  3. OpenHAB
  4. [Tutorial] openHAB with serial gateway
78 Posts 25 Posters 87.8k Views 16 Watching
  • Daniel LindbergD
    Daniel LindbergD
    Daniel Lindberg
    Eventually solved it by just omitting SerialNumber, i.e.
    SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{serial}=="3f980000.usb", SYMLINK+="ttyUSB99
    I guess that could cause problems if I would attached more similar devices to my RPI, but I don't know if there is any point in having more than one gateway? (unless you have > 255 sensors I guess)
    • N
      N
      nikos1671
      I am new with mysensors and i am trying to make it work with openhab.
      I have a soil sensor and with same copy paste from the forum i manage to sent the value on the openhab, now i am trying to translate the battery level on the opnehab side but i dont know how to do it. can someone help me please?? this is what i get on the openhab 0;0;3;0;9;read: 254-254-0 s=255,c=3,t=0,pt=1,l=1,sg=0:68
      254;255;3;0;0;68 this is the battery value.
      But i am lost on the rule how to decode the message.
      Nikos
        SiLeX
        I also would like to share my working default.rules + examples with you. Hope it can help someone.
        https://gist.github.com/gersilex/13f39b3419427b35636a
        • T
          TimO
          Hi @nikos1671 !
          You need to add an item to the hash map with nodeID 254 and childId 255.
          In the rules section search for
          // Internal Command
                  		    if(msgType == 3){
                  		        if(subType == I_SKETCH_NAME){
                  		                println("Sketch name: " + msg )
                  		                sketchName=msg
                  		        if(subType == I_SKETCH_VERSION){
                  		                println("Sketch version: " + msg )
                  		                postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), sketchName+" " +msg )
                  		                sketchName=""
          As the battery status is an internal message, you need to modify this section. Add an if statement for I_BATTERY_LEVEL.
          For more information about the messages: http://www.mysensors.org/download/serial_api_15
          N 1 Reply Last reply
          • T TimO
            Hi @nikos1671 !
            // Internal Command
                    		    if(msgType == 3){
                    		                sketchName=msg
                    		                sketchName=""
            N
            N
            nikos1671
            @TimO thank you
            • N
              N
              nikos1671
              What i am doing wrong??
              i am using the last rules from silex and i can parse the data from my sensebender temp and hum on openhab but i cannot make it with battery. here is my setup
              // Mappings
              var HashMap<String, String> sensorToItemsMap = newLinkedHashMap(
              "3;1;"                 -> "Temp",
              "Temp"					-> "3;1;",
              "3;2;"                 -> "Hum",
              "Hum"					-> "3;2;",
              "3;255;"                 -> "Batt",
              "Batt"			   		-> "3;255;",
              the rule
              if(msgType == M_INTERNAL){ // Internal Command
              print("(INTERNAL)\t")
              if(subType == I_BATTERY_LEVEL){
              postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), msg)
              println ("Batt item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " Batt: " + msg )
              my.items
              String Arduino "Arduino" { serial="COM3@115200" }
              Number Temp "Temperatur [%.1f °C]" <temperature>
              Number Hum "Feuchtigkeit [%.1f %%]" <temperature>
              Number Batt "bataria [%.1f %%]" <energy>
              and this is the logs of openhab
              20:02:58.954 [DEBUG] [b.serial.internal.SerialDevice:194 ] - Received message '0;0;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF03
              3;255;4;0;0;FFFFFFFFFFFFFFFF0300
              0;0;3;0;9;read: 3-3-0 s=255,c=3,t=11,pt=0,l=17,sg=0:Sensebender Micro
              3;255;3;0;11;Sensebender Micro
              0;0;3;0;9;read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.3
              3;255;3;0;12;1.3
              0;0;3;0;9;read: 3-3-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
              3;1;0;0;6;
              0;0;3;0;9;read: 3-3-0 s=2,c=0,t=7,pt=0,l=0,sg=0:
              3;2;0;0;7;
              0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.6
              3;1;1;0;0;23.6
              0;0;3;0;9;read: 3-3-0 s=2,c=1,t=1,pt=2,l=2,sg=0:53
              3;2;1;0;1;53
              0;0;3;0;9;read: 3-3-0 s=255,c=3,t=0,pt=1,l=1,sg=0:113
              3;255;3;0;0;113
              ' on serial port COM3
              20:02:58.960 [DEBUG] [o.b.f.i.h.FritzahaWebInterface:336 ] - Sending update to item Power_FritzDECTv
              20:02:58.977 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule 'Decode incoming MySensors data'
              20:02:59.101 [ERROR] [o.o.c.s.ScriptExecutionThread :50 ] - Error during the execution of rule 'Decode incoming MySensors data': 5
              Can someone help me please??
              • Dave DanD
                Dave DanD
                Dave Dan
                Hi @nikos1671,
                everytime I had that error was mainly because I forgot / add extra comma in the LinkedHastMap definition or something like that.
                Can you please share the full openHAB rule?
                • N
                  N
                  nikos1671
                  wrote on last edited by nikos1671
                  #56
                  Hi @Dave-Dan ,
                  i think i found the problem. i have 2 sensebender micro one with the original shiped firmaware 1.1 (node1) and one with the new one 1.3 (node3) as you can see in the logs of openhab the node1 its parsing the data on the openhab very good but the node3 throwing an error( Error during the execution of rule 'Decode incoming MySensors data': 5)
                  here is the rule that i use
                  // CONTRIBUTE: Feel free to fork, enhance, pull reqest
                  // SiLeX <gersilex@gmail.com>
                  // IMPORTS //////////////////////////////////////////////////////////////////////////////////////////////////////////
                  import org.openhab.core.library.types.*
                  import org.openhab.core.persistence.*
                  import org.openhab.model.script.actions.*
                  import java.util.HashMap
                  import org.eclipse.xtext.xbase.lib.*
                  import org.openhab.core.items.*
                  // VARS /////////////////////////////////////////////////////////////////////////////////////////////////////////////
                  // MySensors 1.5 ////////////////////////////////////////////////////////////////////////////////////////////////////
                  // MessageTypes  //
                  val int M_PRESENTATION    = 0  // Sent by a node when they present attached sensors. This is usually done in setup() at startup.
                  val int M_SET             = 1  // This message is sent from or to a sensor when a sensor value should be updated
                  val int M_REQ             = 2  // Requests a variable value (usually from an actuator destined for controller).
                  val int M_INTERNAL        = 3  // This is a special internal message. See table below for the details
                  val int M_STREAM          = 4  // Used for OTA firmware updates
                  // SubTypes for MessageType M_PRESENTATION //
                  // (Not used for now, as automatic configuration is not possible in OpenHAB 1.)
                  // val int S_DOOR                     = 0   // Door and window sensors
                  // val int S_MOTION                   = 1   // Motion sensors
                  // val int S_SMOKE                    = 2   // Smoke sensor
                  // val int S_LIGHT                    = 3   // Light Actuator (on/off)
                  // val int S_BINARY                   = 3   // Binary device (on/off), Alias for S_LIGHT
                  // val int S_DIMMER                   = 4   // Dimmable device of some kind
                  // val int S_COVER                    = 5   // Window covers or shades
                  // val int S_TEMP                     = 6   // Temperature sensor
                  // val int S_HUM                      = 7   // Humidity sensor
                  // val int S_BARO                     = 8   // Barometer sensor (Pressure)
                  // val int S_WIND                     = 9   // Wind sensor
                  // val int S_RAIN                     = 10  // Rain sensor
                  // val int S_UV                       = 11  // UV sensor
                  // val int S_WEIGHT                   = 12  // Weight sensor for scales etc.
                  // val int S_POWER                    = 13  // Power measuring device, like power meters
                  // val int S_HEATER                   = 14  // Heater device
                  // val int S_DISTANCE                 = 15  // Distance sensor
                  // val int S_LIGHT_LEVEL              = 16  // Light sensor
                  // val int S_ARDUINO_NODE             = 17  // Arduino node device
                  // val int S_ARDUINO_REPEATER_NODE    = 18  // Arduino repeating node device
                  // val int S_LOCK                     = 19  // Lock device
                  // val int S_IR                       = 20  // Ir sender/receiver device
                  // val int S_WATER                    = 21  // Water meter
                  // val int S_AIR_QUALITY              = 22  // Air quality sensor e.g. MQ-2
                  // val int S_CUSTOM                   = 23  // Use this for custom sensors where no other fits.
                  // val int S_DUST                     = 24  // Dust level sensor
                  // val int S_SCENE_CONTROLLER         = 25  // Scene controller device
                  // val int S_RGB_LIGHT                = 26  // RGB light
                  // val int S_RGBW_LIGHT               = 27  // RGBW light (with separate white component)
                  // val int S_COLOR_SENSOR             = 28  // Color sensor
                  // val int S_HVAC                     = 29  // Thermostat/HVAC device
                  // val int S_MULTIMETER               = 30  // Multimeter device
                  // val int S_SPRINKLER                = 31  // Sprinkler device
                  // val int S_WATER_LEAK               = 32  // Water leak sensor
                  // val int S_SOUND                    = 33  // Sound sensor
                  // val int S_VIBRATION                = 34  // Vibration sensor
                  // val int S_MOISTURE                 = 35  // Moisture sensor
                  // SubTypes for MessageType M_SET //
                  val int V_TEMP                  = 0   // Temperature
                  val int V_HUM                   = 1   // Humidity
                  val int V_STATUS                = 2   // Binary status. 0=off 1=on
                  val int V_LIGHT                 = 2   // Deprecated. Alias for V_STATUS. Light status. 0=off 1=on
                  val int V_PERCENTAGE            = 3   // Percentage value. 0-100 (%)
                  val int V_DIMMER                = 3   // Deprecated. Alias for V_PERCENTAGE. Dimmer value. 0-100 (%)
                  val int V_PRESSURE              = 4   // Atmospheric Pressure
                  val int V_FORECAST              = 5   // Whether forecast. One of "stable", "sunny", "cloudy", "unstable", "thunderstorm" or "unknown"
                  val int V_RAIN                  = 6   // Amount of rain
                  val int V_RAINRATE              = 7   // Rate of rain
                  val int V_WIND                  = 8   // Windspeed
                  val int V_GUST                  = 9   // Gust
                  val int V_DIRECTION             = 10  // Wind direction
                  val int V_UV                    = 11  // UV light level
                  val int V_WEIGHT                = 12  // Weight (for scales etc)
                  val int V_DISTANCE              = 13  // Distance
                  val int V_IMPEDANCE             = 14  // Impedance value
                  val int V_ARMED                 = 15  // Armed status of a security sensor. 1=Armed, 0=Bypassed
                  val int V_TRIPPED               = 16  // Tripped status of a security sensor. 1=Tripped, 0=Untripped
                  val int V_WATT                  = 17  // Watt value for power meters
                  val int V_KWH                   = 18  // Accumulated number of KWH for a power meter
                  val int V_SCENE_ON              = 19  // Turn on a scene
                  val int V_SCENE_OFF             = 20  // Turn of a scene
                  val int V_HVAC_FLOW_STATE       = 21  // Mode of header. One of "Off", "HeatOn", "CoolOn", or "AutoChangeOver"
                  val int V_HVAC_SPEED            = 22  // HVAC/Heater fan speed ("Min", "Normal", "Max", "Auto")
                  val int V_LIGHT_LEVEL           = 23  // Uncalibrated light level. 0-100%. Use V_LEVEL for light level in lux.
                  val int V_VAR1                  = 24  // Custom value
                  val int V_VAR2                  = 25  // Custom value
                  val int V_VAR3                  = 26  // Custom value
                  val int V_VAR4                  = 27  // Custom value
                  val int V_VAR5                  = 28  // Custom value
                  val int V_UP                    = 29  // Window covering. Up.
                  val int V_DOWN                  = 30  // Window covering. Down.
                  val int V_STOP                  = 31  // Window covering. Stop.
                  val int V_IR_SEND               = 32  // Send out an IR-command
                  val int V_IR_RECEIVE            = 33  // This message contains a received IR-command
                  val int V_FLOW                  = 34  // Flow of water (in meter)
                  val int V_VOLUME                = 35  // Water volume
                  val int V_LOCK_STATUS           = 36  // Set or get lock status. 1=Locked, 0=Unlocked
                  val int V_LEVEL                 = 37  // Used for sending level-value
                  val int V_VOLTAGE               = 38  // Voltage level
                  val int V_CURRENT               = 39  // Current level
                  val int V_RGB                   = 40  // RGB value transmitted as ASCII hex string (I.e "ff0000" for red)
                  val int V_RGBW                  = 41  // RGBW value transmitted as ASCII hex string (I.e "ff0000ff" for red + full white)
                  val int V_ID                    = 42  // Optional unique sensor id (e.g. OneWire DS1820b ids)
                  val int V_UNIT_PREFIX           = 43  // Allows sensors to send in a string representing the unit prefix to be displayed in GUI. This is not parsed by controller! E.g. cm, m, km, inch.
                  val int V_HVAC_SETPOINT_COOL    = 44  // HVAC cold setpoint
                  val int V_HVAC_SETPOINT_HEAT    = 45  // HVAC/Heater setpoint
                  val int V_HVAC_FLOW_MODE        = 46  // Flow mode for HVAC ("Auto", "ContinuousOn", "PeriodicOn")
                  // SubTypes for MessageType M_INTERNAL //
                  val int I_BATTERY_LEVEL           = 0   // Use this to report the battery level (in percent 0-100).
                  val int I_TIME                    = 1   // Sensors can request the current time from the Controller using this message. The time will be reported as the seconds since 1970
                  val int I_VERSION                 = 2   // Used to request gateway version from controller.
                  val int I_ID_REQUEST              = 3   // Use this to request a unique node id from the controller.
                  val int I_ID_RESPONSE             = 4   // Id response back to sensor. Payload contains sensor id.
                  val int I_INCLUSION_MODE          = 5   // Start/stop inclusion mode of the Controller (1=start, 0=stop).
                  val int I_CONFIG                  = 6   // Config request from node. Reply with (M)etric or (I)mperal back to sensor.
                  val int I_FIND_PARENT             = 7   // When a sensor starts up, it broadcast a search request to all neighbor nodes. They reply with a I_FIND_PARENT_RESPONSE.
                  val int I_FIND_PARENT_RESPONSE    = 8   // Reply message type to I_FIND_PARENT request.
                  val int I_LOG_MESSAGE             = 9   // Sent by the gateway to the Controller to trace-log a message
                  val int I_CHILDREN                = 10  // A message that can be used to transfer child sensors (from EEPROM routing table) of a repeating node.
                  val int I_SKETCH_NAME             = 11  // Optional sketch name that can be used to identify sensor in the Controller GUI
                  val int I_SKETCH_VERSION          = 12  // Optional sketch version that can be reported to keep track of the version of sensor in the Controller GUI.
                  val int I_REBOOT                  = 13  // Used by OTA firmware updates. Request for node to reboot.
                  val int I_GATEWAY_READY           = 14  // Send by gateway to controller when startup is complete.
                  val int I_REQUEST_SIGNING         = 15  // Used between sensors when initialting signing.
                  val int I_GET_NONCE               = 16  // Used between sensors when requesting nonce.
                  val int I_GET_NONCE_RESPONSE      = 17  // Used between sensors for nonce response.
                  // MySensors 1.5 Configuration
                  // Use the HashMap "sensorToItemsMap" to create a relation between the nodeID
                  // within MySensors and the item name in OpenHAB.
                  // Please note that you must map in both directions, so we can resolve both.
                  // Mappings
                      "3;1;"                 -> "Temp",
                      "Temp"					-> "3;1;",
                  	"3;2;"                 -> "Hum",
                      "Hum"					-> "3;2;",
                  	"3;255;"                 -> "Batt",
                      "Batt"			   		-> "3;255;",
                      "1;1;"                 -> "Temp1",
                      "Temp1"					-> "1;1;",
                  	"1;2;"                 -> "Hum1",
                      "Hum1"					-> "1;2;",
                  	"1;255;"                -> "Battery1",
                      "Battery1"				-> "1;255;",
                  val org.eclipse.xtext.xbase.lib.Functions$Function4 mysensors = [
                      String IDs,
                      int subType,
                      String data,
                      org.openhab.core.library.items.StringItem gw
                      if(!(data instanceof String)) println("\nERROR: data must be String but has " + data.getClass() + "\n")
                      var String new_data
                      if(data == "ON"){
                          new_data = new String("1")
                      else if (data == "OFF"){
                          new_data = new String("0")
                          new_data = new String(data)
                      var String output = IDs + "1;0;" + subType + ";" + new_data + "\n"
                      gw.sendCommand(output)
                  // Notes for this rule
                  // This is all you need to have MySensors set your items.
                  // It's better to hardcode the nodeID on your MySensors sensors,
                  // because openHAB will not assign them nodeIDs.
                  rule "Decode incoming MySensors data"
                      when
                          Item Arduino changed
                      then
                          var String lineBuffer =  Arduino.state.toString.split("\n")
                          for (String line : lineBuffer) {
                              var String[] message = line.split(";")
                              var Integer nodeId = new Integer(message.get(0))
                              var Integer childId = new Integer(message.get(1))
                              var Integer msgType = new Integer(message.get(2))
                              var Integer ack = new Integer(message.get(3))
                              var Integer subType = new Integer(message.get(4))
                              var String msg = message.get(5)
                              var String openhab_item = sensorToItemsMap.get( nodeId + ";" + childId + ";" )
                              if (nodeId != 0){ // internal messages have nodeId 0, but are not used for now
                                  if (openhab_item == null){
                                      println("No item matches nodeId=" + nodeId + ", childId=" + childId + ". Data received: " + msg)
                                  else { // openhab_item != null
                                      print("openhab_item=" + openhab_item + "\t")
                                      print("msgType=" + msgType + " ")
                                      var String newState = msg
                                      if (msgType == M_SET){ // Set Command from or to node
                                          println("(SET)\t subType=" + subType + " ")
                                          if (subType      == V_STATUS ){ if ( new Integer(msg) == 1 ) newState =      "ON" else newState = "OFF" }
                                          if (subType      ==  V_ARMED ){ if ( new Integer(msg) == 1 ) newState =      "ON" else newState = "OFF" }
                                          else if (subType == V_TRIPPED){ if ( new Integer(msg) == 1 ) newState = "OPEN" else newState = "CLOSED" }
                                          else println("No special handler for subType=" + subType + " found. Simply using data as String.")
                                      postUpdate(openhab_item, newState)
                  							println ("Battery1 item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " Battery1: " + msg )
                                  } // openhab_item != null
                  end
                  and here is the logs of openhhab
                  10:37:09.294 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;gateway started, id=0, parent=0, distance=0
                  ' on serial port COM13
                  10:37:10.764 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66   ] - Registering new service _openhab-server-ssl._tcp.local. at port 8443
                  10:37:12.060 [INFO ] [c.internal.ModelRepositoryImpl:80   ] - Loading model 'demo.rules'
                  10:37:13.305 [DEBUG] [.i.LoggingPersistenceActivator:31   ] - Logging persistence bundle has been started.
                  10:37:13.316 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:37:13.347 [DEBUG] [.p.internal.PersistenceManager:147  ] - Initializing logging persistence service.
                  10:37:13.369 [DEBUG] [.zwave.internal.ZWaveActivator:36   ] - Z-Wave binding started. Version 1.7.1
                  10:37:13.424 [DEBUG] [.z.internal.ZWaveActiveBinding:175  ] - ConverterHandler not initialised. Polling disabled.
                  10:37:13.424 [INFO ] [.z.internal.ZWaveActiveBinding:317  ] - ZWave 'updated' with null config
                  10:37:14.156 [DEBUG] [riptExtensionClassNameProvider:63   ] - Script actions have changed: PingActionService, AudioActionService, HTTPActionService, TransformationActionService, ExecActionService,
                  10:37:34.145 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.4.1
                  1;255;0;0;17;1.4.1
                  0;0;3;0;9;read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  1;255;3;0;6;0
                  10:37:34.145 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:37:36.179 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=17,sg=0:Sensebender Micro
                  1;255;3;0;11;Sensebender Micro
                  0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                  1;255;3;0;12;1.1
                  0;0;3;0;9;read: 1-1-0 s=1,c=0,t=6,pt=0,l=5,sg=0:1.4.1
                  1;1;0;0;6;1.4.1
                  0;0;3;0;9;read: 1-1-0 s=2,c=0,t=7,pt=0,l=5,sg=0:1.4.1
                  1;2;0;0;7;1.4.1
                  0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:80
                  1;255;3;0;0;80
                  0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.2
                  1;1;1;0;0;22.2
                  0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:47
                  1;2;1;0;1;47
                  10:37:36.179 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:37:47.968 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
                  3;255;0;0;17;1.5
                  0;0;3;0;9;read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  3;255;3;0;6;0
                  10:37:47.968 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:37:50.078 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF03
                  3;255;3;0;12;1.3
                  3;1;0;0;6;
                  3;2;0;0;7;
                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.2
                  3;1;1;0;0;22.2
                  0;0;3;0;9;read: 3-3-0 s=2,c=1,t=1,pt=2,l=2,sg=0:48
                  3;2;1;0;1;48
                  0;0;3;0;9;read: 3-3-0 s=255,c=3,t=0,pt=1,l=1,sg=0:75
                  3;255;3;0;0;75
                  10:37:50.078 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:37:50.158 [ERROR] [o.o.c.s.ScriptExecutionThread :50   ] - Error during the execution of rule 'Decode incoming MySensors data': 5
                  10:38:42.965 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:82
                  1;255;3;0;0;82
                  0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.1
                  1;1;1;0;0;22.1
                  0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:46
                  1;2;1;0;1;46
                  10:38:42.965 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:39:49.716 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.1
                  1;1;1;0;0;22.1
                  1;2;1;0;1;46
                  10:40:40.851 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:40:56.432 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.2
                  1;1;1;0;0;22.2
                  0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:48
                  1;2;1;0;1;48
                  10:40:56.432 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:41:04.095 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.2
                  3;1;1;0;0;24.2
                  0;0;3;0;9;read: 3-3-0 s=2,c=1,t=1,pt=2,l=2,sg=0:76
                  3;2;1;0;1;76
                  10:41:04.095 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:42:03.228 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.2
                  1;1;1;0;0;22.2
                  10:42:03.230 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:42:03.437 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:47
                  1;2;1;0;1;47
                  10:42:03.437 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:42:08.798 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.5
                  3;1;1;0;0;23.5
                  0;0;3;0;9;read: 3-3-0 s=2,c=1,t=1,pt=2,l=2,sg=0:50
                  3;2;1;0;1;50
                  10:42:08.798 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:43:10.504 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.1
                  1;1;1;0;0;22.1
                  1;2;1;0;1;46
                  10:43:10.504 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:43:13.496 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.2
                  3;1;1;0;0;23.2
                  3;2;1;0;1;48
                  10:43:13.496 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:44:17.497 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
                  1;1;1;0;0;22.0
                  10:44:17.500 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:44:18.176 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.8
                  3;1;1;0;0;22.8
                  0;0;3;0;9;read: 3-3-0 s=2,c=1,t=1,pt=2,l=2,sg=0:46
                  3;2;1;0;1;46
                  10:44:18.176 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:45:24.715 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
                  1;1;1;0;0;22.0
                  1;2;1;0;1;46
                  10:45:24.717 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:46:31.704 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.9
                  1;1;1;0;0;21.9
                  10:46:31.706 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:47:32.139 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.3
                  3;1;1;0;0;22.3
                  3;2;1;0;1;46
                  10:47:32.141 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:47:38.937 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.9
                  1;1;1;0;0;21.9
                  1;2;1;0;1;46
                  10:47:38.939 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:48:46.058 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:46
                  1;2;1;0;1;46
                  10:48:46.060 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:49:53.042 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.9
                  1;1;1;0;0;21.9
                  10:49:53.044 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:51:00.209 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:82
                  1;255;3;0;0;82
                  1;1;1;0;0;22.0
                  10:51:00.211 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:51:00.424 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:46
                  1;2;1;0;1;46
                  10:51:00.426 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:52:07.248 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:82
                  1;255;3;0;0;82
                  10:52:07.249 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  10:52:07.640 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.9
                  1;1;1;0;0;21.9
                  1;2;1;0;1;46
                  10:52:07.640 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                  The rule react fast and fill all the data (temp,hum,bat) on the openhab site for the node with the old firmware but with the new frimware i connect the batteries on the sensor and i must wait some minutes until the temp and hum appear on th site but the battery percent not,only after hours
                  Nikos
                  • Dave DanD
                    Dave DanD
                    Dave Dan
                    hey @nikos1671,
                    good to hear you have it under control.
                    Also, please take a look to the 'sensorToItemsMap' definition. If I remember correctly, the last item in the last item, otherwise the compiler is waiting for another item.
                    This is something that happened to me every time I include any new item (you know, copy & paste ... bad thing :P).
                    The fact that you have to wait hours to get the battery status is odd. When I restart one of my nodes ( one with battery level) I have the information inmediately available, well ... as soon as the node sends the information, and fully refreshed in openhab site.
                    it's true I've had different update speeds but basically because I did my first tests with ah Raspberry Pi 1 and now I have all the system working in a Pi 2 ... so goes faster (very much).
                      SiLeX
                      Hey guys, on my Raspberry Pi 2 the first rule execution takes about 15 seconds. If you have changed the rules file, the xtent logic has to be re-compiled to java code again. But after the first rule execution it takes only about 10-50ms for execution.
                      Also, @nikos1671 I would turn off the DEBUG mode on your gateway. Receiving data works and this is what you would debug. You see incoming data without debug, too so you can securely get rid of it :grin:
                      • N
                        N
                        nikos1671
                        Hi ,
                        I think the problem is this msg 3;255;4;0;0;FFFFFFFFFFFFFFFF0300 is this something with the OTA firmware? i think the rule dont recognise this msg and give an error (Error during the execution of rule 'Decode incoming MySensors data': 5). Can the author of the rule please confirm if this it the problem of the error??
                        S 1 Reply Last reply
                        • N nikos1671
                          Hi ,
                          SiLeX
                          wrote on last edited by SiLeX
                          #60
                          @nikos1671 In case of unhandled messages (when there is no openhab item assigned to this nodeID;childID;-combination in your sensorToItemsMap), they will just be ignored (and print the data field).
                          This happens here in the code: https://gist.github.com/gersilex/13f39b3419427b35636a#file-default-rules-L211
                          This will look like this:
                          No item matches nodeId=3, childId=255. Data received: FFFFFFFFFFFFFFFF0300
                          However, this was never tested with debugging enabled on the Gateway. This is why I asked you to disable debugging and recompile/reupload the code to your gateway arduino without the DEBUG flag inside MyConfig.h.
                          There is a know problem which is not catched currently:
                          • Data can only be decoded, if the String has exactly 6 fields, seperated by a semicolon.
                          Please go and try to disable the DEBUG on your gateway arduino.
                          • HenryWhiteH
                            HenryWhiteH
                            HenryWhite
                            Can someone help me? I want to integrate a motion sensor in OpenHAB but I don't know how to distinguish between the motion start and end. here's my openhab console log:
                            • HenryWhiteH
                              HenryWhiteH
                              HenryWhite
                              Can somebody help..?
                              • Dave DanD
                                Dave DanD
                                Dave Dan
                                Try removing DEBUG in the Serial GW and review messages.
                                I receive a 0 or 1 depending if the motion is detected or the sensor is resetting to normal status.
                                HenryWhiteH 1 Reply Last reply
                                • Dave DanD Dave Dan
                                  HenryWhiteH
                                  HenryWhiteH
                                  HenryWhite
                                  @Dave-Dan i tried it, but the motion sensor is still sending only zero's.... even if it is not triggered.
                                  I got these motion sensors: http://www.amazon.de/Pyroelectrische-Infrarot-Bewegung-Sensor-Detektor/dp/B008AESDSY/
                                  • HenryWhiteH
                                    HenryWhiteH
                                    HenryWhite
                                    When I look at the serial monitor output for my motion sensor, it clearly gives me a "0" or "1" depending if movement is detected or not.
                                    But when I look at the serial monitor of my gateway, it only receives the same message no matter if motion started (motion sensor serial monitor: 1) or ended (motion sensor serial monitor: 0)
                                    • T
                                      TimO
                                      @HenryWhite The node is requesting for an id and not sending any status. You'll need to define a static id in the sketch of your node:
                                      http://www.mysensors.org/download/sensor_api_15#the-full-api
                                      Look for "Starting up the library" and the "begin()" function.
                                      • T TimO
                                        HenryWhiteH
                                        HenryWhiteH
                                        HenryWhite
                                        @TimO thank you so much! it works now. Any idea why i had to assign a static id? i thought the gateway should tell the node a dynamic id automatically..
                                        • T
                                          TimO
                                          @HenryWhite You're welcome. The id is assigned by the controller, in your case OpenHAB. There is a post in the forum about how to add a rule for id assignment, but I don't use it myself.
