  3. Can't get DHT22 working with MySbootloader
13 Posts 3 Posters 4.5k Views 1 Watching
  • fifipil909F fifipil909
    Just to add some things.
    I'm using 1.5 lib.
    Here is a screenshot from Myscontroller and my serial debug line :
    upload-de0889f3-c9b7-4784-8476-a423e25e1adb
    upload-993a2926-4a7e-48f0-bad3-2beaae3189a9
    tekkaT
    tekkaT
    tekka
    @fifipil909 sounds like a frequency mismatch. What board and settings are you using for standard upload and to generate the .hex file?
    • fifipil909F
      fifipil909F
      fifipil909
      with the default bootloader I use : Arduino pro mini 3.3V - 8Mhz
      For the MYSbootloader I use :
      proMYSBL.name=ATmega328 16Mhz MYSBootloader
      proMYSBL.upload.tool=avrdude
      proMYSBL.upload.speed=115200
      proMYSBL.build.mcu=atmega328p
      proMYSBL.build.board=AVR_UNO
      proMYSBL.build.core=arduino
      I try to change the f_cpu settings to 8000000L but same result.
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        @fifipil909 8mhz crystal on your board, 3v3? Did you change f_cpu for compiling or for flashing?
        • fifipil909F
          fifipil909F
          fifipil909
          Yes i'm using the 8mhz external oscilator.
          I just change f_cpu while flashing the bootloader.
          Didn't try yet to recompile.
          • fifipil909F
            fifipil909F
            fifipil909
            I confirm it was due to Clock mismatch.
            I burnt a 8mhz version of the bootloader, assign good fuse.
            and now get everything working.
            upload-f27afbdf-a303-4d4b-b8e2-c58903d9d083
              tekkaT
              tekkaT
              tekka
              Importantly, it's not the bootloader at 8mhz that fixed the issue, it's the correct fuse settings matching f_cpu and the crystal. The bootloader is not controlling anything but OTA FW update.
              • carlierdC
                carlierdC
                carlierd
                I have an issue really close to yours. I burnt MYSBootloader to an Arduino Pro Mini at 8MHz and 3.3v.
                Burning is ok and using Nick Gammon sketch I confirm it's correct:
                Atmega fuse calculator.
                Written by Nick Gammon.
                Version 1.10
                Compiled on Nov 21 2015 at 10:56:15 with Arduino IDE 10605.
                Attempting to enter programming mode ...
                Entered programming mode OK.
                Signature = 0x1E 0x95 0x0F
                Processor = ATmega328P
                Flash memory size = 32768
                LFuse = 0xF7
                HFuse = 0xDA
                EFuse = 0xFE
                Lock byte = 0xCF
                Clock calibration = 0xA8
                External Reset Disable.................. [ ]
                Debug Wire Enable....................... [ ]
                Enable Serial (ICSP) Programming........ [X]
                Watchdog Timer Always On................ [ ]
                Preserve EEPROM through chip erase...... [ ]
                Boot into bootloader.................... [X]
                Divide clock by 8....................... [ ]
                Clock output............................ [ ]
                Bootloader size: 2048 bytes.
                Start-up time: SUT0: [ ]  SUT1: [ ] (see datasheet)
                Clock source: full-swing crystal.
                Brownout detection at: 1.8V.
                But impossible to upload a sketch after that. I got the 'not in sync' problem:
                avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
                avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
                @tekka: I understood from your last reply that I need to change fuse settings for matching f_cpu and the crystal ? I only change f_cpu to 8000000L in board.txt but without fuses modification and no bootloader compilation. Can you confirm modifications I have to do ?
                Thanks !
                • carlierdC carlierd
                  Version 1.10
                  LFuse = 0xF7
                  HFuse = 0xDA
                  EFuse = 0xFE
                  Lock byte = 0xCF
                  Thanks !
                  tekkaT
                  tekkaT
                  tekka
                  @carlierd With MYSBootloader you cannot upload a sketch the conventional way, i.e. you cannot upload via a serial connection. MYSBootloader is OTA upload only.
                  • carlierdC
                    carlierdC
                    carlierd
                    Oups !! Shame on me :joy:
                    It's also working using RFM69 ?
                      tekkaT
                      tekkaT
                      tekka
                      @carlierd no, not implemented (at the moment)
                      • carlierdC
                        carlierdC
                        carlierd
                        One more question (or perhaps no ;) ) signing is working without MYSBootloader ?
                        Thanks a lot for your replies.
                        David.
                        12.5k
