  3. power NRF24L01+PA+LNA from FTDI USB to TTL Serial Adapter
13 Posts 5 Posters 8.3k Views 2 Watching
  • V
    V
    vil1driver
    wrote on last edited by vil1driver
    ok, thanks a lot :p
    is the same with 5v ?
    • korttomaK
      korttomaK
      korttoma
      There is no 5v out on the FTDI chip so most likely the 5v comes directly from USB. You need to check your USB FTDI adapter board how it is made since there are many version out there.
      • Tomas
      • V
        V
        vil1driver
        on the mysensors store I found this
        http://www.ebay.com/itm/320907184616?rmvSB=true
        There is a jumper on the board that allows the board to be configured to either 3.3V or 5V
        I think the 5v output is unregulated and can output full curent form usb ?
        OitzuO 1 Reply Last reply
        • V vil1driver
          OitzuO
          OitzuO
          Oitzu
          @vil1driver you probably have a few spare parts laying arround?
          For testing porpuses i'm using external batterie power-source on the pa+lna model.
          • V
            V
            vil1driver
            Testing what ?
            You not understand my question.
            The goal is to power pro mini 5v and nrf with the ftdi adpter.
            And have enough output curent to use nrf at full power.
            • V
              V
              vil1driver
              I ordered, I test and come back to tell you.
              I hope it will work because it is in my opinion the best way to make the gateway
              AWIA 1 Reply Last reply
              • V vil1driver
                AWIA
                AWIA
                AWI
                wrote on last edited by AWI
                @vil1driver It will depend on your FTDI adapter. The "original" serial gateway is a Nano with an "Ftdi" on-board. I always use the FTDI adapter setup while testing. Even the 3.3v output has enough power. You should not power a relay or large led-strip though.
                • V
                  V
                  vil1driver
                  @AWI, Don't you know an arduino can't power a NRF24L01+PA+LNA on full power ? This antena need an external power supply and I don't want. Using only the usb power is far better. I will try to see if I'm right. I hope. Wait and see :-)
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    The PA+LNA version can drawn up to 150ma when transmitting. The 3.3v on nano is usually provided by the FTDI chip, which in general can't go more of 50mA.
                    ESP8266 GW + mySensors 2.3.2
                    Alexa / Google Home
                    • V vil1driver
                      AWIA
                      AWIA
                      AWI
                      @vil1driver As I said it will depend on the "ftdi" board used. There are a few with a decent 3.3v converter on board. But what if you use http://nl.aliexpress.com/item/New-Socket-Adapter-plate-Board-for-8Pin-NRF24L01-Wireless-Transceive-module-51/32230227557.html?ws_ab_test=searchweb201556_7_71_72_73_74_75,searchweb201527_5,searchweb201560_9
                      A lot has been written on this forum and elsewhere on max power settings. Proper shielding seems to be solving some issues there.
                      • V
                        V
                        vil1driver
                        Yes it's working :blush: #define RF24_PA_LEVEL_GW RF24_PA_MAX
