino/libraries/MySensors/PinIO.cpp:43: first defined here
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/PinIO.cpp.o: In functionPinIO::begin(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/PinIO.cpp:43: multiple definition ofPinIO::PinIO(unsigned char)'
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/PinIO.cpp.o: In functionPinIO::begin(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/PinIO.cpp:43: multiple definition ofPinIO::config(bool, bool)'
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In functionSoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition ofSoftI2cMaster::read(unsigned char)'
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/SoftI2cMaster.cpp.o:/Users/..../Documents/Arduino/libraries/MySensors/SoftI2cMaster.cpp:160: first defined here
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In functionSoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition ofSoftI2cMaster::start()'
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/SoftI2cMaster.cpp.o:/Users/..../Documents/Arduino/libraries/MySensors/SoftI2cMaster.h:136: first defined here
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In functionSoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition ofSoftI2cMaster::stop()'
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In functionSoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition ofSoftI2cMaster::write(unsigned char)'
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In functionSoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition ofI2cMasterBase::transferContinue(void*, unsigned int, unsigned char)'
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In functionSoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition ofI2cMasterBase::transfer(unsigned char, void*, unsigned int, unsigned char)'
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In functionSoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition ofSoftI2cMaster::begin(unsigned char, unsigned char)'
/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In functionSoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition ofSoftI2cMaster::SoftI2cMaster(unsigned char, unsigned char)'
collect2: error: ld returned 1 exit status
Fehler beim Kompilieren. -
You probably need to purge your temp folder as well. The Arduino IDE is stupid and might believe it can re-use old build artifacts. (/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp)
thank you all, but its still the problem.
i deleted everything, even the temporary files.
i installed everything (arduinoIDE + mysensors 1.5). everythin works until i comment the softSPI in.
then it reports: the DigitalIO.h error-.
Arduino: 1.6.5 (Mac OS X), Platine: "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"Verwende die Bibliothek SPI im Ordner: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI
Verwende die Bibliothek MySensors im Ordner: /Users/-------/ArduinoNEW/libraries/MySensors (legacy)/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -Wextra -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10605 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI -I/Users/----/ArduinoNEW/libraries/MySensors /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build8452403048590699508.tmp/LightSensor.cpp -o /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build8452403048590699508.tmp/LightSensor.cpp.o
In file included from /Users/-----/ArduinoNEW/libraries/MySensors/MyTransportNRF24.h:26:0,
from /Users/----/ArduinoNEW/libraries/MySensors/MySensor.h:28,
from LightSensor.ino:30:
/Users/----/ArduinoNEW/libraries/MySensors/utility/RF24.h:20:23: fatal error: DigitalIO.h: No such file or directory
#include <DigitalIO.h>
compilation terminated.
Fehler beim Kompilieren.then i checked /Users/----/ArduinoNEW/libraries/ AND
/Users/----/ArduinoNEW/libraries/DigitalIO/
for the DigitalIO.h ==> IN BOTH EXISTS DigitalIO.h because i copied it for testing.that is so strange ... :(
