  3. GatewayESP8266MQTTClient in Development Branch
13 Posts 6 Posters 6.6k Views 2 Watching
    Mike Cayouette
    @hek Thank you. I should have mentioned I have the gateway working but I was wondering how to define the node id in the clients. In any case, I was coming back here to say I had figured it out.
    I have a temp sensor communicating with the gateway.
    Mike
    • V
      V
      vickey
      @hek Gateway and sensor node never get communicated even after configuring manual ID. Here is arduino debug
      Starting...
      find parent
      send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
      find parent
      find parent
      Here is the ESP8266 12E gateway debug
      0;0;3;0;9;Starting...
      scandone
      f 0, ....scandone
      state: 0 -> 2 (b0)
      .state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 1
      cnt
      connected with Ahmed, channel 1
      ip:192.168.0.31,mask:255.255.255.0,gw:192.168.0.1
      .IP: 192.168.0.31
      0;0;3;0;9;MQTT connected
      • FotoFieberF
        FotoFieberF
        FotoFieber
        There seems to be a bug in incomingMQTT:
        replace
        with
        for (str = strtok_r(topic, "/", &p); str && i <= 5;
        -> http://forum.mysensors.org/topic/1870/esp8266-wifi-gateway-port-for-mysensors/138
          Ok, created a PR on this.
          https://github.com/mysensors/Arduino/pull/229
          Will just let it run through Jenkins before merging.
          • FotoFieberF
            FotoFieberF
            FotoFieber
            There may be other problems in the code. I switched to ethernet gateway and wrote my own controller in node-red (wip).
              Mike Cayouette
              @FotoFieber I switched to ethernet gateway and wrote my own controller in node-red
              I am attempting the same . For some reason though I cannot get the mysensors ESP8266Gateway to receive data from node-red. I configured a TCP node in node-red with the gateways IP on port 5003. When I connect the serial monitor I can see the client connection established, but when I send data from node-red I get nothing. I am able to telenet to the gateway and in the serial monitor I see the messages I type so I know the gateway can receive, but it does not receive from node-red. How did you get node-red and the gateway to exchange messages?
              Thank you,
              Mike
              • M Mike Cayouette
                Thank you,
                Mike
                FotoFieberF
                FotoFieberF
                FotoFieber
                @Mike-Cayouette
                What kind of tcp node do you use?
                I use a tcp request node and inject a blank on startup to get the connection opened.
                • ahmedadelhosniA
                  ahmedadelhosniA
                  ahmedadelhosni
                  wrote on last edited by ahmedadelhosni
                  This reply is related to another topic http://forum.mysensors.org/topic/2378/how-can-i-set-the-payload-for-mqtt-v1-6 where I wasn't able to send my buffer from my mqtt gateway to another sensor node. After spending all day today debugging the issue, I was able to find two bugs and to send the buffer correctly.
                  This is the topic which I subscribe to
                  #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygatewayin"
                  This is how I send my mqtt pattern using MQTTlens or Mosquitto to be published to the gateway. My message contains 1 or 0 to turn ON or OFF a relay in my sensor node with id 4, child id 19, set, no ack, V_LIGHT
                  mygatewayin/4/19/1/0/2
                  The first problem which I faced is that my mqtt buffer wasn't evaluated in the callback function incomingMQTT() found in MyGatewayTransportMQTTClient.cpp
                  After checking the case switch I found out that the rest of the case switches doesn't continue because the code returns due to the following line
                  if (strcmp_P(str, MY_MQTT_SUBSCRIBE_TOPIC_PREFIX) != 0)
                      return;
                  According to http://www.nongnu.org/avr-libc/user-manual/group__avr__pgmspace.html#gad34d5b7d040fcb97939e939f19d88a5f
                  The strcmp_PF() function returns an integer less than, equal to, or greater than zero if s1 is found, respectively, to be less than, to match, or be greater than s2. The contents of RAMPZ SFR are undefined when the function returns
                  Actually I haven't used this function before but according to description it will return 0 if they are identical, so using != shall be right, but actually it was solved when I replaced it with == instead of !=
                  Finally I was able to evaluate the buffer and the case switches continued.
                  But Also this didn't solve the problem and the buffer wasn't sent to the sensor node id 4
                  After lots of printing functions for debugging I found that in serial monitoring, the following is printed
                  send: 0-0-0-4 s=19,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
                  While when I use Serial gateway which is working well till now, the following is printed instead
                  send: 0-0-4-4 s=19,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                  Thus I found that the difference is in 0-0-X-4.
                  Searching further in the code, I found that the debug function for this line is used in MyTransport.cpp in function transportSendWrite(uint8_t to, MyMessage &message)
                  debug(PSTR("send: %d-%d-%d-%d s=%d,c=%d,t=%d,pt=%d,l=%d,sg=%d,st=%s:%s\n"),
                  			message.sender,message.last, to, message.destination, message.sensor, mGetCommand(message), message.type,
                  			mGetPayloadType(message), mGetLength(message), mGetSigned(message), to==BROADCAST_ADDRESS ? "bc" : (ok ? "ok":"fail"), message.getString(_convBuf));
                  So the difference here is that the variable to is set as 0 in case of mqttgateway, while it is set as 4 correctly using Serial gateway.
                  So finally this is what I have reached.
                  In MyTransport.cpp in function boolean transportSendRoute(MyMessage &message)
                  #if !defined(MY_REPEATER_FEATURE)
                      // None repeating node... We can only send to our parent\\
                      ok = transportSendWrite(_nc.parentNodeId, message);
                  The above is called because MY_REPEATER_FEATURE is not defined, thus the mqttgateway sends always 0 instead of the required node id.
                  I tried to define MY_REPEATER_FEATURE but I found big memory size and the software was crazy.
                  Also in MySensor.h it is not mentioned to be defined
                  #if defined(MY_GATEWAY_MQTT_CLIENT)
                  ... some code ...
                  ... some code ...
                  #elif defined(MY_GATEWAY_FEATURE)
                  ... some code ...
                  	#if defined(MY_RADIO_FEATURE)
                  		// We assume that a gateway having a radio also should act as repeater
                  		#define MY_REPEATER_FEATURE
                  What I did now as a workaround because it is 2:40 AM here and I need to sleep :D Is the following
                  In MyTransport.cpp
                  			ok = transportSendWrite(message.destination, message);
                  Please check whether this will solve the problem or not. Please correct me if I was wrong. It's my first time to look around in the library today.
                    @ahmedadelhosni said:
                    MY_REPEATER_FEATURE
                    Good catch, I'll do some tests and check in something.
                      MY_REPEATER_FEATURE
                      ahmedadelhosniA
                      ahmedadelhosniA
                      ahmedadelhosni
                      @hek Thanks. I am sure you will come up with a better general solution :D
