  3. [Solved] Soft signing issue
13 Posts 2 Posters 4.3k Views 3 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    You are not supposed to provide a soft_serial without using whitelisting. The argument you pass is directed to the randomseedPin for the software backend. It is optional to pass and if not passed, will default to MY_RANDOMSEED_PIN.
    So simply don't enter and pass a soft_serial if you do not intend to use whitelisting and it should work.
    You can see the software backends API here:
    https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySigningAtsha204Soft.h
    • carlierdC
      carlierdC
      carlierd
      Ok ! It's clear !
      So I enable MY_SECURE_NODE_WHITELISTING in MyConfig.h.
      I tried to compile the following code from your intial post:
      MyTransportRFM69 transport;
      uint8_t soft_serial[SHA204_SERIAL_SZ] = {bla bla bla};
      MySigningAtsha204Soft signer(true, 0, NULL, soft_serial);
      I got the following error:
      In file included from SerialGateway.ino:34:0:
      /Users/carlierd/Arduino/libraries/MySensors/MySigningAtsha204.h:40:3: error: conflicting declaration 'typedef struct whitelist_entry_t whitelist_entry_t'
       } whitelist_entry_t;
      In file included from SerialGateway.ino:33:0:
      /Users/carlierd/Arduino/libraries/MySensors/MySigningAtsha204Soft.h:44:3: error: 'whitelist_entry_t' has a previous declaration as 'typedef struct whitelist_entry_t whitelist_entry_t'
      Erreur lors de la compilation.
      I don't want to have a whitelist on the gateway. I think it's correct ?
      Thanks !
      AnticimexA 1 Reply Last reply
      • carlierdC carlierd
        Ok ! It's clear !
        Thanks !
        AnticimexA
        AnticimexA
        Anticimex
        @carlierd if you don't want whitelisting I suggest you don't enable MY_SECURE_NODE_WHITELISTING and don't use the arguments for whitelisting. See the github link I posted for details on how the api changes based on the MY_SECURE_NODE_WHITELISTING flag.
        • carlierdC
          carlierdC
          carlierd
          It's probably not clear for me.
          I understood that the whitelisting could be enable on node to only accept data from trust gateway (identified by the soft_serial).
          So:
          • I set a soft_serial on the gateway and give a null withelist as I don't want to recompile the gateway for adding soft_serial of a new node.
          • I will set a soft_serial on the node and give a whitelist with the soft_serial of the gateway.
          I misunderstood ?
            So:
            I misunderstood ?
            AnticimexA
            AnticimexA
            Anticimex
            @carlierd if you have not compiled your gw with whitelisting and given it a serial number, it will not salt the signature with that data, and signature will therefore not contain the necessary components for you node to identify your gw as a trusted sender, so if you want to use whitelisting, all nodes involved need to support this. I do believe this was stated on my topic on signatures but if it is missing, I will add that.
              So:
              I misunderstood ?
              AnticimexA
              AnticimexA
              Anticimex
              @carlierd that said, your understanding is correct. But you have to supply the proper constructor arguments.
              • carlierdC
                carlierdC
                carlierd
                I tried to compile the gw with the following code but it failed:
                It's not good ? What is wrong ?
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @carlierd from the errors you listed above, it looks like you include two signing backends. Try only including the soft signing backend header since the backends declare conflicting whitelist structure types. They cannot be used simultaneously in the same sketch.
                  • carlierdC
                    carlierdC
                    carlierd
                    So simple as soon as you give me the answer ;)
                    Thanks a lot !
                      Thanks a lot !
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @carlierd no problem. I am on a phone so it is difficult to read the code formatting ok a small screen so I did not see the complete error message until now. Good to hear that it works now! :)
                      • carlierdC
                        carlierdC
                        carlierd
                        Thanks to take time ! Especially on your phone :)
