  3. Having issues with 2AAA battery project and AVRDUDE
14 Posts 5 Posters 5.7k Views 3 Watching
  • D
    den2k
    I've had some decent success so far getting a Pro Mini 3.3V + nRF24 + temperature sensor + 2 AAA bty working. The node is pushing temperature sensor data to my serial gateway which is connected via USB to a Pi.
    The challenge is driving the node to use even lower power consumption. I am at 4-5mA on average now. This was with me removing 2 LEDs (one from Pro Mini and one from a Step up module).
    I've been trying to use this method:
    http://iot-playground.com/2-uncategorised/9-arduino-low-power-sensor
    To create a low powered Mini running at 1MHz without much luck. When I run avrdude this is what I get after programming the board.
    I believe using avrdude the bootloader is programmed correctly into the Pro Mini, but not sure because when I try to program the board from the Arduino IDE, (I've already added the special board to the board.txt file) it won't program correctly.
    Any clue?
    OitzuO 1 Reply Last reply
    • A
      ahhk
      this is **very **interesenting for me. could you write a small tutorial when you solved it? i failed until today to use arduino ide with 328p@4mhz(or lower) with arduino bootloader. i read something about compiling a new bootloader - but this is too much for me to go and i didnt find a compiled bootloader for 1 or 4mhz to download :(
      greetings
      andreas
      • D den2k
        Any clue?
        OitzuO
        OitzuO
        Oitzu
        @den2k baudrate to high in boards.txt? The mcu can't handle the same high baudrate on 1mhz.
        D 1 Reply Last reply
        • L
          L
          LastSamurai
          Perhaps this helps. As far as I know and have read 1Mhz doesn't really change that much because you sleep most of the time anyways. Try to disable the BOD, that uses most of the power.
          D R 2 Replies Last reply
          • A
            ahhk
            wrote on last edited by ahhk
            but you can run on a lower Vmin value....
            The other thread doesnt help - there was no solution for the serial-problem at 1mhz...
            Greetings
            • OitzuO
              OitzuO
              Oitzu
              http://wormfood.net/avrbaudcalc.php?postbitrate=9600&postclock=1
              Indicates a baudrate of 4800 should be fine...
              • L
                L
                LastSamurai
                Sure there was (at least wiht a similar problem at 8Mhz). Define your own board for the ide with a lower baudrate and use and ISP + upload with programmer in the IDE.
                • OitzuO Oitzu
                  den2k
                  wrote on last edited by den2k
                  @Oitzu Not sure that is the issue. This is what I have in my board.txt
                  nomii.upload.protocol=arduino
                  nomii.upload.maximum_size=30720
                  nomii.upload.speed=9600
                  nomii.upload.tool=avrdude
                  nomii.bootloader.low_fuses=0x62
                  nomii.bootloader.high_fuses=0xda
                  nomii.bootloader.extended_fuses=0x06
                  nomii.bootloader.path=nomii
                  nomii.bootloader.file=atmega328p_1mhz_9600.hex
                  nomii.bootloader.unlock_bits=0x3F
                  nomii.bootloader.lock_bits=0x0F
                  nomii.bootloader.tool=avrdude
                  nomii.build.mcu=atmega328p
                  nomii.build.f_cpu=1000000L
                  nomii.build.core=arduino
                  nomii.build.variant=standard
                  nomii.build.board=AVR_NOMII
                  • L LastSamurai
                    den2k
                    @LastSamurai interesting you say that 1Mhz doesn't matter that much. I don't know if it does or doesn't yet, because I cannot get it to work.
                    When measuring power consumption I get 4-5mA of consistent power draw. It spikes up to 25mA when the radio and Mini turn on to transmit and goes back to 5mA.
                    I have not removed the 3.3V voltage regulator on the Mini, so that may add to the 5mA figure, but I am no where near the <1mA that others are getting.
                    • L LastSamurai
                      den2k
                      @LastSamurai When I try programming to upload an Arduino script using the Arduino IDE to the 1Mhz board @ 9600 baud, I am using my FTDI module connected to the Mini. Are you saying I need to hook up a ISP programmer... thought that was only when I needed to program a bootloader.
                      • A
                        ahhk
                        I thougt uploading via ISP-programmer deletes the bootloader?
                        • D den2k
                          OitzuO
                          OitzuO
                          Oitzu
                          wrote on last edited by Oitzu
                          Did you removed the Power-LED?
                          Tried 4800?
                          I'm also missing nomii.upload.maximum_data_size=2048
                          Don't think so. Bootloader and Sketch go to different memory location.
                          • D
                            den2k
                            The Pro mini is now running at 0.7mA without the power LED. I've been able to program using AVRDUDE using a new AVR programmer from Sparkfun (Pocket AVR). The one on Ebay I found out needed to be programmed via AVR first.
                            9600 Baud works. So all ok now. Thanks everyone.
                            • L LastSamurai
                              R
                              R
                              riataman
                              wrote on last edited by riataman
                              I don't think the idea behind changing the clock to 1Mhz is to save energy, but to allow the mcu to run at lower voltages (allowing it to keep running when the batteries are already considered dead for other uses). The Atmega328 can run down to 1.8V but only if your clock speed is 4Mhz or lower. We change it to 1Mhz because its easier to do that in software, rather than solder a new crystal.
