  3. My Slim 2AA Battery Node
498 Posts 71 Posters 598.5k Views 69 Watching
  • GertSandersG GertSanders
    Very nicely done ! Great idea, makes the sensor blend in. Fortunatly in Belgium we do have access to cheap cableducts. I did not think of using them as a case, but given that we have access to various widths, I will check.
    May I ask, which boardhouse made the PCB's for you ?
    Gert
    m26872M
    m26872M
    m26872
    @GertSanders I ordered from DirtyPCBs. It was 51mm but it didn't complain.
    Hm. I can now see few strange spot in one of the PCB-photos above. I'll look into what that can be...
    AWIA 1 Reply Last reply
    • A
      aproxx
      wrote on last edited by aproxx
      Thanks for the detailed information about this project! I was/am looking for a similar solution to check whether doors are opened or closed.
      Have you ever considered drilling a hole in the top of the door, and placing the entire node inside this drilled hole like the video below? Similar to this video?
      That was something I planned to do, but your solution seems really nice as well in case drilling a hole in the door doesn't work out as expected.
      m26872M 1 Reply Last reply
      • H
        H
        Harrdy
        I see u don't use a external 8mhz quarz. Because any technical reasons (=low current?) or for reasons of space?
        • m26872M m26872
          AWIA
          AWIA
          AWI
          @m26872 Great design, did you share the design on dirtyPcb's?
          • A aproxx
            m26872M
            m26872M
            m26872
            @aproxx I've never thought about it, but I think it's an excellent idea for some situations.
            • AWIA AWI
              m26872M
              m26872M
              m26872
              @AWI No, but the Eagle files are attached above. I'm new to all this open hw/sw sharing. You're very welcome to tell me how I should do it the right way. PM if you like.
              • m26872M m26872
                AWIA
                AWIA
                AWI
                @m26872 When you check out your order you can set the "sharing" options:
                upload-821ec565-96e5-4214-baa4-72564a63c07a and even get a small profit (or a donation to MySensors..)
                  @m26872: very nice idea :smiley:
                  just a little question, is your cable duct pvc. I think so. Alloy maybe would not be great for radio...
                  yoyur idea can be very helpful thx for share.
                  • scalzS scalz
                    m26872M
                    m26872M
                    m26872
                    @scalz Yes, it's pvc.
                    • H Harrdy
                      m26872M
                      m26872M
                      m26872
                      Low power, low cost, less space, less work. Stability might be an issue at different ambient temperatures etc.
                      • m26872M
                        m26872M
                        m26872
                        Added a boardhouse link if anyone would like to order the board straight from there (thx @AWI). Couldn't see any cons.
                        I think it's enough tested, but personally I'd wait for a tested v2.0 or make suggested improvements myself first.
                        • A
                          ahhk
                          great job! I think i will use your board to for small window -sensors.
                          But one question: i cannot upload sketches via arduino-ide when the 1mhz bootloader is flashed. i checked the wires and everything else and i tested a 8mhz/internal bootloader - works fine. but the 1mhz-bootloader just does not accept uploads?
                          • A ahhk
                            m26872M
                            m26872M
                            m26872
                            wrote on last edited by m26872
                            @ahhk There's also the precompiled bootloader for 4800 baud in the link above. Did you try that one too? I think 9600 baud was maximum serial speed at 1MHz. Lower should be safer.
                            Or what do you mean with "does not accept uploads"? Is it locked?
                            Double checked boards.txt settings?
                            • A
                              ahhk
                              wrote on last edited by ahhk
                              i can upload via RX/TX with arduino IDE with the 8mhz/internal bootloader. but if i flash the 1mhz bootloader from the link above (atmega328_1a.hex), i cannot upload the same way...
                              TX/RX is connected correctly. I can upload a sketch via "Upload with programmer" and receive and transmit characters with 9600baud. tested with the example-sketch "SerialEvent".
                              IT is a brand new 328P - not locked...
                              boards.txt shows
                              apm96.upload.tool=avrdude
                              apm96.upload.protocol=arduino
                              apm96.upload.speed=9600
                              apm96.bootloader.tool=avrdude
                              apm96.build.mcu=atmega328p
                              apm96.build.f_cpu=1000000L
                              apm96.build.core=arduino
                              apm96.build.variant=standard
                              i didnt try the 4800baud bootloader until now....i will do now...
                              • A ahhk
                                boards.txt shows
                                m26872M
                                m26872M
                                m26872
                                @ahhk Reset issue? Maybe try other startup times (low fuse 42h or 52h), other usb2serial or adjust reset R and C.
                                • m26872M
                                  m26872M
                                  m26872
                                  For info. I've prototyped and ordered a slightly improved version of the pcb. Note that this is UNTESTED and experimental.
                                  Eagle brd-file and board house link. Use it for inspiration. Don't expect it to be and tested until next month at least.
                                  • mfalkviddM
                                    Great work @m26872
                                    Thanks for sharing!
                                    • F
                                      F
                                      frenchclem
                                      Really great idea @m26872 !!
                                      I'm waiting for the V1.2 test and review before ordering some boards on DirtyPcb.
                                      One Tip/question : have you thought on panelizing your slimnode, because we could easily fit 3 board on the 5X5 limitation ? I also think that DirtyPCB would even process the break routing to ease board separation.
                                      • F frenchclem
                                        m26872M
                                        m26872M
                                        m26872
                                        #22
                                        @frenchclem
                                        AAMOF I ordered a panelized version just a few days ago. I'm completely new to all this, so I leave no guarantees...
                                        Here's the brd-file.
                                        Edit 3/12: Boardhouse link removed (the panelized version of v1.2 contains a faulty via between D13 and SCK.)
                                        • F
                                          F
                                          frenchclem
                                          I guess if you ordered panelized version, you have tested the V1.2 ? Would you mind sharing the schematics also please ?
                                          I'm also very new to this, I've never ordered PCB on Dirtypcb, how long does it takes to arrive in Europe ?
