  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.5k Views 30 Watching
  • T
    tomkxy
    Well , could be... I had to use different wires female - female, male - female, male - male (for config 3). For the male-male wire I have no other option at the moment.
    However, I am glad it works now.
    AnticimexA 1 Reply Last reply
    • T tomkxy
      AnticimexA
      AnticimexA
      Anticimex
      Good news! Regarding breadboard issues, it could be that you need an additional decoupling on the VCC line to the atsha204a. And also perhaps a pullup on the SDA signal. Breadboards usually put some more requirements on noise suppression.
      • O
        O
        otto001
        I seem to be too stupid (or drunk ;-) ) to get this working with MySigningAtsha204Soft :-(
        Is anyone willing to provide a working MyConfig.h and EthernetGateway.ino for this?
        There seemed to be some changes and I am sure, I am just too dumb... :-(
        • T
          tomkxy
          Here you go....However, I do not have EthernetGateway but a MQTTClientGateway. May be it is of help.
          What is your specific problem?
          myconfig.h (key changed)
          #ifndef MyConfig_h
          #define MyConfig_h
          #include <stdint.h>
          #define DEBUG
          #define BAUD_RATE 115200
          #define MY_OTA_FLASH_SS 8
          // Flash jdecid
          *  Information LEDs blinking
          // disabled in the gateway.
          //#define WITH_LEDS_BLINKING
          // off when blinking
          // The RX LED default pin
          #define DEFAULT_RX_LED_PIN 6
          // The TX LED default pin
          #define DEFAULT_TX_LED_PIN 5
          // The Error LED default pin
          #define DEFAULT_ERR_LED_PIN 4
          *  Message Signing Settings
          #define MY_SIGNING_FEATURE
          #define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
          #define MY_HMAC_KEY 0x10,0x23,0xBB,0x78,0x77,0x35,0xB0,0x01,0x70,0x47,0xF1,0xDE,0x21,0x94,0x54,0x67,0xEE,0x36,0x72,0x00,0x97,0x12,0xA0,0x0A,0x0F,0x09,0x03,0xE2,0x00,0x31,0xE4,0x41
          *  NRF24L01 Driver Defaults
          #define RF24_CE_PIN		   9
          #define RF24_CS_PIN		   10
          #define RF24_CHANNEL	   76
          //#define SOFTSPI
          #ifdef SOFTSPI
          *  RFM69 Driver Defaults
          /* 				MyMQTT Client Gateway 0.1b
           Created by Norbert Truchsess <norbert.truchsess@t-online.de>
           Based on MyMQTT-broker gateway created by Daniel Wiegert <daniel.wiegert@gmail.com>
           Based on MySensors Ethernet Gateway by Henrik Ekblad <henrik.ekblad@gmail.com>
           http://www.mysensors.org
           Requires MySensors lib 1.4b
           * Change below; TCP_IP, TCP_PORT, TCP_MAC
           This will listen on your selected TCP_IP:TCP_PORT below, Please change TCP_MAC your liking also.
           *1 -> NOTE: Keep first byte at x2, x6, xA or xE (replace x with any hex value) for using Local Ranges.
           *2 You can use standard pin set-up as MySensors recommends or if you own a IBOARD you may change
           the radio-pins below if you hardware mod your iBoard. see [URL BELOW] for more details.
           http://forum.mysensors.org/topic/224/iboard-cheap-single-board-ethernet-arduino-with-radio/5
           * Don't forget to look at the definitions in libraries\MySensors\MyMQTT.h!
           define TCPDUMP and connect serial interface if you have problems, please write on
           http://forum.mysensors.org/ and explain your problem, include serial output. Don't forget to
           turn on DEBUG in libraries\MySensors\MyConfig.h also.
           MQTT_FIRST_SENSORID is for 'DHCP' server in MyMQTT. You may limit the ID's with FIRST and LAST definition.
           If you want your manually configured below 20 set MQTT_FIRST_SENSORID to 20.
           To disable: set MQTT_FIRST_SENSORID to 255.
           MQTT_BROKER_PREFIX is the leading prefix for your nodes. This can be only one char if like.
           MQTT_SEND_SUBSCRIPTION is if you want the MyMQTT to send a empty payload message to your nodes.
           This can be useful if you want to send latest state back to the MQTT client. Just check if incoming
           message has any length or not.
           Example: if (msg.type==V_LIGHT && strlen(msg.getString())>0) otherwise the code might do strange things.
           * Address-layout is : [MQTT_BROKER_PREFIX]/[NodeID]/[SensorID]/V_[SensorType]
           NodeID and SensorID is uint8 (0-255) number.
           Last segment is translation of the sensor type, look inside MyMQTT.cpp for the definitions.
           User can change this to their needs. We have also left some space for custom types.
           Special: (sensor 255 reserved for special commands)
           You can receive a node sketch name with MyMQTT/20/255/V_Sketch_name (or version with _version)
           To-do:
           Special commands : clear or set EEPROM Values, Send REBOOT and Receive reboot for MyMQTT itself.
           Be able to send ACK so client returns the data being sent.
           ... Please come with ideas!
           What to do with publish messages.
           Test in more MQTT clients, So far tested in openhab and MyMQTT for Android (Not my creation)
           - http://www.openhab.org/
           - https://play.google.com/store/apps/details?id=at.tripwire.mqtt.client&hl=en
           ... Please notify me if you use this broker with other software.
           * How to set-up Openhab and MQTTGateway:
           http://forum.mysensors.org/topic/303/mqtt-broker-gateway
           Changes by Thomas Krebs <thkrebs@gmx.de>
           - Add signing support from MySensors 1.5 and update for MySensors 1.5;
           - Restructured code back to a C like implementation following the existing MQTTGateway
          #include "MyMQTTClient.h"
          #include "PubSubClient.h"
          #include <Ethernet.h>
          #include <DigitalIO.h>
          #include <MsTimer2.h>
          #include <Time.h>
          #ifdef MY_SIGNING_FEATURE
          #include <MySigningNone.h>
          //#define DSRTC
          #ifdef DSRTC
          #include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
           * To configure MQTTClientGateway.ino to use an ENC28J60 based board include
           * 'UIPEthernet.h' (SPI.h required for MySensors anyway). The UIPEthernet-library can be downloaded
          //#include <UIPEthernet.h>
           * To execute MQTTClientGateway.ino on Yun uncomment Bridge.h and YunClient.h.
           * Do not include Ethernet.h or SPI.h in this case.
           * On Yun there's no need to configure local_ip and mac in the sketch
           * as this is configured on the linux-side of Yun.
          //#include <Bridge.h>
          //#include <YunClient.h>
          // * Use this for IBOARD modded to use standard MISO/MOSI/SCK, see note *1 above!
           #define RADIO_CE_PIN        3			// radio chip enable
           #define RADIO_SPI_SS_PIN    8			// radio SPI serial select
           #define RADIO_ERROR_LED_PIN A2  		// Error led pin
           #define RADIO_RX_LED_PIN    A1  		// Receive led pin
           #define RADIO_TX_LED_PIN    A0  		// the PCB, on board LED*/
          // * Use this for default configured pro mini / nano etc :
          //#define RADIO_CE_PIN        5		// radio chip enable
          //#define RADIO_SPI_SS_PIN    6		// radio SPI serial select
          //#define RADIO_ERROR_LED_PIN 7		// Error led pin
          //#define RADIO_RX_LED_PIN    8		// Receive led pin
          //#define RADIO_TX_LED_PIN    9		// the PCB, on board LED*/
          // CE_PIN and SPI_SS_PIN for Mega
          #define RADIO_CE_PIN        48			// radio chip enable
          #define RADIO_SPI_SS_PIN    49			// radio SPI serial select
          //replace with ip of server you want to connect to, comment out if using 'remote_host'
          uint8_t remote_ip[] =  { 192, 168, 178, 74 };  // Mosquitto broker
          //replace with hostname of server you want to connect to, comment out if using 'remote_ip'
          //char* remote_ip = "server.local";
          //replace with the port that your server is listening on
          #define remote_port 1883
          //replace with arduinos ip-address. Comment out if Ethernet-startup should use dhcp. Is ignored on Yun
          uint8_t local_ip[] = {192, 168, 178, 11};
          //replace with ethernet shield mac. It's mandatory every device is assigned a unique mac. Is ignored on Yun
          uint8_t mac[] = { 0xA2, 0xAE, 0xAD, 0xA0, 0xA0, 0xA2 };
          #if defined remote_ip && defined remote_host
          #error "cannot define both remote_ip and remote_host at the same time!"
          #ifdef _YUN_CLIENT_H_
          YunClient ethClient;
          EthernetClient ethClient;
          //MyTransportRFM69 transport;
          //MySigningNone signer;
          MySigningAtsha204Soft signer;
          //MySigningAtsha204 signer;
          // Hardware profile
          MyHwATMega328 hw;
          MyMessage msg;
          char convBuf[MAX_PAYLOAD * 2 + 1];
          uint8_t buffsize;
          char buffer[MQTT_MAX_PACKET_SIZE];
          volatile uint8_t countRx;
          volatile uint8_t countTx;
          volatile uint8_t countErr;
          void processMQTTMessages(char* topic, byte* payload, unsigned int length);
          PubSubClient client(remote_ip, remote_port, processMQTTMessages, ethClient);
          // Declare and initialize MySensor instance
          // Construct MyMQTTClient (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h, if signing
          // feature not to be used, uncomment)
          MySensor gw(transport, hw
                      , signer
          #ifdef WITH_LEDS_BLINKING
                      , RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN
           * setup
            countRx = 0;
            countTx = 0;
            countErr = 0;
            Ethernet.begin(mac, local_ip);
            //Bridge.begin();
            delay(1000);   // Wait for Ethernet to get configured.
            begin();
           * loop
            if (!client.connected())
              client.connect("MySensor");
              client.subscribe(MQTT_TOPIC_MASK);
            client.loop();
           * processRadioMessage
           * Receives radio message, parses it and forwards it to the MQTT broker
          void processRadioMessage(const MyMessage &message)
              rxBlink(1);
              sendMQTT(message);
           * sendMQTT
           * Handles processing of radio messages and eventually publishes it to the MQTT broker
          void sendMQTT(const MyMessage &inMsg)
            MyMessage msg = inMsg;
            buffsize = 0;
              return;			//We have no connections - return
            if (msg.isAck())
          #ifdef DEBUG
              Serial.println("msg is ack!");
              if (msg.sender == 255 && mGetCommand(msg) == C_INTERNAL
                  && msg.type == I_ID_REQUEST)
                // TODO: sending ACK request on id_response fucks node up. doesn't work.
                // The idea was to confirm id and save to EEPROM_LATEST_NODE_ADDRESS.
              // we have to check every message if its a newly assigned id or not.
              // Ack on I_ID_RESPONSE does not work, and checking on C_PRESENTATION isn't reliable.
              uint8_t newNodeID = gw.loadState(EEPROM_LATEST_NODE_ADDRESS) + 1;
              if (newNodeID <= MQTT_FIRST_SENSORID)
                newNodeID = MQTT_FIRST_SENSORID;
              if (msg.sender == newNodeID)
                gw.saveState(EEPROM_LATEST_NODE_ADDRESS, newNodeID);
              if (mGetCommand(msg) == C_INTERNAL)
                if (msg.type == I_CONFIG)
                  txBlink(1);
                  if (!gw.sendRoute(
                        build(msg, GATEWAY_ADDRESS, msg.sender, 255, C_INTERNAL,
                              I_CONFIG, 0).set("M")))
                    errBlink(1);
                else if (msg.type == I_TIME)
          #ifdef DEBUG
                  Serial.println("I_TIME requested!");
                  txBlink(1);
                  if (!gw.sendRoute(
                              I_TIME, 0).set(now())))
                    errBlink(1);
                else if (msg.type == I_ID_REQUEST && msg.sender == 255)
                  if (newNodeID >= MQTT_LAST_SENSORID)
                    return; // Sorry no more id's left :(
                  txBlink(1);
                  if (!gw.sendRoute(
                              I_ID_RESPONSE, 0).set(newNodeID)))
                    errBlink(1);
                else if (msg.type == I_BATTERY_LEVEL)
                  strcpy_P(buffer, mqtt_prefix);
                  buffsize += strlen_P(mqtt_prefix);
                  buffsize += sprintf(&buffer[buffsize], "/%i/255/BATTERY_LEVEL\0", msg.sender );
                  msg.getString(convBuf);
          #ifdef DEBUG
                  Serial.print("publish: ");
                  Serial.print((char*) buffer);
                  Serial.print(" ");
                  Serial.println((char*) convBuf);
                  client.publish(buffer, convBuf);
                else if (msg.type == I_SKETCH_NAME)
                  buffsize += sprintf(&buffer[buffsize], "/%i/255/SKETCH_NAME\0", msg.sender );
          #ifdef DEBUG
                  Serial.print(" ");
                else if (msg.type == I_SKETCH_VERSION)
                  buffsize += sprintf(&buffer[buffsize], "/%i/255/SKETCH_VERSION\0", msg.sender );
          #ifdef DEBUG
                  Serial.print(" ");
              else if (mGetCommand(msg) != 0)
                if (mGetCommand(msg) == 3)
                  msg.type = msg.type + (S_FIRSTCUSTOM - 10);	//Special message
                if (msg.type > VAR_TOTAL)
                  msg.type = VAR_TOTAL;		// If type > defined types set to unknown.
                buffsize += sprintf(&buffer[buffsize], "/%i/%i/V_%s\0", msg.sender,
                                    msg.sensor, getType(convBuf, &VAR_Type[msg.type]));
          #ifdef DEBUG
                Serial.print(" ");
           * build
           * Constructs a radio message
          inline MyMessage& build(MyMessage &msg, uint8_t sender, uint8_t destination, uint8_t sensor,
                                  uint8_t command, uint8_t type, bool enableAck)
            msg.destination = destination;
            msg.sender = sender;
            msg.sensor = sensor;
            msg.type = type;
            mSetCommand(msg, command);
            mSetRequestAck(msg, enableAck);
            mSetAck(msg, false);
            return msg;
           * getType
          char *getType(char *b, const char **index)
            char *q = b;
            char *p = (char *) pgm_read_word(index);
            while (*q++ = pgm_read_byte(p++))
            *q = 0;
            return b;
           * begin
           * wraps MySensors begin method; setup of RTC and led timers interrupt
          void begin()
          #ifdef DEBUG
            Serial.begin(BAUD_RATE);
          #ifdef DSRTC
            // Attach RTC
            setSyncProvider(RTC.get);   // the function to get the time from the RTC
            setSyncInterval(60);
            gw.begin(processRadioMessage, 0, true, 0);
            MsTimer2::set(200, ledTimersInterrupt);
            MsTimer2::start();
          #ifdef DEBUG
            Serial.print(getType(convBuf, &VAR_Type[S_FIRSTCUSTOM]));
           * processMQTTMessages
           * message handler for the PubSubClient
            processMQTTMessage(topic, payload, length);
           * processes MQTT messages, parses the topic, extracts radio address out of topic and sends them
           * to the respective radio
          void processMQTTMessage(char* topic, byte* payload,
            char *str, *p;
            uint8_t i = 0;
            buffer[0] = 0;
            buffsize = 0;
            uint8_t cmd = -1;
                 str = strtok_r(NULL, "/", &p))
              switch (i)
                case 0:
                    if (strcmp_P(str, mqtt_prefix) != 0)
                    { //look for MQTT_PREFIX
                      return;			//Message not for us or malformatted!
                case 1:
                    msg.destination = atoi(str);	//NodeID
                case 2:
                    msg.sensor = atoi(str);		//SensorID
                case 3:
                    char match = 0;			//SensorType
                    //strcpy(str,(char*)&str[2]);  //Strip VAR_
                    for (uint8_t j = 0;
                         strcpy_P(convBuf, (char*) pgm_read_word(&(VAR_Type[j]))); j++)
                      if (strcmp((char*) &str[2], convBuf) == 0)
                      { //Strip VAR_ and compare
                        match = j;
                      if (j >= VAR_TOTAL)
                      { // No match found!
                        match = VAR_TOTAL;	// last item.
                    msg.type = match;
                 case 4:
                      // support the command get and set; get will be mapped to a C_REQ and set to C_SET
                      if (strcmp(str,MQTT_CMD_SET) == 0)
                        cmd = C_SET;
                      else if (strcmp(str,MQTT_CMD_GET) == 0) {
                        cmd = C_REQ;
                      else {
          #ifdef DEBUG
                        Serial.print("Received unsupported command - ignore: ");
                        Serial.println(str);
              i++;
            }						//Check if packge has payload
            if (cmd != -1) {
              char* ca;
              ca = (char *)payload;
              ca += length;
              *ca = '\0';
              msg.set((const char*)payload);			//Payload
              txBlink(1);
              // inject time
              if ((msg.destination == 0) && (msg.sensor == 199)) {
                unsigned long epoch = atol((char*)payload);
                if (epoch > 10000) {
          #ifdef DSRTC
                  RTC.set(epoch); // this sets the RTC to the time from controller - which we do want periodically
                  setTime(epoch);
          #ifdef DEBUG
                Serial.print("Time recieved ");
                Serial.println(epoch);
              if (!gw.sendRoute(
                    build(msg, GATEWAY_ADDRESS, msg.destination, msg.sensor, C_SET, msg.type,
                          0)))
                errBlink(1);
          // Led handling
           * ledTimersIntterupt
          void ledTimersInterrupt() {
            if (countRx && countRx != 255) {
              // switch led on
              digitalWrite(RADIO_RX_LED_PIN, LOW);
            } else if (!countRx) {
              // switching off
              digitalWrite(RADIO_RX_LED_PIN, HIGH);
            if (countRx != 255) {
              countRx--;
            if (countTx && countTx != 255) {
              // switch led on
              digitalWrite(RADIO_TX_LED_PIN, LOW);
            } else if (!countTx) {
              // switching off
              digitalWrite(RADIO_TX_LED_PIN, HIGH);
            if (countTx != 255) {
              countTx--;
            if (countErr && countErr != 255) {
              // switch led on
              digitalWrite(RADIO_ERROR_LED_PIN, LOW);
            } else if (!countErr) {
              // switching off
              digitalWrite(RADIO_ERROR_LED_PIN, HIGH);
            if (countErr != 255) {
              countErr--;
          void rxBlink(uint8_t cnt)
            if (countRx == 255)
              countRx = cnt;
          void txBlink(uint8_t cnt)
            if (countTx == 255)
              countTx = cnt;
          void errBlink(uint8_t cnt)
            if (countErr == 255)
              countErr = cnt;
          O 1 Reply Last reply
          • T tomkxy
            #ifndef MyConfig_h
            #define MyConfig_h
            #include <stdint.h>
            #define DEBUG
            // Flash jdecid
            //#define SOFTSPI
            #ifdef SOFTSPI
             To-do:
            #include <Time.h>
            //#define DSRTC
            #ifdef DSRTC
            // Hardware profile
            MyHwATMega328 hw;
            MyMessage msg;
            uint8_t buffsize;
                        , signer
             * setup
              countRx = 0;
              countTx = 0;
              countErr = 0;
              //Bridge.begin();
              begin();
             * loop
              client.loop();
                rxBlink(1);
                sendMQTT(message);
             * sendMQTT
              buffsize = 0;
              if (msg.isAck())
            #ifdef DEBUG
                    txBlink(1);
                    if (!gw.sendRoute(
                      errBlink(1);
            #ifdef DEBUG
                    txBlink(1);
                    if (!gw.sendRoute(
                      errBlink(1);
                    txBlink(1);
                    if (!gw.sendRoute(
                      errBlink(1);
            #ifdef DEBUG
                    Serial.print(" ");
            #ifdef DEBUG
                    Serial.print(" ");
            #ifdef DEBUG
                    Serial.print(" ");
            #ifdef DEBUG
                  Serial.print(" ");
             * build
              msg.type = type;
              return msg;
             * getType
              char *q = b;
              *q = 0;
              return b;
             * begin
            void begin()
            #ifdef DEBUG
            #ifdef DSRTC
              // Attach RTC
              MsTimer2::start();
            #ifdef DEBUG
              char *str, *p;
              uint8_t i = 0;
              buffer[0] = 0;
              buffsize = 0;
              uint8_t cmd = -1;
                switch (i)
                  case 0:
                  case 1:
                  case 2:
                  case 3:
                      for (uint8_t j = 0;
                          match = j;
                        if (j >= VAR_TOTAL)
                      msg.type = match;
                   case 4:
                          cmd = C_SET;
                          cmd = C_REQ;
                        else {
            #ifdef DEBUG
                i++;
              if (cmd != -1) {
                char* ca;
                ca += length;
                *ca = '\0';
                txBlink(1);
                // inject time
            #ifdef DSRTC
                    setTime(epoch);
            #ifdef DEBUG
                if (!gw.sendRoute(
                            0)))
                  errBlink(1);
            // Led handling
                // switch led on
                // switching off
                countRx--;
                // switch led on
                // switching off
                countTx--;
                // switch led on
                // switching off
                countErr--;
              if (countRx == 255)
                countRx = cnt;
              if (countTx == 255)
                countTx = cnt;
                countErr = cnt;
            O
            O
            otto001
            @tomkxy Thanks, that helped! I seemed to have two problems:
            1. I did not know where to place the necessary includes! Thanks for the examples! Helped me a lot
            2)Regarding my problems from above (error: 'DEFAULT_CE_PIN' was not declared in this scope): I removed the whole libraries/MySensors dir and copied it again from the recent devel branch - this helped, error is gone and everything is compiling fine now :-)
            Thanks again and cheers,
            Otto
            • O otto001
              Otto
              AnticimexA
              AnticimexA
              Anticimex
              @otto001 Great! And thanks @tomkxy for helping out. MySensors teamwork at it's best. This is what it's all about :D
              • O
                O
                otto001
                wrote on last edited by otto001
                #156
                Hi again,
                and thanks again. signing seems to work now, unfortunately the sketch is too big for an UNO and I am right now struggling with the pinout and code adaptions to get it working with my W5100 shield and a mega...
                /edit: got it working.
                MyConfig.h:
                #ifdef SOFTSPI
                    //MEGA
                    const uint8_t SOFT_SPI_MISO_PIN = 15;
                    const uint8_t SOFT_SPI_MOSI_PIN = 14;
                    const uint8_t SOFT_SPI_SCK_PIN = 16;
                EthernetGateway.ino:
                #define RADIO_CE_PIN        35 // 5  // radio chip enable
                #define RADIO_SPI_SS_PIN    34 // 6  // radio SPI serial select
                And exactly those pins I connected from radio to the mega... (just in case that anyone else is in need of this)
                Might be a little OT, but maybe someone here knows a solution for a strange problem:
                Whenever I am using an UNO or MEGA with my W5100 shield, I have to reset after every power-on to make the sketch run. Does anyone know this? Is there a solution? I am trying to adapt optiboot to wait additional 500ms when powering on, but no luck so far...
                Cheers,
                Otto
                TD22057T 1 Reply Last reply
                • O otto001
                  Hi again,
                  MyConfig.h:
                  #ifdef SOFTSPI
                      //MEGA
                  Cheers,
                  Otto
                  TD22057T
                  TD22057T
                  TD22057
                  Check here: https://www.sparkfun.com/products/11166 Their "version 2" shield has some notes about fixing the power up reset problem with regular internet shields. Not sure what it is but maybe their notes and schematic can clue you in to a help you implement a fix on your current board.
                  • TD22057T
                    TD22057T
                    TD22057
                    And is the explanation of the fix that needs to be made:
                    http://www.hobbyist.co.nz/?q=ethernet-shield-w5100
                    http://forum.arduino.cc/index.php?topic=215798.msg1607035#msg1607035
                    FYI I just ordered a Mega myself for a gateway since I figured the $7 to get one is a better expenditure of my time/money than me trying to get the MqttClientGateway + signing + RF69 radio + debug print to all fit on an Uno so I'll be doing this mod as well.
                    • F
                      F
                      fleinze
                      @Anticimex
                      I think I may have found a bug in the code:
                      I wanted to build a gateway that accepts both signed and unsigned messages. For this I used MySigningAtsha204Soft signer(false);.
                      Now the gateway did accept unsigned messages, but also all messages sent to the gateway by another node with signing where unsigned.
                      After changing this line in MySensor.cpp:
                      if (signer.requestSignatures() && DO_SIGN(msg.sender))
                      to
                      if (signer.requestSignatures() || DO_SIGN(msg.sender))
                      it worked as I wanted it. The gateway accepts unsigned messages from nodes but if a node expects signed messages, the messages to the gateway are also signed.
                      This line means that the gateway requests signing from the node if he always requests signing or if the node requests signing.
                      What do you think?
                      • F fleinze
                        @Anticimex
                        to
                        What do you think?
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @fleinze I am not sure I understand the basic problem. What do you mean by " but also all messages sent to the gateway by another node with signing where unsigned.". The signing is based on requirement. A node (or gateway) either require messages sent to it to be signed or not. You have told your gateway that it is not supposed to require signed messages so it will accept unsigned messages sent to it. It is up to the node to configure if the node require signed messages in return. The gateway configuration has nothing to do with the preferences of a node. If you tell your gateway that it does not require signing, no messages to it will be signed. The opposite also holds true. If you configure it to require signed messages, all messages have to be signed. That is "working as designed".
                        • F fleinze
                          @Anticimex
                          to
                          What do you think?
                          AnticimexA
                          AnticimexA
                          Anticimex
                          #161
                          @fleinze after reading the post a few times I think I understand better :) you want nodes who require signed messages from the gateway to send signed messages to the gateway as well even though the gateway is configured to not require it. I don't have a problem with that change as long as it is also portable to the nodes (the same code works equally well for both gateways and nodes usecases). You are welcome to put a pull request on the code so I can have a closer look. If approved I will update the head post to reflect this changed behaviour.
                          • F
                            F
                            fleinze
                            :+1: The change only effects gateways. I will put a pull request, thx.
                            • F fleinze
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @fleinze do you have some special reason for why you want this? I don't see a real benefit and it would slightly increase the traffic. I suppose it would add some symmetry to node-gw communication.
                              • F fleinze
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @fleinze I am quite stressed out for the moment so I forget my own design :)
                                What you actually should do is to configure the gateway to require signed messages. It will then do so, but only from nodes that in turn require signed messages. So you should not need to change anything, just set the GW to require signatures.
                                • F
                                  F
                                  fleinze
                                  @Anticimex If I do so, this is the output of the Gateway:
                                  0;0;3;0;9;no sign
                                  0;0;3;0;9;no sign
                                  0;0;3;0;9;no sign
                                  0;0;3;0;9;no sign
                                  0;0;3;0;9;read: 2-2-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
                                  2;0;0;0;6;
                                  0;0;3;0;9;read: 2-2-0 s=1,c=0,t=30,pt=0,l=0,sg=0:
                                  2;1;0;0;30;
                                  0;0;3;0;9;no sign
                                  0;0;3;0;9;no sign
                                  0;0;3;0;9;no sign
                                  I tried to compile the node with deactivated signing feature and also with MySigningNone.
                                  The messages get rejected because in MySensor.cpp line 570 (developement branch) it is not checked if the sender requires signing:
                                  	if (signer.requestSignatures() && msg.destination == nc.nodeId && mGetLength(msg) && !mGetAck(msg) &&
                                  		(mGetCommand(msg) != C_INTERNAL ||
                                  		 (msg.type != I_GET_NONCE_RESPONSE && msg.type != I_GET_NONCE && msg.type != I_REQUEST_SIGNING &&
                                  		  msg.type != I_ID_REQUEST && msg.type != I_ID_RESPONSE &&
                                  		  msg.type != I_FIND_PARENT && msg.type != I_FIND_PARENT_RESPONSE)))
                                  My thought is that if I have a mixed network (signing and non-signing nodes) for some sensors I do not need signing (i.e. temperature-sensors). But if I have a button sensor that can actually switch something on or off (via the controller), it would be a security benefit if the messages from the sensor to the gateway are signed.
                                  • F fleinze
                                    0;0;3;0;9;no sign
                                    0;0;3;0;9;no sign
                                    0;0;3;0;9;no sign
                                    0;0;3;0;9;no sign
                                    2;0;0;0;6;
                                    2;1;0;0;30;
                                    0;0;3;0;9;no sign
                                    0;0;3;0;9;no sign
                                    0;0;3;0;9;no sign
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @fleinze If you have upgraded the library version, the signing table might have shifted in EEPROM. You then need to run the clear EEPROM sketch to reset the stored state in order for the gw/nodes to re-learn the existing signing preferences of the network.
                                    • F fleinze
                                      0;0;3;0;9;no sign
                                      0;0;3;0;9;no sign
                                      0;0;3;0;9;no sign
                                      0;0;3;0;9;no sign
                                      2;0;0;0;6;
                                      2;1;0;0;30;
                                      0;0;3;0;9;no sign
                                      0;0;3;0;9;no sign
                                      0;0;3;0;9;no sign
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      This is the exact usecase for the gw default behavior to only require signing from nodes that require signing in return. But I also got "no sign" errors after I flashed development branch yesterday on node/gw and only after I wiped the GW EEPROM I got it back online. So please try that. If it still does not work, I have to look closer, and see why this has broken because it has been working like that when I submitted the signing behavior.
                                      • F
                                        F
                                        fleinze
                                        @Anticimex I tried to make it work:
                                        • took a fresh copy of the development branch
                                        • activated signing in MyConfig.h
                                        • flashed the ClearEepromConfig sketch to both the test-gateway and the test-node.
                                        • built the gateway with MySigningAtsha204Soft signer; (requires signing by default)
                                        • built the node with MySigningNone signer;
                                        Still got the no sign message from the gateway...
                                        Please have a look at this.
                                        • F fleinze
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @fleinze mysigningnone is a special case. It won't make signatures, so could you instead try with either hard or soft atsha?
