  3. [contest] Yet another servo blind control project
servovenetianblinds
19 Posts 7 Posters 31.0k Views 6 Watching
  • slartiS
    slartiS
    slarti
    A little bit of progress. Got some functional radios today and I've been trying to fit everything in the control boxes. I think I have an ok design but once I started soldering I realised that the protoboard I was using wasn't dot matrix like it said on the box but copper tracks :rage:
    Oh well, I'll have to get something else tomorrow...
    Some mock up pics:
    "One is never alone with a rubber duck"
    • slartiS
      slartiS
      slarti
      wrote on last edited by slarti
      First finished sensor!:
      Obvious flaw:
      Whole window
      What is the best way to disable the power LED? Desolder it?
      jendrushJ 1 Reply Last reply
      • slartiS slarti
        Obvious flaw:
        Whole window
        jendrushJ
        jendrushJ
        jendrush
        You can cut the pcb trace leading to this led.
        • slartiS
          slartiS
          slarti
          After soldering three ratsnests like the one in the previous post, I decided there has to be a simpler way to do things. So after a day of watching eagle cad tutorials and messing about with the software I came up with a board of my own.
          I didn't want to add any stuff I didn't need except for a pin header for raw input, A0-breakout and a choice of 5V/3.3V output for A0 and D4 with a jumper. I also don't want to solder every pin on the pro mini so I can use them possibly elsewhere.
          Am I shooting a fly with a cannon? Do I need something else on the board? DirtyPCB and other chinese manufacturers are closed at the moment but are there alternatives besides OSHPARK?
          BTW, three arduinos and servos seem to be the maximum simultaneous capacity for the little Nokia charger. They all work but get a bit flaky after a few tests. We'll see what happens when I add the fourth :wink:
          • slartiS
            slartiS
            slarti
            Ok, I'm calling this one finished. I got all the wiring done and my sketch is working well enough (I'll update the first post). The result doesn't look too bad, either.
            I don't know if the little charger doesn't have enough power for the four arduinos and servos at once or if the radio network gets clogged up when Vera tries to control them all at the same time, but they work well as a group when I add a 500ms delay between each command. Here's the lua script I've put in a scene:
            local SSID = "urn:upnp-org:serviceId:Dimming1"
            local value = luup.variable_get(SSID, "LoadLevelStatus", 59)
            windows = {59, 58, 54, 61}
            if (value == "0") then
              for i=1,4 do
                luup.call_action(SSID, "SetLoadLevelTarget", {newLoadlevelTarget = "100"}, windows[i])
                luup.sleep(500)
              end
              for i=1,4 do
                luup.call_action(SSID, "SetLoadLevelTarget", {newLoadlevelTarget = "0"}, windows[i])
                luup.sleep(500)
              end
            end
            It just looks up the status of the first window and then changes all positions to the exact opposite of that single window.
            I'll update the first post with a video of them being controlled with a zwave fibaro switch that controls another hidden fibaro switch which triggers the lua script in Vera (that's not complicated at all :wink: ).
            All in all, this ended up costing almost as much as a commercial solution if you count all the stuff I ordered from ebay and the tools I had to buy. On the other hand I now own the tools and I have a ton of leftover material for several more windows and sensors and now I know some C++, lua and even eagle CAD! Very happy with the end result. Thanks to the MySensors team for making it possible! :+1:
            Here's the parts list (price/window):
            • Servo extension cables (2pcs 0.88€)
            • Servos (1pc 2.78€)
            • Bobbins (1pc 0.09€)
            • Buttons (1pc 0.70€)
            • Heat shrink tube (maybe 0.10€ worth)
            • Cat6 cable (solid core) (maybe 0.10€ worth)
            • Protoboard (1pc 0.20€)
            • Project box (1pc 1.44€)
            • Cable raceway (about 1€)
            • 3.3V regulators (1pc 0.12€)
            • 4,7 uF capacitors (1pc 0.16€)
            • various bits and pieces I can't think of now (can't think of a price, either)
            • 5v Arduino Pro Mini clone (1pc 2€)
            • NRF24L01+ -radio (1pc 0.70€)
            Grand total/window : 10.27€
            • NuubiN
              NuubiN
              Nuubi
              Excellent project report, Thanks!
              It made soo easy to order the required parts :-)
              I suppose I should post my project, once it's been done, too... these things just tend to take their time (ofter years---to infinity).
              • E
                E
                exosteph
                Your project is very cool !
                Do you known if it is possible to control it with a raspberry pi and domoticz ?
                Thank's
                slartiS 1 Reply Last reply
                • E exosteph
                  Thank's
                  slartiS
                  slartiS
                  slarti
                  @exosteph I would think so since these are just MySensors actuator nodes.
                  The sketches are made using MySensors 1.4 libraries so they might not work with 1.5. I've been really busy lately and haven't had any time for this stuff :cry:
                  I did make some helper boards earlier to make it easier to solder these sensors (nevermind the horrible soldering)
                  • NuubiN
                    NuubiN
                    Nuubi
                    wrote on last edited by Nuubi
                    Darn. When I connect the servo to the setup the Arduino loses it. Any idea how to tackle this? I've tried various capacitors all over the places:expressionless:
                    • NuubiN Nuubi
                      slartiS
                      slartiS
                      slarti
                      @Nuubi Can you show your connections?
                      • NuubiN
                        NuubiN
                        Nuubi
                        It was, in the end and again, a power issue. I didn't mention that I included an RGB control to the node, so I'm feeding the whole nest with a 12v low grade supply. And the servo gets its power via Nano -- no external regulator for that.
                        All in all, caps in the power supply, radio, nano 5V and 3.3V, aaaallll works now :)
                        BTW, now that you've had your blinds automated, have you been happy with them? All blinds MySensorised yet?
                        • NuubiN Nuubi
                          slartiS
                          slartiS
                          slarti
                          @Nuubi Yes, I've been happy with them but MySensoring the rest of them is on hold. I've been extremely busy with a new job for a long time and I was supposed to do a few more improvements and tweaks before doing the rest of them. Also, my tinkering space (the kitchen table) is always under heavy pressure from other activities. Maybe I can get some time during the winter.
                          TL;DR I've been lazy
                          • slartiS
                            slartiS
                            slarti
                            My ethernet gateway died and I made another one on a Raspberry Pi so I updated all of my sensors from 1.4 libraries to 2.2. Here's the updated sketch for these servo blind control nodes:
                            // A sketch to control a servo with a button and MySensors messages
                            #include <Servo.h>
                            #include <Button.h>        	//https://github.com/JChristensen/Button
                            #define BUTTON_PIN 4       	//Connect a tactile button switch (or something similar)
                                                        //from Arduino pin 4 to ground.
                            #define PULLUP true        	//To keep things simple, we use the Arduino's internal pullup resistor.
                            #define INVERT true        	//Since the pullup resistor will keep the pin high unless the
                                                       	//switch is closed, this is negative logic, i.e. a high state
                                                       	//means the button is NOT pressed. (Assuming a normally open switch.)
                            #define DEBOUNCE_MS 20     	//A debounce time of 20 milliseconds usually works well for tactile button switches.
                            #define LONG_PRESS_PERIOD 700   //How long to keep button pressed until sweeping starts
                            #define MAX_DEGREES 180         //Servo limits. Whatever works for you.
                            #define MIN_DEGREES 0
                            #define CHILD_ID 3
                            Button myBtn(BUTTON_PIN, PULLUP, INVERT, DEBOUNCE_MS);    //Declare the button
                            Servo myservo;
                            enum {DECREASING, INCREASING};      //On a servo mounted on the left, with outer slat edge down as closed,
        // closing is going toward 180, opening toward 0 (on my fake futaba s3003's)
                            boolean invertConversions = true;   // false if opening toward 180
                            boolean servoDirection = INCREASING;     //A variable that keeps the current servo direction
                            int servoPin = 3;
                            int servoPosition;
                            int servoSpeed = 1;                 // The bigger, the faster. 1=slow 5=fast
                            MyMessage msg(CHILD_ID, V_PERCENTAGE);
                            void setup(void)
                            void presentation()  {
                              sendSketchInfo("Servo", "1.3");
                              present(CHILD_ID, S_COVER);
                            void loop(void)
                                myBtn.read();                    		//Read the button
                                if (myBtn.wasReleased()){                   //If the button was pressed once sweep to end of current direction
                                    SweepToDirectionEnd();
                                    send(msg.set(ConvertDegToPercent(servoPosition)));
                                if (myBtn.pressedFor(LONG_PRESS_PERIOD)){   //If the button is held down the servo will start to sweep
                                    SweepUntilStop();
                            int ConvertPercentToDeg(int percent)
                                int degree;
                                if (invertConversions)
                                    degree = map(percent, 0, 100, MAX_DEGREES, MIN_DEGREES);
                                if (!invertConversions)
                                    degree = map(percent, 0, 100, MIN_DEGREES, MAX_DEGREES);
                                return degree;
                            int ConvertDegToPercent(int degree)
                                int percent;
                                    percent = map(degree, MAX_DEGREES, MIN_DEGREES, 0, 100);
                                    percent = map(degree, MIN_DEGREES, MAX_DEGREES, 0, 100);
                                return percent;
                                myservo.attach(servoPin);
                                if (message.type==V_PERCENTAGE) {
                                    int val = message.getInt();
                                    SweepToPosition(ConvertPercentToDeg(val)); //In this case the value has to be inverted because 0 = open
                                    send(msg.set(val));
                                else if (message.type==V_STATUS) {
                                    if (message.getInt() == 1){
                                    SweepToPosition(ConvertPercentToDeg(100));
                                    send(msg.set(100));
                                    else if(message.getInt() == 0) {
                                    SweepToPosition(ConvertPercentToDeg(0));
                                    send(msg.set(0));
                                    myservo.detach();
                            void ServoMoveUp()
                                if ((myservo.attached()) && servoPosition < MAX_DEGREES){
                                    servoPosition += servoSpeed;
                                    myservo.write(servoPosition);
                                    delay(10);
                                    Serial.print("Servo Position: ");
                                    Serial.println(servoPosition);
                                if (!myservo.attached()){
                                    Serial.println("Servo stopped while moving toward MAX, direction unchanged");
                                    delay(100 * servoSpeed);
                                if (servoPosition >= MAX_DEGREES){
                                    Serial.println("MAX reached, changing direction toward MIN");
                                    servoDirection = DECREASING;
                                    delay(100 * servoSpeed);			// Wait for the last movement to finish
                            void ServoMoveDown()
                                if ((myservo.attached()) && servoPosition > MIN_DEGREES){
                                    servoPosition -= servoSpeed;
                                    delay(10);
                                    Serial.println("Servo stopped while moving toward MIN, direction unchanged");
                                if (servoPosition == MIN_DEGREES){
                                    Serial.println("MIN reached, changing direction toward MAX");
                            void SweepToDirectionEnd()
                                if (servoDirection == INCREASING){
                                    Serial.println("Going to MAX and stopping there");
                                    while (servoPosition < MAX_DEGREES){
                                        ServoMoveUp();
                                    delay(20 * servoSpeed);
                                    myservo.detach();
                                else if (servoDirection == DECREASING){
                                    Serial.println("Going to MIN and stopping there");
                                    while (servoPosition > MIN_DEGREES){
                                        ServoMoveDown();
                                    myservo.detach();
                            void SweepUntilStop()
                                while (myBtn.isPressed()){
                                    myBtn.read();
                                    if (myBtn.isReleased())
                                        myservo.detach();
                                        ServoMoveUp();
                                        ServoMoveDown();
                            void SweepToPosition(int destination)
                                if (abs(destination - servoPosition) >= servoSpeed)    //Don't move if destination is close to position
                                if (destination > servoPosition && myservo.attached()){
                                    Serial.print("Going to ");
                                    Serial.print(destination);
                                    Serial.println(" and stopping there");
                                    while (servoPosition < destination){
                                        ServoMoveUp();
                                    myservo.detach();
                                if (destination < servoPosition && myservo.attached()){
                                    while (servoPosition > destination){
                                        ServoMoveDown();
                                    myservo.detach();
