  3. OpenHAB
  4. [Tutorial] openHAB with serial gateway
78 Posts 25 Posters 87.8k Views 16 Watching
  • N
    N
    nikos1671
    I am new with mysensors and i am trying to make it work with openhab.
    I have a soil sensor and with same copy paste from the forum i manage to sent the value on the openhab, now i am trying to translate the battery level on the opnehab side but i dont know how to do it. can someone help me please?? this is what i get on the openhab 0;0;3;0;9;read: 254-254-0 s=255,c=3,t=0,pt=1,l=1,sg=0:68
    254;255;3;0;0;68 this is the battery value.
    But i am lost on the rule how to decode the message.
    Nikos
      SiLeX
      I also would like to share my working default.rules + examples with you. Hope it can help someone.
      https://gist.github.com/gersilex/13f39b3419427b35636a
      • T
        TimO
        Hi @nikos1671 !
        You need to add an item to the hash map with nodeID 254 and childId 255.
        In the rules section search for
        // Internal Command
                		    if(msgType == 3){
                		        if(subType == I_SKETCH_NAME){
                		                println("Sketch name: " + msg )
                		                sketchName=msg
                		        if(subType == I_SKETCH_VERSION){
                		                println("Sketch version: " + msg )
                		                postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), sketchName+" " +msg )
                		                sketchName=""
        As the battery status is an internal message, you need to modify this section. Add an if statement for I_BATTERY_LEVEL.
        For more information about the messages: http://www.mysensors.org/download/serial_api_15
        N 1 Reply Last reply
        • T TimO
          Hi @nikos1671 !
          // Internal Command
                  		    if(msgType == 3){
                  		                sketchName=msg
                  		                sketchName=""
          N
          N
          nikos1671
          @TimO thank you
          • N
            N
            nikos1671
            What i am doing wrong??
            i am using the last rules from silex and i can parse the data from my sensebender temp and hum on openhab but i cannot make it with battery. here is my setup
            // Mappings
            var HashMap<String, String> sensorToItemsMap = newLinkedHashMap(
            "3;1;"                 -> "Temp",
            "Temp"					-> "3;1;",
            "3;2;"                 -> "Hum",
            "Hum"					-> "3;2;",
            "3;255;"                 -> "Batt",
            "Batt"			   		-> "3;255;",
            the rule
            if(msgType == M_INTERNAL){ // Internal Command
            print("(INTERNAL)\t")
            if(subType == I_BATTERY_LEVEL){
            postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), msg)
            println ("Batt item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " Batt: " + msg )
            my.items
            String Arduino "Arduino" { serial="COM3@115200" }
            Number Temp "Temperatur [%.1f °C]" <temperature>
            Number Hum "Feuchtigkeit [%.1f %%]" <temperature>
            Number Batt "bataria [%.1f %%]" <energy>
            and this is the logs of openhab
            20:02:58.954 [DEBUG] [b.serial.internal.SerialDevice:194 ] - Received message '0;0;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF03
            3;255;4;0;0;FFFFFFFFFFFFFFFF0300
            0;0;3;0;9;read: 3-3-0 s=255,c=3,t=11,pt=0,l=17,sg=0:Sensebender Micro
            3;255;3;0;11;Sensebender Micro
            0;0;3;0;9;read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.3
            3;255;3;0;12;1.3
            0;0;3;0;9;read: 3-3-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
            3;1;0;0;6;
            0;0;3;0;9;read: 3-3-0 s=2,c=0,t=7,pt=0,l=0,sg=0:
            3;2;0;0;7;
            0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.6
            3;1;1;0;0;23.6
            0;0;3;0;9;read: 3-3-0 s=2,c=1,t=1,pt=2,l=2,sg=0:53
            3;2;1;0;1;53
            0;0;3;0;9;read: 3-3-0 s=255,c=3,t=0,pt=1,l=1,sg=0:113
            3;255;3;0;0;113
            ' on serial port COM3
            20:02:58.960 [DEBUG] [o.b.f.i.h.FritzahaWebInterface:336 ] - Sending update to item Power_FritzDECTv
            20:02:58.977 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule 'Decode incoming MySensors data'
            20:02:59.101 [ERROR] [o.o.c.s.ScriptExecutionThread :50 ] - Error during the execution of rule 'Decode incoming MySensors data': 5
            Can someone help me please??
            • Dave DanD
              Dave DanD
              Dave Dan
              Hi @nikos1671,
              everytime I had that error was mainly because I forgot / add extra comma in the LinkedHastMap definition or something like that.
              Can you please share the full openHAB rule?
              • N
                N
                nikos1671
                wrote on last edited by nikos1671
                #56
                Hi @Dave-Dan ,
                i think i found the problem. i have 2 sensebender micro one with the original shiped firmaware 1.1 (node1) and one with the new one 1.3 (node3) as you can see in the logs of openhab the node1 its parsing the data on the openhab very good but the node3 throwing an error( Error during the execution of rule 'Decode incoming MySensors data': 5)
                here is the rule that i use
                // CONTRIBUTE: Feel free to fork, enhance, pull reqest
                // SiLeX <gersilex@gmail.com>
                // IMPORTS //////////////////////////////////////////////////////////////////////////////////////////////////////////
                import org.openhab.core.library.types.*
                import org.openhab.core.persistence.*
                import org.openhab.model.script.actions.*
                import java.util.HashMap
                import org.eclipse.xtext.xbase.lib.*
                import org.openhab.core.items.*
                // VARS /////////////////////////////////////////////////////////////////////////////////////////////////////////////
                // MySensors 1.5 ////////////////////////////////////////////////////////////////////////////////////////////////////
                // MessageTypes  //
                val int M_PRESENTATION    = 0  // Sent by a node when they present attached sensors. This is usually done in setup() at startup.
                val int M_SET             = 1  // This message is sent from or to a sensor when a sensor value should be updated
                val int M_REQ             = 2  // Requests a variable value (usually from an actuator destined for controller).
                val int M_INTERNAL        = 3  // This is a special internal message. See table below for the details
                val int M_STREAM          = 4  // Used for OTA firmware updates
                // SubTypes for MessageType M_PRESENTATION //
                // (Not used for now, as automatic configuration is not possible in OpenHAB 1.)
                // val int S_DOOR                     = 0   // Door and window sensors
                // val int S_MOTION                   = 1   // Motion sensors
                // val int S_SMOKE                    = 2   // Smoke sensor
                // val int S_LIGHT                    = 3   // Light Actuator (on/off)
                // val int S_BINARY                   = 3   // Binary device (on/off), Alias for S_LIGHT
                // val int S_DIMMER                   = 4   // Dimmable device of some kind
                // val int S_COVER                    = 5   // Window covers or shades
                // val int S_TEMP                     = 6   // Temperature sensor
                // val int S_HUM                      = 7   // Humidity sensor
                // val int S_BARO                     = 8   // Barometer sensor (Pressure)
                // val int S_WIND                     = 9   // Wind sensor
                // val int S_RAIN                     = 10  // Rain sensor
                // val int S_UV                       = 11  // UV sensor
                // val int S_WEIGHT                   = 12  // Weight sensor for scales etc.
                // val int S_POWER                    = 13  // Power measuring device, like power meters
                // val int S_HEATER                   = 14  // Heater device
                // val int S_DISTANCE                 = 15  // Distance sensor
                // val int S_LIGHT_LEVEL              = 16  // Light sensor
                // val int S_ARDUINO_NODE             = 17  // Arduino node device
                // val int S_ARDUINO_REPEATER_NODE    = 18  // Arduino repeating node device
                // val int S_LOCK                     = 19  // Lock device
                // val int S_IR                       = 20  // Ir sender/receiver device
                // val int S_WATER                    = 21  // Water meter
                // val int S_AIR_QUALITY              = 22  // Air quality sensor e.g. MQ-2
                // val int S_CUSTOM                   = 23  // Use this for custom sensors where no other fits.
                // val int S_DUST                     = 24  // Dust level sensor
                // val int S_SCENE_CONTROLLER         = 25  // Scene controller device
                // val int S_RGB_LIGHT                = 26  // RGB light
                // val int S_RGBW_LIGHT               = 27  // RGBW light (with separate white component)
                // val int S_COLOR_SENSOR             = 28  // Color sensor
                // val int S_HVAC                     = 29  // Thermostat/HVAC device
                // val int S_MULTIMETER               = 30  // Multimeter device
                // val int S_SPRINKLER                = 31  // Sprinkler device
                // val int S_WATER_LEAK               = 32  // Water leak sensor
                // val int S_SOUND                    = 33  // Sound sensor
                // val int S_VIBRATION                = 34  // Vibration sensor
                // val int S_MOISTURE                 = 35  // Moisture sensor
                // SubTypes for MessageType M_SET //
                val int V_TEMP                  = 0   // Temperature
                val int V_HUM                   = 1   // Humidity
                val int V_STATUS                = 2   // Binary status. 0=off 1=on
                val int V_LIGHT                 = 2   // Deprecated. Alias for V_STATUS. Light status. 0=off 1=on
                val int V_PERCENTAGE            = 3   // Percentage value. 0-100 (%)
                val int V_DIMMER                = 3   // Deprecated. Alias for V_PERCENTAGE. Dimmer value. 0-100 (%)
                val int V_PRESSURE              = 4   // Atmospheric Pressure
                val int V_FORECAST              = 5   // Whether forecast. One of "stable", "sunny", "cloudy", "unstable", "thunderstorm" or "unknown"
                val int V_RAIN                  = 6   // Amount of rain
                val int V_RAINRATE              = 7   // Rate of rain
                val int V_WIND                  = 8   // Windspeed
                val int V_GUST                  = 9   // Gust
                val int V_DIRECTION             = 10  // Wind direction
                val int V_UV                    = 11  // UV light level
                val int V_WEIGHT                = 12  // Weight (for scales etc)
                val int V_DISTANCE              = 13  // Distance
                val int V_IMPEDANCE             = 14  // Impedance value
                val int V_ARMED                 = 15  // Armed status of a security sensor. 1=Armed, 0=Bypassed
                val int V_TRIPPED               = 16  // Tripped status of a security sensor. 1=Tripped, 0=Untripped
                val int V_WATT                  = 17  // Watt value for power meters
                val int V_KWH                   = 18  // Accumulated number of KWH for a power meter
                val int V_SCENE_ON              = 19  // Turn on a scene
                val int V_SCENE_OFF             = 20  // Turn of a scene
                val int V_HVAC_FLOW_STATE       = 21  // Mode of header. One of "Off", "HeatOn", "CoolOn", or "AutoChangeOver"
                val int V_HVAC_SPEED            = 22  // HVAC/Heater fan speed ("Min", "Normal", "Max", "Auto")
                val int V_LIGHT_LEVEL           = 23  // Uncalibrated light level. 0-100%. Use V_LEVEL for light level in lux.
                val int V_VAR1                  = 24  // Custom value
                val int V_VAR2                  = 25  // Custom value
                val int V_VAR3                  = 26  // Custom value
                val int V_VAR4                  = 27  // Custom value
                val int V_VAR5                  = 28  // Custom value
                val int V_UP                    = 29  // Window covering. Up.
                val int V_DOWN                  = 30  // Window covering. Down.
                val int V_STOP                  = 31  // Window covering. Stop.
                val int V_IR_SEND               = 32  // Send out an IR-command
                val int V_IR_RECEIVE            = 33  // This message contains a received IR-command
                val int V_FLOW                  = 34  // Flow of water (in meter)
                val int V_VOLUME                = 35  // Water volume
                val int V_LOCK_STATUS           = 36  // Set or get lock status. 1=Locked, 0=Unlocked
                val int V_LEVEL                 = 37  // Used for sending level-value
                val int V_VOLTAGE               = 38  // Voltage level
                val int V_CURRENT               = 39  // Current level
                val int V_RGB                   = 40  // RGB value transmitted as ASCII hex string (I.e "ff0000" for red)
                val int V_RGBW                  = 41  // RGBW value transmitted as ASCII hex string (I.e "ff0000ff" for red + full white)
                val int V_ID                    = 42  // Optional unique sensor id (e.g. OneWire DS1820b ids)
                val int V_UNIT_PREFIX           = 43  // Allows sensors to send in a string representing the unit prefix to be displayed in GUI. This is not parsed by controller! E.g. cm, m, km, inch.
                val int V_HVAC_SETPOINT_COOL    = 44  // HVAC cold setpoint
                val int V_HVAC_SETPOINT_HEAT    = 45  // HVAC/Heater setpoint
                val int V_HVAC_FLOW_MODE        = 46  // Flow mode for HVAC ("Auto", "ContinuousOn", "PeriodicOn")
                // SubTypes for MessageType M_INTERNAL //
                val int I_BATTERY_LEVEL           = 0   // Use this to report the battery level (in percent 0-100).
                val int I_TIME                    = 1   // Sensors can request the current time from the Controller using this message. The time will be reported as the seconds since 1970
                val int I_VERSION                 = 2   // Used to request gateway version from controller.
                val int I_ID_REQUEST              = 3   // Use this to request a unique node id from the controller.
                val int I_ID_RESPONSE             = 4   // Id response back to sensor. Payload contains sensor id.
                val int I_INCLUSION_MODE          = 5   // Start/stop inclusion mode of the Controller (1=start, 0=stop).
                val int I_CONFIG                  = 6   // Config request from node. Reply with (M)etric or (I)mperal back to sensor.
                val int I_FIND_PARENT             = 7   // When a sensor starts up, it broadcast a search request to all neighbor nodes. They reply with a I_FIND_PARENT_RESPONSE.
                val int I_FIND_PARENT_RESPONSE    = 8   // Reply message type to I_FIND_PARENT request.
                val int I_LOG_MESSAGE             = 9   // Sent by the gateway to the Controller to trace-log a message
                val int I_CHILDREN                = 10  // A message that can be used to transfer child sensors (from EEPROM routing table) of a repeating node.
                val int I_SKETCH_NAME             = 11  // Optional sketch name that can be used to identify sensor in the Controller GUI
                val int I_SKETCH_VERSION          = 12  // Optional sketch version that can be reported to keep track of the version of sensor in the Controller GUI.
                val int I_REBOOT                  = 13  // Used by OTA firmware updates. Request for node to reboot.
                val int I_GATEWAY_READY           = 14  // Send by gateway to controller when startup is complete.
                val int I_REQUEST_SIGNING         = 15  // Used between sensors when initialting signing.
                val int I_GET_NONCE               = 16  // Used between sensors when requesting nonce.
                val int I_GET_NONCE_RESPONSE      = 17  // Used between sensors for nonce response.
                // MySensors 1.5 Configuration
                // Use the HashMap "sensorToItemsMap" to create a relation between the nodeID
                // within MySensors and the item name in OpenHAB.
                // Please note that you must map in both directions, so we can resolve both.
                // Mappings
                    "3;1;"                 -> "Temp",
                    "Temp"					-> "3;1;",
                	"3;2;"                 -> "Hum",
                    "Hum"					-> "3;2;",
                	"3;255;"                 -> "Batt",
                    "Batt"			   		-> "3;255;",
                    "1;1;"                 -> "Temp1",
                    "Temp1"					-> "1;1;",
                	"1;2;"                 -> "Hum1",
                    "Hum1"					-> "1;2;",
                	"1;255;"                -> "Battery1",
                    "Battery1"				-> "1;255;",
                val org.eclipse.xtext.xbase.lib.Functions$Function4 mysensors = [
                    String IDs,
                    int subType,
                    String data,
                    org.openhab.core.library.items.StringItem gw
                    if(!(data instanceof String)) println("\nERROR: data must be String but has " + data.getClass() + "\n")
                    var String new_data
                    if(data == "ON"){
                        new_data = new String("1")
                    else if (data == "OFF"){
                        new_data = new String("0")
                        new_data = new String(data)
                    var String output = IDs + "1;0;" + subType + ";" + new_data + "\n"
                    gw.sendCommand(output)
                // Notes for this rule
                // This is all you need to have MySensors set your items.
                // It's better to hardcode the nodeID on your MySensors sensors,
                // because openHAB will not assign them nodeIDs.
                rule "Decode incoming MySensors data"
                    when
                        Item Arduino changed
                    then
                        var String lineBuffer =  Arduino.state.toString.split("\n")
                        for (String line : lineBuffer) {
                            var String[] message = line.split(";")
                            var Integer nodeId = new Integer(message.get(0))
                            var Integer childId = new Integer(message.get(1))
                            var Integer msgType = new Integer(message.get(2))
                            var Integer ack = new Integer(message.get(3))
                            var Integer subType = new Integer(message.get(4))
                            var String msg = message.get(5)
                            var String openhab_item = sensorToItemsMap.get( nodeId + ";" + childId + ";" )
                            if (nodeId != 0){ // internal messages have nodeId 0, but are not used for now
                                if (openhab_item == null){
                                    println("No item matches nodeId=" + nodeId + ", childId=" + childId + ". Data received: " + msg)
                                else { // openhab_item != null
                                    print("openhab_item=" + openhab_item + "\t")
                                    print("msgType=" + msgType + " ")
                                    var String newState = msg
                                    if (msgType == M_SET){ // Set Command from or to node
                                        println("(SET)\t subType=" + subType + " ")
                                        if (subType      == V_STATUS ){ if ( new Integer(msg) == 1 ) newState =      "ON" else newState = "OFF" }
                                        if (subType      ==  V_ARMED ){ if ( new Integer(msg) == 1 ) newState =      "ON" else newState = "OFF" }
                                        else if (subType == V_TRIPPED){ if ( new Integer(msg) == 1 ) newState = "OPEN" else newState = "CLOSED" }
                                        else println("No special handler for subType=" + subType + " found. Simply using data as String.")
                                    postUpdate(openhab_item, newState)
                							println ("Battery1 item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " Battery1: " + msg )
                                } // openhab_item != null
                end
                and here is the logs of openhhab
                10:37:09.294 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;gateway started, id=0, parent=0, distance=0
                ' on serial port COM13
                10:37:10.764 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66   ] - Registering new service _openhab-server-ssl._tcp.local. at port 8443
                10:37:12.060 [INFO ] [c.internal.ModelRepositoryImpl:80   ] - Loading model 'demo.rules'
                10:37:13.305 [DEBUG] [.i.LoggingPersistenceActivator:31   ] - Logging persistence bundle has been started.
                10:37:13.316 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:37:13.347 [DEBUG] [.p.internal.PersistenceManager:147  ] - Initializing logging persistence service.
                10:37:13.369 [DEBUG] [.zwave.internal.ZWaveActivator:36   ] - Z-Wave binding started. Version 1.7.1
                10:37:13.424 [DEBUG] [.z.internal.ZWaveActiveBinding:175  ] - ConverterHandler not initialised. Polling disabled.
                10:37:13.424 [INFO ] [.z.internal.ZWaveActiveBinding:317  ] - ZWave 'updated' with null config
                10:37:14.156 [DEBUG] [riptExtensionClassNameProvider:63   ] - Script actions have changed: PingActionService, AudioActionService, HTTPActionService, TransformationActionService, ExecActionService,
                10:37:34.145 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.4.1
                1;255;0;0;17;1.4.1
                0;0;3;0;9;read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                1;255;3;0;6;0
                10:37:34.145 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:37:36.179 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=17,sg=0:Sensebender Micro
                1;255;3;0;11;Sensebender Micro
                0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                1;255;3;0;12;1.1
                0;0;3;0;9;read: 1-1-0 s=1,c=0,t=6,pt=0,l=5,sg=0:1.4.1
                1;1;0;0;6;1.4.1
                0;0;3;0;9;read: 1-1-0 s=2,c=0,t=7,pt=0,l=5,sg=0:1.4.1
                1;2;0;0;7;1.4.1
                0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:80
                1;255;3;0;0;80
                0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.2
                1;1;1;0;0;22.2
                0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:47
                1;2;1;0;1;47
                10:37:36.179 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:37:47.968 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
                3;255;0;0;17;1.5
                0;0;3;0;9;read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                3;255;3;0;6;0
                10:37:47.968 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:37:50.078 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF03
                3;255;3;0;12;1.3
                3;1;0;0;6;
                3;2;0;0;7;
                0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.2
                3;1;1;0;0;22.2
                0;0;3;0;9;read: 3-3-0 s=2,c=1,t=1,pt=2,l=2,sg=0:48
                3;2;1;0;1;48
                0;0;3;0;9;read: 3-3-0 s=255,c=3,t=0,pt=1,l=1,sg=0:75
                3;255;3;0;0;75
                10:37:50.078 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:37:50.158 [ERROR] [o.o.c.s.ScriptExecutionThread :50   ] - Error during the execution of rule 'Decode incoming MySensors data': 5
                10:38:42.965 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:82
                1;255;3;0;0;82
                0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.1
                1;1;1;0;0;22.1
                0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:46
                1;2;1;0;1;46
                10:38:42.965 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:39:49.716 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.1
                1;1;1;0;0;22.1
                1;2;1;0;1;46
                10:40:40.851 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:40:56.432 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.2
                1;1;1;0;0;22.2
                0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:48
                1;2;1;0;1;48
                10:40:56.432 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:41:04.095 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.2
                3;1;1;0;0;24.2
                0;0;3;0;9;read: 3-3-0 s=2,c=1,t=1,pt=2,l=2,sg=0:76
                3;2;1;0;1;76
                10:41:04.095 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:42:03.228 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.2
                1;1;1;0;0;22.2
                10:42:03.230 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:42:03.437 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:47
                1;2;1;0;1;47
                10:42:03.437 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:42:08.798 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.5
                3;1;1;0;0;23.5
                0;0;3;0;9;read: 3-3-0 s=2,c=1,t=1,pt=2,l=2,sg=0:50
                3;2;1;0;1;50
                10:42:08.798 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:43:10.504 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.1
                1;1;1;0;0;22.1
                1;2;1;0;1;46
                10:43:10.504 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:43:13.496 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.2
                3;1;1;0;0;23.2
                3;2;1;0;1;48
                10:43:13.496 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:44:17.497 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
                1;1;1;0;0;22.0
                10:44:17.500 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:44:18.176 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.8
                3;1;1;0;0;22.8
                0;0;3;0;9;read: 3-3-0 s=2,c=1,t=1,pt=2,l=2,sg=0:46
                3;2;1;0;1;46
                10:44:18.176 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:45:24.715 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
                1;1;1;0;0;22.0
                1;2;1;0;1;46
                10:45:24.717 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:46:31.704 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.9
                1;1;1;0;0;21.9
                10:46:31.706 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:47:32.139 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.3
                3;1;1;0;0;22.3
                3;2;1;0;1;46
                10:47:32.141 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:47:38.937 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.9
                1;1;1;0;0;21.9
                1;2;1;0;1;46
                10:47:38.939 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:48:46.058 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:46
                1;2;1;0;1;46
                10:48:46.060 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:49:53.042 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.9
                1;1;1;0;0;21.9
                10:49:53.044 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:51:00.209 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:82
                1;255;3;0;0;82
                1;1;1;0;0;22.0
                10:51:00.211 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:51:00.424 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:46
                1;2;1;0;1;46
                10:51:00.426 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:52:07.248 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:82
                1;255;3;0;0;82
                10:52:07.249 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                10:52:07.640 [DEBUG] [b.serial.internal.SerialDevice:194  ] - Received message '0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.9
                1;1;1;0;0;21.9
                1;2;1;0;1;46
                10:52:07.640 [DEBUG] [m.r.internal.engine.RuleEngine:305  ] - Executing rule 'Decode incoming MySensors data'
                The rule react fast and fill all the data (temp,hum,bat) on the openhab site for the node with the old firmware but with the new frimware i connect the batteries on the sensor and i must wait some minutes until the temp and hum appear on th site but the battery percent not,only after hours
                Nikos
                • Dave DanD
                  Dave DanD
                  Dave Dan
                  hey @nikos1671,
                  good to hear you have it under control.
                  Also, please take a look to the 'sensorToItemsMap' definition. If I remember correctly, the last item in the last item, otherwise the compiler is waiting for another item.
                  This is something that happened to me every time I include any new item (you know, copy & paste ... bad thing :P).
                  The fact that you have to wait hours to get the battery status is odd. When I restart one of my nodes ( one with battery level) I have the information inmediately available, well ... as soon as the node sends the information, and fully refreshed in openhab site.
                  it's true I've had different update speeds but basically because I did my first tests with ah Raspberry Pi 1 and now I have all the system working in a Pi 2 ... so goes faster (very much).
                    SiLeX
                    Hey guys, on my Raspberry Pi 2 the first rule execution takes about 15 seconds. If you have changed the rules file, the xtent logic has to be re-compiled to java code again. But after the first rule execution it takes only about 10-50ms for execution.
                    Also, @nikos1671 I would turn off the DEBUG mode on your gateway. Receiving data works and this is what you would debug. You see incoming data without debug, too so you can securely get rid of it :grin:
                    • N
                      N
                      nikos1671
                      Hi ,
                      I think the problem is this msg 3;255;4;0;0;FFFFFFFFFFFFFFFF0300 is this something with the OTA firmware? i think the rule dont recognise this msg and give an error (Error during the execution of rule 'Decode incoming MySensors data': 5). Can the author of the rule please confirm if this it the problem of the error??
                      S 1 Reply Last reply
                      • N nikos1671
                        Hi ,
                        SiLeX
                        wrote on last edited by SiLeX
                        #60
                        @nikos1671 In case of unhandled messages (when there is no openhab item assigned to this nodeID;childID;-combination in your sensorToItemsMap), they will just be ignored (and print the data field).
                        This happens here in the code: https://gist.github.com/gersilex/13f39b3419427b35636a#file-default-rules-L211
                        This will look like this:
                        No item matches nodeId=3, childId=255. Data received: FFFFFFFFFFFFFFFF0300
                        However, this was never tested with debugging enabled on the Gateway. This is why I asked you to disable debugging and recompile/reupload the code to your gateway arduino without the DEBUG flag inside MyConfig.h.
                        There is a know problem which is not catched currently:
                        • Data can only be decoded, if the String has exactly 6 fields, seperated by a semicolon.
                        Please go and try to disable the DEBUG on your gateway arduino.
                        • HenryWhiteH
                          HenryWhiteH
                          HenryWhite
                          Can someone help me? I want to integrate a motion sensor in OpenHAB but I don't know how to distinguish between the motion start and end. here's my openhab console log:
                          • HenryWhiteH
                            HenryWhiteH
                            HenryWhite
                            Can somebody help..?
                            • Dave DanD
                              Dave DanD
                              Dave Dan
                              Try removing DEBUG in the Serial GW and review messages.
                              I receive a 0 or 1 depending if the motion is detected or the sensor is resetting to normal status.
                              HenryWhiteH 1 Reply Last reply
                              • Dave DanD Dave Dan
                                HenryWhiteH
                                HenryWhiteH
                                HenryWhite
                                @Dave-Dan i tried it, but the motion sensor is still sending only zero's.... even if it is not triggered.
                                I got these motion sensors: http://www.amazon.de/Pyroelectrische-Infrarot-Bewegung-Sensor-Detektor/dp/B008AESDSY/
                                • HenryWhiteH
                                  HenryWhiteH
                                  HenryWhite
                                  When I look at the serial monitor output for my motion sensor, it clearly gives me a "0" or "1" depending if movement is detected or not.
                                  But when I look at the serial monitor of my gateway, it only receives the same message no matter if motion started (motion sensor serial monitor: 1) or ended (motion sensor serial monitor: 0)
                                  • T
                                    TimO
                                    @HenryWhite The node is requesting for an id and not sending any status. You'll need to define a static id in the sketch of your node:
                                    http://www.mysensors.org/download/sensor_api_15#the-full-api
                                    Look for "Starting up the library" and the "begin()" function.
                                    • T TimO
                                      HenryWhiteH
                                      HenryWhiteH
                                      HenryWhite
                                      @TimO thank you so much! it works now. Any idea why i had to assign a static id? i thought the gateway should tell the node a dynamic id automatically..
                                      • T
                                        TimO
                                        @HenryWhite You're welcome. The id is assigned by the controller, in your case OpenHAB. There is a post in the forum about how to add a rule for id assignment, but I don't use it myself.
                                        • L
                                          L
                                          lundebc
                                          I have a real noob question, and I am way better with the electronics that I am the software. I can see my motion detector show up in my gateway, and in the events.log, so I know that I am getting to the Raspberry Pi I deployed opneHAB on.
                                          Here's some detail:
                                          So I have build the MySensors.org motion detector (and a separate temp/humidity sensor), loaded up the NRF24l01+ and PIR.
                                          I created a gateway out of a nano with NRF24l01+.
                                          I followed the tutorial on how to do the serial bindings.
                                          I see in the terminal window runtime.busevents that the motion detector is detecting movement, and later changing back to 0, along with the other sensor I have, which is the DHT11 for temp and humidity.
                                          2016-01-10 18:48:12 - Arduino state updated to 0;0;3;0;9;read: 4-4-0 s=1,c=1,t=0,pt=7,l=5:21.0
                                          4;1;1;0;0;21.0
                                          2016-01-10 18:48:12 - livingTemp01 state updated to 21.0
                                          2016-01-10 18:49:32 - Arduino state updated to 0;0;3;0;9;read: 10-10-0 s=1,c=1,t=16,pt=0,l=1:1
                                          10;1;1;0;16;1
                                          2016-01-10 18:49:35 - Arduino state updated to 0;0;3;0;9;read: 10-10-0 s=1,c=1,t=16,pt=0,l=1:0
                                          10;1;1;0;16;0
                                          My confusion is how this software all works to get just the information from the gateway to the screen.
                                          I know you have to declare an item in the demo.items file, and that item needs to be in the sitemap to display. but I do not understand how you get the status from the gateway? Can someone point me to some simple examples that include the mysensor.org PIR sensor? How does the item declaration get the knowledge of the change that the gateway is receiving from the sensor? I have read through several documents and tutorials, but I am missing this bit of information.
