  3. Is there any complete "how to guide"?
16 Posts 5 Posters 6.4k Views 2 Watching
  • A
    alfredocdmiranda
    Now, I am confuse, who does assign IDs? Controller or Gateway?
    • sundberg84S
      sundberg84S
      Never the gateway - this just pass along the msg to the controller.
      If you do not set a static node id, the controller assign.
      • magpernM
        magpernM
        magpern
        Yet again thanks @Dwalt.
        I guess I'll have to wait for the Vera Edge to arrive. Can't make head or tail out of this.
        I don't get anything useful out of MYSController. I have tried to read about it, but I can't find anything but the forum thread about it. Everybody seams to already have it running and have other problems (and talk about MYSBootloader alot)
        MYSController connects to my gateway at 192.168.0.250:5003. It says
        0;0;3;0;14;Gateway startup completed
        when I power up my sensor, MYSController does some TX and RX (I also see thing happen in telnet client).
        2015-10-14 22:05:23 TX 255;255;3;0;4;1
        2015-10-14 22:05:23 RX 255;255;3;0;3;
        But that's about it. Nothing more. Nodes does not update, routing table is the same
        it just say this in the nodes list
        0 - Gateway
        Broadcast
        tekkaT 1 Reply Last reply
        • magpernM magpern
          0 - Gateway
          Broadcast
          tekkaT
          tekkaT
          tekka
          That looks already good. The node is asking for an ID, and the controller assigns ID 1 (not chronological in the log). What sketch are you running?
          For further troubleshooting, please make sure "Logging" is enabled and upload the generated log file - that helps to understand what is going on.
          • sundberg84S
            sundberg84S
            @Magnus-Pernemark You can read about the serial api here: http://www.mysensors.org/download/serial_api_15
            255 = Node does not have an id
            3 = Internal
            0 = No ack
            damn... tecka was first :)
            • sundberg84S sundberg84
              3 = Internal
              0 = No ack
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              @sundberg84 sorry...lol :)
              • magpernM
                magpernM
                magpern
                Hi @tekka. I just took a ESP8266 NodeMcu V0.9 and connected a NRF24L01+ radio to it. Uploaded sketch according to instructions found about this gateway.
                Then I did the same thing with a Mini Pro, hooked up a NRF and uploaded the RelayActuator.
                I didn't change any code, more then the LED pin on the gateway, SSID and password for WIFI.
                Applyed power to gateway, started MYSController, applyed power to sensor.
                And this is what I get
                2015-10-14 22:30:13	STARTUP	Initialize message logging
                2015-10-14 22:30:13	STARTUP	MYSController 0.1.2.282
                2015-10-14 22:30:13	STARTUP	FPC 2.6.4 / Lazarus 1.4.2
                2015-10-14 22:30:13	STARTUP	still under development :) tekka 2015
                2015-10-14 22:30:13	STARTUP	Load INI file...
                2015-10-14 22:30:13	STARTUP	INI version 0.1.2.282
                2015-10-14 22:30:13	INFO	*** Logging START ***
                2015-10-14 22:30:13	VERSION	MYSController 0.1.2.282
                2015-10-14 22:30:13	STARTUP	INI file loaded
                2015-10-14 22:30:13	STARTUP	Loading FW repository...
                2015-10-14 22:30:13	REPO	FW "Blink" loaded. t=10, v=1, blocks=72, crc=0xD098
                2015-10-14 22:30:13	REPO	FW "TimeReporter" loaded. t=20, v=1, blocks=840, crc=0x4AC5
                2015-10-14 22:30:13	REPO	FW "Sensebender Micro" loaded. t=100, v=1, blocks=1344, crc=0x3482
                2015-10-14 22:30:13	REPO	FW "Sensebender Blink" loaded. t=110, v=1, blocks=768, crc=0x1314
                2015-10-14 22:30:13	REPO	FW repository loaded. Items=4
                2015-10-14 22:30:13	STARTUP	Initialize message types
                2015-10-14 22:30:13	NODE	New node discovered, node id=0
                2015-10-14 22:30:13	NODE	New node discovered, node id=255
                2015-10-14 22:30:17	INFO	Connected to 192.168.0.250:5003
                2015-10-14 22:30:17	CHILD	New child discovered, node id=0, child id=0
                2015-10-14 22:30:17	RX	0;0;3;0;14;Gateway startup complete.
                2015-10-14 22:30:25	UPDATE	4295098650
                2015-10-14 22:30:38	CHILD	New child discovered, node id=255, child id=internal
                2015-10-14 22:30:38	TX	255;255;3;0;4;1
                2015-10-14 22:30:38	RX	255;255;3;0;3;
                2015-10-14 22:30:39	TX	255;255;3;0;4;1
                2015-10-14 22:30:39	RX	255;255;3;0;3;
                2015-10-14 22:30:41	TX	255;255;3;0;4;1
                2015-10-14 22:30:42	RX	255;255;3;0;3;
                2015-10-14 22:30:43	TX	255;255;3;0;4;1
                2015-10-14 22:30:43	RX	255;255;3;0;3;
                • magpernM magpern
                  tekkaT
                  tekkaT
                  tekka
                  @Magnus-Pernemark looks like the node does not receive the ID reply - this has previously been observed: adding a larger capacitor or replacing the nRF often solved the issue.
                  • magpernM
                    magpernM
                    magpern
                    Thanks @tekka that did it. I didn't have a capacitor on the gateway. I added a 4.7uF and now the sensor pops up in MYSController. (The capacitor recommendation was not in the ESP8266 setup, hense lack of one)
                    Thank you so much. One less thing to loose sleep over.
                    • magpernM magpern
                      tekkaT
                      tekkaT
                      tekka
                      @Magnus-Pernemark :) have fun
                      • A
                        alfredocdmiranda
                        @sundberg84 Thanks for your answer! Now makes a lot of sense and it works I am able to assign ids :)
