  3. Can't get DHT22 working with MySbootloader
13 Posts 3 Posters 4.5k Views 1 Watching
  • fifipil909F
    fifipil909F
    fifipil909
    with the default bootloader I use : Arduino pro mini 3.3V - 8Mhz
    For the MYSbootloader I use :
    proMYSBL.name=ATmega328 16Mhz MYSBootloader
    proMYSBL.upload.tool=avrdude
    proMYSBL.upload.speed=115200
    proMYSBL.build.mcu=atmega328p
    proMYSBL.build.board=AVR_UNO
    proMYSBL.build.core=arduino
    I try to change the f_cpu settings to 8000000L but same result.
    tekkaT 1 Reply Last reply
    • fifipil909F fifipil909
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      @fifipil909 8mhz crystal on your board, 3v3? Did you change f_cpu for compiling or for flashing?
      • fifipil909F
        fifipil909F
        fifipil909
        Yes i'm using the 8mhz external oscilator.
        I just change f_cpu while flashing the bootloader.
        Didn't try yet to recompile.
        • fifipil909F
          fifipil909F
          fifipil909
          I confirm it was due to Clock mismatch.
          I burnt a 8mhz version of the bootloader, assign good fuse.
          and now get everything working.
          upload-f27afbdf-a303-4d4b-b8e2-c58903d9d083
            tekkaT
            tekkaT
            tekka
            Importantly, it's not the bootloader at 8mhz that fixed the issue, it's the correct fuse settings matching f_cpu and the crystal. The bootloader is not controlling anything but OTA FW update.
            • carlierdC
              carlierdC
              carlierd
              I have an issue really close to yours. I burnt MYSBootloader to an Arduino Pro Mini at 8MHz and 3.3v.
              Burning is ok and using Nick Gammon sketch I confirm it's correct:
              Atmega fuse calculator.
              Written by Nick Gammon.
              Version 1.10
              Compiled on Nov 21 2015 at 10:56:15 with Arduino IDE 10605.
              Attempting to enter programming mode ...
              Entered programming mode OK.
              Signature = 0x1E 0x95 0x0F
              Processor = ATmega328P
              Flash memory size = 32768
              LFuse = 0xF7
              HFuse = 0xDA
              EFuse = 0xFE
              Lock byte = 0xCF
              Clock calibration = 0xA8
              External Reset Disable.................. [ ]
              Debug Wire Enable....................... [ ]
              Enable Serial (ICSP) Programming........ [X]
              Watchdog Timer Always On................ [ ]
              Preserve EEPROM through chip erase...... [ ]
              Boot into bootloader.................... [X]
              Divide clock by 8....................... [ ]
              Clock output............................ [ ]
              Bootloader size: 2048 bytes.
              Start-up time: SUT0: [ ]  SUT1: [ ] (see datasheet)
              Clock source: full-swing crystal.
              Brownout detection at: 1.8V.
              But impossible to upload a sketch after that. I got the 'not in sync' problem:
              avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
              avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
              @tekka: I understood from your last reply that I need to change fuse settings for matching f_cpu and the crystal ? I only change f_cpu to 8000000L in board.txt but without fuses modification and no bootloader compilation. Can you confirm modifications I have to do ?
              Thanks !
              • carlierdC carlierd
                Version 1.10
                LFuse = 0xF7
                HFuse = 0xDA
                EFuse = 0xFE
                Lock byte = 0xCF
                Thanks !
                tekkaT
                tekkaT
                tekka
                @carlierd With MYSBootloader you cannot upload a sketch the conventional way, i.e. you cannot upload via a serial connection. MYSBootloader is OTA upload only.
                • carlierdC
                  carlierdC
                  carlierd
                  Oups !! Shame on me :joy:
                  It's also working using RFM69 ?
                    tekkaT
                    tekkaT
                    tekka
                    @carlierd no, not implemented (at the moment)
                    • carlierdC
                      carlierdC
                      carlierd
                      One more question (or perhaps no ;) ) signing is working without MYSBootloader ?
                      Thanks a lot for your replies.
                      David.
                      12.5k
