  3. Generic Temperature/repeater node
9 Posts 3 Posters 5.7k Views 1 Watching
  • B
    B
    blackdog65
    Hi Guys,
    I have several nodes up and running which I feed into Domoticz.
    I'm currently trying to turn the DallasTemperatureSensor script into a repeater node. I have built some plug-in temp sensors but I have range issues due to living in a "Faraday Mansion". Some of my internal walls are 700mm+ in thickness! My current "get around" is to have a Raspberry Pi + Arduino gateway connected to each wifi point (yeah wifi is a huge issue too!)
    So far I have
    gw.begin(NULL, AUTO, true);
    in the
    and I'm calling process() in my loop()
    But I don't know where to go with regard to sleep/wait etc.
    I'd like to take a temp reading every 10 - 15 mins but I'm stuck
    Any pointers? :D
    • AWIA
      AWIA
      AWI
      Hi and welcome. You can try a non-blocking code loop like:
      if (millis() > lastUpdate + loopDelay){
          < whatever you want to do> ;
         lastUpdate = millis();
      make sure you have the lastUpdate (and loopDelay) as unisigned long
      • or -
      use gw.wait() ;
      • B
        B
        blackdog65
        Thanks for the reply!
        I got my "Arduino for Dummies" book from Amazon today... sooo let's give it a go :)
        • B
          B
          blackdog65
          Ok... I tried this based on the standard dallas DS18B20 sketch and I think it's working.
          It shows up in MSController as both a TEMP sensor and an ARDUINO_RELAY
          Tomorrow I'll try it with Domoticz
          Many thanks for the advice ;)
          #include <OneWire.h>
          #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
          unsigned long WAIT_TIME = 300000; // Wait time between reads (in milliseconds)
          int numSensors=0;
          boolean receivedConfig = false;
          boolean metric = true;
          MyMessage msg(0,V_TEMP);
            sensors.begin();
            // Startup and initialize MySensors library. Set callback for incoming messages.
            gw.sendSketchInfo("Temperature Sensor", "1.1");
               gw.present(i, S_TEMP);
            // Process incoming messages (like config from server)
            gw.wait(conversionTime);
              float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
              #if COMPARE_TEMP == 1
                gw.send(msg.setSensor(i).set(temperature,1));
            gw.wait(WAIT_TIME);
          • B
            B
            blackdog65
            Ah... actually it doesn't work :(
            It takes one temp reading and then sits there with a led flashing... damn!
            Anyone see the problem?
            AWIA 1 Reply Last reply
            • B blackdog65
              AWIA
              AWIA
              AWI
              @blackdog65 You can include a few Serial.print's. It could block for while if "conversionTime" is long..
              • B
                B
                blackdog65
                How odd? Turned off and on... (which I'd tried obviously) and has worked perfectly since
                go figure
                • N
                  N
                  NotYetRated
                  700mm walls? Do you live in a blast shelter?! haha that has got to be infuriating. Although, the sound dampening from room to room between those walls has got to be nice!
                  • B
                    B
                    blackdog65
                    It drives me crazy! The oldest part of the house pre-dates 1650 and was built to last. I have 4 wifi points hard-wired in as wifi will only reach the next room.
                    On the plus side, it's cool in summer and warm in winter ;)
