  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.1k Views 73 Watching
  • R rubal
    Hi @tekka , I've gone through the steps in your guide using MQTTGateway as gw sketch.
    When I start my new node (burned with mysbootloader) I only see the repeating message "FIND_PARENT" in MySensor Debug window and "RX 0;0;3;0;9;read: 0-0-255 s=255,c=3,t=7,pt=0,l=0,sg=0:" in the MYSController Debug window.
    The message appears every time the led is blinking on the node (approx every 2 seconds).
    Any idea why it doesn't request node id? Have also tried with AutoID without success.
    Thx!
    tekkaT
    tekkaT
    tekka
    @rubal MYSController does not support MQTT gw. Please use a different controller or change to a serial/tcp gw.
    • tekkaT tekka
      @Anticimex is implemented in the upcoming release :)
      AnticimexA
      AnticimexA
      Anticimex
      @tekka sweet! Any ETA on the next release?
      tekkaT 1 Reply Last reply
      • AnticimexA Anticimex
        tekkaT
        tekkaT
        tekka
        @Anticimex wanna beta-test? ;)
        AnticimexA 1 Reply Last reply
        • tekkaT tekka
          AnticimexA
          AnticimexA
          Anticimex
          @tekka for sure :)
            mvader
            @tekka - i do :) i use it every day
            • C cdr
              @tekka I feel really, really, REALLY stupid;
              I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
              D'OH
              Thanks for your patience and help, everything is working now and I'm really happy!
              :+1:
              petewillP
              petewillP
              petewill
              I think I am running into the same thing. How did you fix this? I have many nodes so switching back to 76 is not a good option for me.
              C 1 Reply Last reply
              • petewillP petewill
                C
                C
                cdr
                You can edit myconfig.h and have te recompile after change.
                • petewillP
                  petewillP
                  petewill
                  @cdr I've never recompiled a bootloader before but when I did some searching it seems that I need the .c file to do this. Maybe I'm missing something and I can recompile the .hex? How did you end up doing it? Thanks!
                  • petewillP
                    petewillP
                    petewill
                    I did some more testing and my issue definitely appears to be a result of changing the channel in MyConfig.h. I just built a serial gateway with channel 76 selected and everything worked perfectly. The only problem is I have over 20 nodes located throughout my house so re-uploading the code so they use that channel is not something I'd like to do if I can avoid it. Does anyone know how I can recompile the bootloader so I can change the channel?
                    I tried the files @siklosi posted here http://forum.mysensors.org/topic/2319/how-to-make-complie-mysbootloader/7 but it did not work.
                    N 1 Reply Last reply
                    • N
                      N
                      niccodemi
                      in firmware_config.csv file what is the first column "type" for? And where do I get "type" codes?
                      • N niccodemi
                        tekkaT
                        tekkaT
                        tekka
                        @niccodemi type can be any numeric value used to identify a specific firmware type - this value (together with FW version and the FW CRC) is used to automatically update the nodes.
                          N
                          N
                          niccodemi
                          @petewill did you have any success finding out how to change default channel?
                          petewillP 1 Reply Last reply
                          • F
                            F
                            Fabien
                            I recently switch to RFM69 and I know it's not yet compatible with MYSBootloader. But I can't find information about RFM69 and dualoptiboot support for OTA in MYSController (without a sensebender). Is it possible ? I have to make special config ? Thank !
                            • F Fabien
                              AnticimexA
                              AnticimexA
                              Anticimex
                              #310
                              @Fabien DualOptiboot is completely radio agnostic. You should not need any custom config to use OTA with DualOptiboot and rfm69. You do need an external flash on your board though.
                              • F
                                F
                                Fabien
                                @Anticimex ok but in MYSController is there a way in the GUI for setting the bootloader (DualOptiboot or MYSBootloader) or is ti automatic. I ask this because you have to tell MYSBootloader your are running SenseBender (DualOptiboot).
                                • F Fabien
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Fabien yes, select "sensebender"...this will do the trick
                                  • F
                                    F
                                    Fabien
                                    Thank you @tekka I don't test your new bootloader beacuse I think you don't have RFM69 version (perhaps in th future ?)
                                    • F Fabien
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @Fabien perhaps, will have to get some RFM69 hardware first...
                                      • N niccodemi
                                        petewillP
                                        petewillP
                                        petewill
                                        Sorry, don't know how I missed this. No, I haven't. I got sidetracked (kids) and I haven't had a chance to work on it further.
                                        • petewillP
                                          petewillP
                                          petewill
                                          @niccodemi I just was able to upload the bootloader using the files provided by @siklosi posted here http://forum.mysensors.org/topic/2319/how-to-make-complie-mysbootloader/7. The difference is I used a USBASP (V2.0) instead of an UNO. It worked the first time uploading the blink sketch!! It was a pain getting the USBASP to work on Windows 8.1 but after I got the driver installed (and the wiring connections correct) it worked great. I haven't uploaded any sensor sketches yet but hopefully I'll have time to play with it soon.
