  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
  • A aproxx
    @mvdarend Thanks for the feedback! Happy to hear that it's working fine on your side as well. Although I do find it strange that the LE33 seems to be the other way around on your board? Maybe I just made a mistake with the silkscreen, and should the LE33 be on the bottom side? Anyway, I'll make sure to address this as soon as I possible (probably somewhere during next week). Sorry for the possible inconvenience, but thanks for pointing this out! :)
    @sundberg84 The board dimension are about 4.2x4.7cm, so it is quite small. However, I'm afraid that because of the NRF24L01 module, and the 230v connections to it, it wouldn't really fit the box you have on that picture (assuming the board you have there is 5x5cm)..
    Somewhere in the next week or 2 I'll try to design a custom 3d printable plastic box for the board that I've designed. Together with a 2-relay board as requested by @jemish .
    Z
    Z
    zebmina
    @aproxx I'm a complete newbie but am interested in exploring this! Do you have a tutorial on the steps to populate this circuit board? I am comfortable with soldering but new to electronic circuits. Is there a particular order in which components ought to be soldered? Would you recommend breadboarding to begin with? Any sample code that can be used to do a sanity test?
    Your guidance is greatly appreciated!
    • A aproxx
      For those who wanted to see some pictures of the board:
      IMG_20150921_194059 (Small).jpg IMG_20150921_194039 (Small).jpg IMG_20150921_194035 (Small).jpg IMG_20150921_194023 (Small).jpg IMG_20150921_192748 (Small).jpg IMG_20150921_192737 (Small).jpg IMG_20150921_192728 (Small).jpg
      Small notice: These pictures are of a slightly older design. The newer design has a few minor changes like better component placement and a permanent fuse instead of this resettable fuse. But these pictures should at least give you an idea on how everything looks like, and shows how really small it actually is.
      Also, I reinforced the traces of the 230v lines, which I absolutely recommend to do! (Although I do recommend to do it slightly more professional than I did on this prototype :))
      Z
      Z
      zebmina
      @aproxx Very nice! Just ordered.... But quite nervous - don't know much about electronic circuits, although I am quite good at following detailed instructions. You wouldn't happen to have a tutorial on how to populate the pcb?
      • A aproxx
        Hi all,
        **UPDATE April 17 2016 **
        The latest version of this board is available HERE.
        After spending a few months on this forum and a few prototypes later, I decided I wanted to build a small but cheap PCB which could be placed in either the wall behind the light switch, or above the lamp.
        Besides the boards I've seen on this forum, I wanted these boards to contain a module to go from 230v AC to 5/3.3v DC in order to power an Arduino nano and the NRF module. I eventually ended up with a PCB which is about 4 by 4.5cm. So with all components attached I'm hoping to get in stuffed in a 5x5x3cm plastic printed case.
        Modules which I've used to power the board:
        [http://www.aliexpress.com/item/5-pcs-HLK-PM01-AC-DC-220V-to-5V-Step-Down-Power-Supply-Module-Intelligent-Household/32319202093.html?spm=2114.32010308.4.19.8oKfZg
        UPDATE: 2015/09/18
        As promised, I've got an update for this project. The board has been tested in the past week, and everything is working as expected. Compared to the previous board I've posted, I have updated the following:
        • Solder pads of LE33CZ have been placed a little wider apart to avoid short circuit while soldering.
        • Solder pads of the resettable fuse (Fuse2) has been placed closer together to better fit the fuses of the BOM.
        • Moved the NRF24L01 connector a bit away from the solid state relay. Should make it easier to solder.
        • Moved Fuse2 to another location on the board, away from the 230v circuit.
        Some 3D pictures (Top and bottom):
        Anyone who is interested can order the PCB HERE
        Some documentation, complete list of required components and all gerber / DipTrace files (in case you would like to make some modifications) can be found here: MySensors board v3.2.3.zip.
        Z
        Z
        zebmina
        OK, this may be a really dumb question, but I need to ask, so please pardon my ignorance....
        Clearly one main advantage of this is to control traditional light switches programatically and also through the standard light switch. How would I know whether someone flipped the light switch to turn on/off? How does the program "state" keep in sync with the "state" of the physical light switch?
        Sorry again about what might be a rather dumb question.
        • sundberg84S
          sundberg84S
          You could connect the regular switch like a binary button, for example between D3 and Grd. The node could monitor both incoming messages from the controller and the state on D3.
          • n3roN
            n3roN
            n3ro
            i hope i can buy this board in the near future =)
            pimatic + MySensors + Homeduino + z-way
            https://github.com/n3roGit/MySensors_n3ro
            • zrom69Z
              zrom69Z
              zrom69
              Hello
              I'm putting a home automation system I want to put in the cabinet
              electric power supply to power pc wholes my Arduino pro mini cable this method and these can be well card she could withstand power pc. thank you in advance for aid
              • RJ_MakeR RJ_Make
                @korttoma Say what...? You measure .4 ohms on your Varistor? I think you found your problem. :angry:
                I have only ever used Varistor protection on the primary side, so I've got no experience with low voltage Varistors, but I don't think it should ever read .4.. Should be infinite.
                korttomaK
                korttomaK
                korttoma
                I how received a new batch from another seller and these varistors show infinite resistance, unfortunately they are 0603 footprint so they are really tiny.
                I bet the other seller (Unionup Electronic Mall) just sent me random crap because all of them show 0 resistance at first and then increase to 0.4 ohms, to bad it is too late to open dispute now. Just stay clear of Unionup Electronic Mall in the future.
                • Tomas
                RJ_MakeR 1 Reply Last reply
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  wrote on last edited by Cliff Karlsson
                  #145
                  is it the brown or blue varistors that is defective?
                  Edit: sorry the brown ones are fuses
                  korttomaK 1 Reply Last reply
                    korttomaK
                    korttomaK
                    korttoma
                    @Cliff-Karlsson the 5.5V SMD varistors I recieved from Aliexpress seller "Unionup Electronic Mall" do not work for me. Now running my circuit with out it instead.
                    • Tomas
                    • korttomaK korttoma
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      @korttoma Thanks for the heads up on Unionup.
                      RJ_Make
                      • Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        I don't have any ceramic capacitors. Can I replace them with regualr ones?
                        • Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          Nevermind the capacitor question I found some ceramic capacitors now. But Is the "BOM" that shows component placement in the beginning of the thread accurate? only the transistor needs to be turned around?
                          • Cliff KarlssonC
                            Cliff KarlssonC
                            Cliff Karlsson
                            @bjornhallberg said:
                            @m26872 You're probably right, I just followed the BOM. I'll see if I
                            I think the first post should be edited with the right components. In the doc it says
                            100nF + 100pF Capacitors 0.02 Euro AliExpress Link
                            but in the post is says:C2 100uF capacitor
                            I have a couple of 100uF 16v but I guess that wont work, correct?
                            • Cliff KarlssonC
                              Cliff KarlssonC
                              Cliff Karlsson
                              Sorry for spamming but regarding fuse 2. Can someone post a link to a fuse that works well. I got alot of those brown PTC fuses but the holes in the PCB are too small. I tried drilling them up but then I got no contact so I had to solder a separate separate wire from 5v to the fuse to get any power to the arduino and the rest of the components.
                              Or has there been a mistake on my PCB with too small holes for fuse 2?
                                korttomaK
                                korttomaK
                                korttoma
                                #152
                                @Cliff-Karlsson the holes for Fuse2 are to smal and this has been mentioned a few times before in this thread. I drilled mine out with a 0.8mm drill and could then use the recommended fuse without any extra wires.
                                • Tomas
                                • T
                                  tomkxy
                                  Since the 5.5V varistor is not available from the linked AliExpress shop I wonder whether this varistor would work as well?
                                  https://www.conrad.de/de/smd-varistor-we-vs-82537040-4-v-wuerth-elektronik-we-vs-82537040-1-st-1086820.html
                                  • zrom69Z
                                    zrom69Z
                                    zrom69
                                    greeted everyone
                                    look what concerns island link tests on this HLK-PM01
                                      sebas
                                      A question about the fuses. The BOM in the Word document links to two 230V fuses, the PTC and slow blow fuse. If I read the schematic correctly one fuse is on the AC side and one is on the DC side. How does a 230V fuse help on the DC side where there should not be more than 5Vdc? Or am I missing something? As I'm quite new to this I'm probably not reading the schematic correctly or missing something :-)
                                      • A aproxx
                                        the cosmic gateT
                                        the cosmic gateT
                                        the cosmic gate
                                        I really like this design, but it would be even nicer when this fits a ESP8266 :) Maybe the PCB could be even smaller . And it works together with link text .
                                        So is there maybe one of the PCB designer guys who can build /draw / design this 230v to ESP8266 PCB ?
                                        There's more than meets the eye
                                        • Michel - ItM
                                          Michel - ItM
                                          Michel - It
                                          WOW, REALLY GREAT JOB!
