  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
  • A aproxx
    @jemish I've made some minor changes to the board (nothing functional has been changed, just some updated silk screen and modified the 90 degree angles to 45 degree angles.)
    Please be aware that at this moment the board still isn't confirmed to be working. If you want to be 100% sure everything works properly, I strongly advise to wait for another 5-7 weeks. That way I can assemble the board myself and confirm everything is working as expected.
    J
    J
    jemish
    @aproxx so now, what is the progress??
    we will wait for your response.
    • A
      aproxx
      @jemish
      All components are at my desk at the moment. The only thing missing is.. The PCB itself. :)
      DirtyPCBs' website states that the board was shipped to me at August 24. My packets from China usually arrive about 2 or 3 weeks after they have been sent from China, so I expect it to arrive somewhere next week.
      After the boards have arrived I'll make sure to have it assembled in less than a week. :)
      J 1 Reply Last reply
      • A aproxx
        @jemish
        J
        J
        jemish
        @aproxx please upload new design new that you make now.
        • A
          aproxx
          @jemish : The design which I've posted 2 weeks ago (A few posts above this one) is the latest design I have.
          • J
            J
            jemish
            but, you said that you want to change something like 45 degree or 90 degree, so that ....
            • A
              aproxx
              @jemish : Yes, but that's already included in the design which I posted above.
              J 2 Replies Last reply
              • A aproxx
                J
                J
                jemish
                @aproxx can you make design for 2- relay board....
                • A aproxx
                  J
                  J
                  jemish
                  @aproxx so, now what is the progress....we are waiting your response.....
                  • A
                    aproxx
                    I received the newly designed PCB last weekend, and have been soldering/testing the board since it arrived. Just a few minor changes to the layout (not the schematic) and the board should be completely finished! So far the results look promising.
                    @jemish: I'm currently re-working the design a bit and working on documentation, but I'll make sure to post the new and completely finished design by the end of the week!
                    • A
                      aproxx
                      wrote on last edited by aproxx
                      #66
                      As promised, I've got an update for this project. The board has been tested in the past week, and everything is working as expected. Compared to the previous board I've posted, I have updated the following:
                      • Solder pads of LE33CZ have been placed a little wider apart to avoid short circuit while soldering.
                      • Solder pads of the resettable fuse (Fuse2) has been placed closer together to better fit the fuses of the BOM.
                      • Moved the NRF24L01 connector a bit away from the solid state relay. Should make it easier to solder.
                      • Moved Fuse2 to another location on the board, away from the 230v circuit.
                      Some 3D pictures (Top and bottom):
                      Anyone who is interested can order the PCB HERE
                      Some documentation, and all gerber / DipTrace files (in case you would like to make some modifications) can be found here: MySensors board v3.2.3.zip.
                      YveauxY AWIA S 3 Replies Last reply
                        shabba
                        I just ordered 20. Can't think what I will need them all for but better to be looking at them than looking for them :-)
                        Great work! Thanks!
                        • A aproxx
                          @aproxx I guess you use a different Arduino Pro Mini as the one in the 3D view, because its row of pins pointing towards us seems to get awfully close to the mains coming from "Power in", right?
                          DrJeffD A 2 Replies Last reply
                          • YveauxY Yveaux
                            DrJeffD
                            DrJeffD
                            DrJeff
                            @Yveaux
                            I believe those are for the serial connection that usually are pointing up, or back for programing? It looks like they are just rendered as down in the 3D image? But I am curious how the clearance for the components on the other side (HLK) is when they are soldered, does it need some space off the board?
                            • A aproxx
                              AWIA
                              AWIA
                              AWI
                              @aproxx Could you share some photo's of the mounted board to get some feel or the 'real' thing? thanks
                              • YveauxY Yveaux
                                aproxx
                                @Yveaux: I'm using the standard Arduino Nano, but I agree that the 3D view looks a bit worrying. In real life it isn't needed to solder this row of pins to the Arduino, so it should be safe. So the assumption of @DrJeff is correct!
                                The only reason why these pins look connected to the board is because I couldn't find a 3D design of the Arduino nano without these 6 pins soldered. :)
                                But thanks for pointing this out, I'll add it to the documentation to make sure people aren't getting confused.
                                @AWI: I'll try and see if I can take some decent pictures when I get home (in approximately 12 hours) and post them up here!
                                • A
                                  aproxx
                                  For those who wanted to see some pictures of the board:
                                  IMG_20150921_194059 (Small).jpg IMG_20150921_194039 (Small).jpg IMG_20150921_194035 (Small).jpg IMG_20150921_194023 (Small).jpg IMG_20150921_192748 (Small).jpg IMG_20150921_192737 (Small).jpg IMG_20150921_192728 (Small).jpg
                                  Small notice: These pictures are of a slightly older design. The newer design has a few minor changes like better component placement and a permanent fuse instead of this resettable fuse. But these pictures should at least give you an idea on how everything looks like, and shows how really small it actually is.
                                  Also, I reinforced the traces of the 230v lines, which I absolutely recommend to do! (Although I do recommend to do it slightly more professional than I did on this prototype :))
                                  AWIA Z the cosmic gateT 3 Replies Last reply
                                    mvdarend
                                    Very nice. :thumbsup: I ordered 10 boards on Saturday, can't wait for them to arrive.
                                    • A aproxx
                                      AWIA
                                      AWIA
                                      AWI
                                      @aproxx Looks cleaner than the 3D view :clap:
                                      A 1 Reply Last reply
                                      • AWIA AWI
                                        aproxx
                                        @AWI Thanks for the kind words! I did my best on the soldering part, but the reinforcement of the 230v circuit could have done a bit better in my opinion. :) Next time I would use an isolated wire to reinforce the 230v traces, but for a prototype build this was sufficient.
                                        • J
                                          J
                                          jemish
                                          nice job....very nice....
