  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
    is it the brown or blue varistors that is defective?
    Edit: sorry the brown ones are fuses
    korttomaK
    korttomaK
    korttoma
    @Cliff-Karlsson the 5.5V SMD varistors I recieved from Aliexpress seller "Unionup Electronic Mall" do not work for me. Now running my circuit with out it instead.
    • Tomas
    • korttomaK korttoma
      @ServiceXp said:
      @korttoma Say what...? You measure .4 ohms on your Varistor? I think you found your problem. :angry:
      I have only ever used Varistor protection on the primary side, so I've got no experience with low voltage Varistors, but I don't think it should ever read .4.. Should be infinite.
      I how received a new batch from another seller and these varistors show infinite resistance, unfortunately they are 0603 footprint so they are really tiny.
      I bet the other seller (Unionup Electronic Mall) just sent me random crap because all of them show 0 resistance at first and then increase to 0.4 ohms, to bad it is too late to open dispute now. Just stay clear of Unionup Electronic Mall in the future.
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @korttoma Thanks for the heads up on Unionup.
      RJ_Make
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        I don't have any ceramic capacitors. Can I replace them with regualr ones?
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          Nevermind the capacitor question I found some ceramic capacitors now. But Is the "BOM" that shows component placement in the beginning of the thread accurate? only the transistor needs to be turned around?
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            @bjornhallberg said:
            @m26872 You're probably right, I just followed the BOM. I'll see if I
            I think the first post should be edited with the right components. In the doc it says
            100nF + 100pF Capacitors 0.02 Euro AliExpress Link
            but in the post is says:C2 100uF capacitor
            I have a couple of 100uF 16v but I guess that wont work, correct?
            • Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              Sorry for spamming but regarding fuse 2. Can someone post a link to a fuse that works well. I got alot of those brown PTC fuses but the holes in the PCB are too small. I tried drilling them up but then I got no contact so I had to solder a separate separate wire from 5v to the fuse to get any power to the arduino and the rest of the components.
              Or has there been a mistake on my PCB with too small holes for fuse 2?
              korttomaK 1 Reply Last reply
                korttomaK
                korttomaK
                korttoma
                #152
                @Cliff-Karlsson the holes for Fuse2 are to smal and this has been mentioned a few times before in this thread. I drilled mine out with a 0.8mm drill and could then use the recommended fuse without any extra wires.
                • Tomas
                • T
                  tomkxy
                  Since the 5.5V varistor is not available from the linked AliExpress shop I wonder whether this varistor would work as well?
                  https://www.conrad.de/de/smd-varistor-we-vs-82537040-4-v-wuerth-elektronik-we-vs-82537040-1-st-1086820.html
                  • zrom69Z
                    zrom69Z
                    zrom69
                    greeted everyone
                    look what concerns island link tests on this HLK-PM01
                      sebas
                      A question about the fuses. The BOM in the Word document links to two 230V fuses, the PTC and slow blow fuse. If I read the schematic correctly one fuse is on the AC side and one is on the DC side. How does a 230V fuse help on the DC side where there should not be more than 5Vdc? Or am I missing something? As I'm quite new to this I'm probably not reading the schematic correctly or missing something :-)
                      • A aproxx
                        For those who wanted to see some pictures of the board:
                        IMG_20150921_194059 (Small).jpg IMG_20150921_194039 (Small).jpg IMG_20150921_194035 (Small).jpg IMG_20150921_194023 (Small).jpg IMG_20150921_192748 (Small).jpg IMG_20150921_192737 (Small).jpg IMG_20150921_192728 (Small).jpg
                        Small notice: These pictures are of a slightly older design. The newer design has a few minor changes like better component placement and a permanent fuse instead of this resettable fuse. But these pictures should at least give you an idea on how everything looks like, and shows how really small it actually is.
                        Also, I reinforced the traces of the 230v lines, which I absolutely recommend to do! (Although I do recommend to do it slightly more professional than I did on this prototype :))
                        the cosmic gateT
                        the cosmic gateT
                        the cosmic gate
                        I really like this design, but it would be even nicer when this fits a ESP8266 :) Maybe the PCB could be even smaller . And it works together with link text .
                        So is there maybe one of the PCB designer guys who can build /draw / design this 230v to ESP8266 PCB ?
                        There's more than meets the eye
                        • Michel - ItM
                          Michel - ItM
                          Michel - It
                          WOW, REALLY GREAT JOB!
                          • B
                            B
                            Brijesh Mishra
                            Hello everyone,
                            This is a gr8 project, i am looking forward to make few sensor for my home. As i don't have any experience with electronics and very new to all these terms and components.
                            I would request anyone of you to, kindly post some pictures of the board with components in place that i can copy and make my boards.
                            **Specially 3 pin regulator and Capacitors **
                            My first assembled board is not working, it looks like m doing something wrong with either the capacitors or the regulator. I checked my NRF24l01 VCC pin and not getting any voltage at all.
                            Please help me guys......
                            Thanks and Regards
                            Brij
                            • B Brijesh Mishra
                              Hello everyone,
                              Thanks and Regards
                              Brij
                              @the-cosmic-gate has already posted images above.
                              Perhaps you should post a picture of what you've done?
                              • B
                                B
                                Brijesh Mishra
                                Thanks a lot for your response, this is what i have done so far.
                                • the cosmic gateT
                                  the cosmic gateT
                                  the cosmic gate
                                  Could I ask to the smart PCB builder's / designers to make the same 230v PCB but not using an Arduino but one of the ESP8266 versions , the the board could be even smaller and easier to fix in the wholes
                                  B 1 Reply Last reply
                                  • the cosmic gateT the cosmic gate
                                    B
                                    B
                                    Brijesh Mishra
                                    @the-cosmic-gate, greetings to you. Kindly let me know, is there any issue with the component placement in the board. Not sure why it's not working :(.
                                    Brijesh
                                    the cosmic gateT 1 Reply Last reply
                                    • N
                                      N
                                      nunver
                                      @aproxx Great job. Just started to work with mysensors and I was looking for a power supply alternative to mobile phone chargers. Though one question; the board that you included the relay was really interesting. Why did you not proceed on this? Also, do you sell the PCB's?
                                      • B Brijesh Mishra
                                        Brijesh
                                        the cosmic gateT
                                        the cosmic gateT
                                        the cosmic gate
                                        Brijesh
                                        There absolutely nothing wrong, but I want to use the ESP8266 to build in instead of the arduino and 2.4 ghz radio (the ESP8266 is an Arduino incl WiFi) so the PCB can be much smaller I think.
                                        • N
                                          N
                                          novicit
                                          @Brijesh-Mishra , I see two issues with your photos. 1) the 3.3V regulator is on backwards. If you earlier in this thread someone comments that the regulator needs to be put on backward. The white design on the board is not correct. That was also my experience with the boards I built. The flat side of the regulator should face the two cap's. 2) more importantly, it appears that you used a thermal fuse in the spot where fuse #1 goes. Fuse #1 is supposed to be a 300ma slo blow fuse. If that is what you have there no problem, but it looks like the thermal discussed in the thread. This board does not have a place for the thermal fuse. I would consider this a serious safety issue, but I am not an expert. Hope this helps.
