  3. a little programming help please.
13 Posts 3 Posters 4.7k Views 1 Watching
    mvader
    thanks for looking at this for me.
    I gave your suggestion a try, i'm still having issues
    char* outlet[]={"0","1111111","2222222","3333333"};
    where S = to one of the elements in the array
    Serial.println(outlet[(S)]); <-- this works
    mySwitch.send(outlet[(S)], 24); <-- this errors
    error: invalid conversion from 'char*' to 'long unsigned int' [-fpermissive]
    why does it print, but not put that same value in the next command?
    I want it to work like this
    myswitch.send (VALUE of the element in the arra,24);
    how do i get that value in there?
    AWIA sowardS 2 Replies Last reply
    • M mvader
      AWIA
      AWIA
      AWI
      @mvader
      You are using a "setter" for a float value (or pointer) see API
      // Setters for payload
      MyMessage& set(void* payload, uint8_t length);
      MyMessage& set(const char* value);
      MyMessage& set(uint8_t value);
      MyMessage& set(float value, uint8_t decimals);
      MyMessage& set(unsigned long value);
      MyMessage& set(long value);
      MyMessage& set(unsigned int value);
      MyMessage& set(int value);
        mvader
        so the value of S is a number it's the sensor ID # that my vera has assigned to my outlets
        when i click "ON" in vera, it will send (if say outlet 3) S will then equal 3
        i then want to send out the code that is assigned to outlet 3
        i was using an array to store them, but i would be fine defining outlet1= outlet2= etc
        either way when i get to the function as the bottom
        i want the code to show outlet(S) S being the outlet, but outlet(S) should = 1111641 and that is what code i want sent out
        i can't seem to figure out how to make that happen
        in a shell script i can just do outlet$S and then that = outlet3 (the value of)
        can you do that in arduino/C ?
        #include <RCSwitch.h>
        #define RF433_CHILD_ID 0
        #define NUMBER_OF_OUTLETS 4
        #define char* outlet[]={"0","1119683","1111641","1114582"};
        RCSwitch mySwitch = RCSwitch();
        mySwitch.enableTransmit(2);
        gw.sendSketchInfo("RF433C", "1.0");
        for(int i=0; i<NUMBER_OF_OUTLETS;i++)
        gw.present(i+1, S_LIGHT);
        void incomingMessage(const MyMessage &message)
          if (message.type==V_LIGHT) {
          int incomingLightState =  message.getBool();
          int S = message.sensor;
         if (incomingLightState==1)
        • M mvader
          sowardS
          sowardS
          soward
          Maybe you could post your entire sketch here?
          • sowardS soward
            mvader
            that is my entire sketch (above your post) lol
            i have not been able to get any further
            AWIA 1 Reply Last reply
            • M mvader
              AWIA
              AWIA
              AWI
              @mvader
              I don't know what you are trying to accomplish but RCSwtich.send expects either a character array (= implicit pointer) or an "unsigned long" Code with a length value. I does not have anything to do with MySensors. It is probably easier for you to browse through the RCSwitch examples before combining it with the MySensors API (which has similar characteristics..
              Below the RCSwitch definitions.
              void send(unsigned long Code, unsigned int length);
              void send(char* Code);
                mvader
                wrote on last edited by mvader
                @AWI
                i'm confused why you say it doesn't have anything to do with mysensors.
                i have a working sketch that controls 433 outlets on my - mysensors network
                the issue i have is i'm trying to shorten the sketch.
                the way it is written now, it defines an on and off code for each outlet
                if you have many outlets that's allot of "IF" statements.
                in the shell script world i could easily shorten that by using a variable and for loop.
                as admitted i'm a scripter and know little about c/arduino programming
                here is a modified working sketch
                /*  RF433Mhz Transmitter node:
                    This sketch allows On-Off-Keying (OOK) control of four 433Mhz relay outlets
                    which utilize the common PT2262 encoding chip for signal transmission. The sketch could
                    be easily expanded to include additional outlets.  The sensor node consists of a nano
                    connected to a NRF24L01 and a 433Mhz transmitter connected to pin 3, 5V and Gnd.  The
                    transmitter can run off of 3.3V as well.
                    The sketch is based on the MySensors project (http://www.mysensors.org).
                    Submitted by Dwalt.
                //  Include related libraries
                //  Define Constants
                #define NUMBER_OF_OUTLETS 4 // Each outlet will have 2 OOK codes
                //#define SEND_DATA 2
                #define CODE_1On 1119683
                #define CODE_1Off 1119692
                #define CODE_2On 6287580
                #define CODE_2Off 6287572
                #define CODE_3On 6287578
                #define CODE_3Off 6287570
                #define CODE_4On 6287577
                #define CODE_4Off 6287569
                 Serial.begin(115200); // Not sure why this was included
                 //  The node is mains powered, so why not make it a repeater.
                 // Send the sketch version information to gateway
                 gw.sendSketchInfo("RF433", "1.1");
                 // Register outlets to gw (they will be created as child devices)
                 for(int i=0; i<NUMBER_OF_OUTLETS;i++) {
                  int incomingOutlet = message.sensor;
                  Serial.print("Outlet #: ");
                  Serial.print("Command: ");
                 if (incomingOutlet==1) {
                 if (incomingLightState==1) {
                    // Turn on  socket 1
                    Serial.println("Turn on Socket 1");
                 mySwitch.send(CODE_1On, 24); // These codes are unique to each outlet
                 delay(50);
                 if (incomingLightState==0)  {
                    // Turn off socket 1
                 Serial.println("Turn off Socket 1");
                mySwitch.send(CODE_1Off, 24);
                delay(50);
                 if (incomingOutlet==2) {
                    // Turn on  socket 2
                    Serial.println("Turn on Socket 2");
                mySwitch.send(CODE_2On, 24);
                 delay(50);
                    // Turn off socket 2
                 Serial.println("Turn off Socket 2");
                mySwitch.send(CODE_2Off, 24);
                delay(50);
                 if (incomingOutlet==3) {
                    // Turn on  socket 3
                    Serial.println("Turn on Socket 3");
                mySwitch.send(CODE_3On, 24);
                 delay(50);
                    // Turn off socket 3
                 Serial.println("Turn off Socket 3");
                mySwitch.send(CODE_3Off, 24);
                delay(50);
                 if (incomingOutlet==4) {
                    // Turn on  socket 4
                    Serial.println("Turn on Socket 4");
                 mySwitch.send(CODE_4On, 24);
                 delay(50);
                    // Turn off socket 4
                 Serial.println("Turn off Socket 4");
                mySwitch.send(CODE_4Off, 24);
                delay(50);
                 delay(50);
                • M mvader
                  @AWI
                      Submitted by Dwalt.
                  //  Define Constants
                      // Turn on  socket 1
                   delay(50);
                  delay(50);
                      // Turn on  socket 2
                   delay(50);
                  delay(50);
                      // Turn on  socket 3
                   delay(50);
                  delay(50);
                      // Turn on  socket 4
                   delay(50);
                  delay(50);
                   delay(50);
                  AWIA
                  AWIA
                  AWI
                  wrote on last edited by AWI
                  @mvader If you look at the similar statement in this sketch:
                  (better written as:)
                  const int CODE_1On = 1119683   // define integer with value
                  CODE_10n is an Integer "type"
                  In the other sketch you are using "outlet[(S)]" which is a char array (or pointer) type.
                  const char outlet[] = {"0","1119683","1111641","1114582"};   // define an array with character arrays
                  While the mySwitch.send( .. ) either wants a character array ("ABCDEF12121") or an integer with length (12234, 24)
                  C++ does not automatically convert types...
                    mvader
                    I must still be missing something.
                    appreciate the correction on the declared part.
                    however, i still don't know how to make outlet(S) (where S is the outlet number)
                    work.
                    i constantly get a "outlet" is not defined.. etc
                    outlet is not specifically defined, but i'm not trying to send just "outlet"
                    i'm trying to send the value of outlet3
                    the variable S is supposed to represent the 3 (or whatever other outlet # is sent back by vera)
                    this allows me to use 1 piece of code, instead of saying
                    if outlet 1
                    if outlet 2
                    if outlet 3
                    etc
                    i can just say outlet(S)
                    but that' isn't working. why? not possible or not coded correctly?
                    • M mvader
                      work.
                      if outlet 1
                      if outlet 2
                      if outlet 3
                      etc
                      AWIA
                      AWIA
                      AWI
                      @mvader sorry for confusing you.. try this:
                      const unsigned long outlet[]= {0,1119683,1111641,1114582};
                      i.s.o.
                        mvader
                        I think that may have done the trick.. i'll follow up in a bit
                        thanks!
