  3. Is there any complete "how to guide"?
16 Posts 5 Posters 6.4k Views 2 Watching
  • sundberg84S
    sundberg84S
    Never the gateway - this just pass along the msg to the controller.
    If you do not set a static node id, the controller assign.
    • magpernM
      magpernM
      magpern
      Yet again thanks @Dwalt.
      I guess I'll have to wait for the Vera Edge to arrive. Can't make head or tail out of this.
      I don't get anything useful out of MYSController. I have tried to read about it, but I can't find anything but the forum thread about it. Everybody seams to already have it running and have other problems (and talk about MYSBootloader alot)
      MYSController connects to my gateway at 192.168.0.250:5003. It says
      0;0;3;0;14;Gateway startup completed
      when I power up my sensor, MYSController does some TX and RX (I also see thing happen in telnet client).
      2015-10-14 22:05:23 TX 255;255;3;0;4;1
      2015-10-14 22:05:23 RX 255;255;3;0;3;
      But that's about it. Nothing more. Nodes does not update, routing table is the same
      it just say this in the nodes list
      0 - Gateway
      Broadcast
      tekkaT 1 Reply Last reply
      • magpernM magpern
        0 - Gateway
        Broadcast
        tekkaT
        tekkaT
        tekka
        That looks already good. The node is asking for an ID, and the controller assigns ID 1 (not chronological in the log). What sketch are you running?
        For further troubleshooting, please make sure "Logging" is enabled and upload the generated log file - that helps to understand what is going on.
        • sundberg84S
          sundberg84S
          @Magnus-Pernemark You can read about the serial api here: http://www.mysensors.org/download/serial_api_15
          255 = Node does not have an id
          3 = Internal
          0 = No ack
          damn... tecka was first :)
          • sundberg84S sundberg84
            3 = Internal
            0 = No ack
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            @sundberg84 sorry...lol :)
            • magpernM
              magpernM
              magpern
              Hi @tekka. I just took a ESP8266 NodeMcu V0.9 and connected a NRF24L01+ radio to it. Uploaded sketch according to instructions found about this gateway.
              Then I did the same thing with a Mini Pro, hooked up a NRF and uploaded the RelayActuator.
              I didn't change any code, more then the LED pin on the gateway, SSID and password for WIFI.
              Applyed power to gateway, started MYSController, applyed power to sensor.
              And this is what I get
              2015-10-14 22:30:13	STARTUP	Initialize message logging
              2015-10-14 22:30:13	STARTUP	MYSController 0.1.2.282
              2015-10-14 22:30:13	STARTUP	FPC 2.6.4 / Lazarus 1.4.2
              2015-10-14 22:30:13	STARTUP	still under development :) tekka 2015
              2015-10-14 22:30:13	STARTUP	Load INI file...
              2015-10-14 22:30:13	STARTUP	INI version 0.1.2.282
              2015-10-14 22:30:13	INFO	*** Logging START ***
              2015-10-14 22:30:13	VERSION	MYSController 0.1.2.282
              2015-10-14 22:30:13	STARTUP	INI file loaded
              2015-10-14 22:30:13	STARTUP	Loading FW repository...
              2015-10-14 22:30:13	REPO	FW "Blink" loaded. t=10, v=1, blocks=72, crc=0xD098
              2015-10-14 22:30:13	REPO	FW "TimeReporter" loaded. t=20, v=1, blocks=840, crc=0x4AC5
              2015-10-14 22:30:13	REPO	FW "Sensebender Micro" loaded. t=100, v=1, blocks=1344, crc=0x3482
              2015-10-14 22:30:13	REPO	FW "Sensebender Blink" loaded. t=110, v=1, blocks=768, crc=0x1314
              2015-10-14 22:30:13	REPO	FW repository loaded. Items=4
              2015-10-14 22:30:13	STARTUP	Initialize message types
              2015-10-14 22:30:13	NODE	New node discovered, node id=0
              2015-10-14 22:30:13	NODE	New node discovered, node id=255
              2015-10-14 22:30:17	INFO	Connected to 192.168.0.250:5003
              2015-10-14 22:30:17	CHILD	New child discovered, node id=0, child id=0
              2015-10-14 22:30:17	RX	0;0;3;0;14;Gateway startup complete.
              2015-10-14 22:30:25	UPDATE	4295098650
              2015-10-14 22:30:38	CHILD	New child discovered, node id=255, child id=internal
              2015-10-14 22:30:38	TX	255;255;3;0;4;1
              2015-10-14 22:30:38	RX	255;255;3;0;3;
              2015-10-14 22:30:39	TX	255;255;3;0;4;1
              2015-10-14 22:30:39	RX	255;255;3;0;3;
              2015-10-14 22:30:41	TX	255;255;3;0;4;1
              2015-10-14 22:30:42	RX	255;255;3;0;3;
              2015-10-14 22:30:43	TX	255;255;3;0;4;1
              2015-10-14 22:30:43	RX	255;255;3;0;3;
              • magpernM magpern
                tekkaT
                tekkaT
                tekka
                @Magnus-Pernemark looks like the node does not receive the ID reply - this has previously been observed: adding a larger capacitor or replacing the nRF often solved the issue.
                • magpernM
                  magpernM
                  magpern
                  Thanks @tekka that did it. I didn't have a capacitor on the gateway. I added a 4.7uF and now the sensor pops up in MYSController. (The capacitor recommendation was not in the ESP8266 setup, hense lack of one)
                  Thank you so much. One less thing to loose sleep over.
                  • magpernM magpern
                    tekkaT
                    tekkaT
                    tekka
                    @Magnus-Pernemark :) have fun
                    • A
                      alfredocdmiranda
                      @sundberg84 Thanks for your answer! Now makes a lot of sense and it works I am able to assign ids :)
