  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 346.3k Views 68 Watching
  • RJ_MakeR RJ_Make
    @korttoma Say what...? You measure .4 ohms on your Varistor? I think you found your problem. :angry:
    I have only ever used Varistor protection on the primary side, so I've got no experience with low voltage Varistors, but I don't think it should ever read .4.. Should be infinite.
    korttomaK
    korttomaK
    korttoma
    I how received a new batch from another seller and these varistors show infinite resistance, unfortunately they are 0603 footprint so they are really tiny.
    I bet the other seller (Unionup Electronic Mall) just sent me random crap because all of them show 0 resistance at first and then increase to 0.4 ohms, to bad it is too late to open dispute now. Just stay clear of Unionup Electronic Mall in the future.
    • Tomas
    RJ_MakeR 1 Reply Last reply
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      wrote on last edited by Cliff Karlsson
      #145
      is it the brown or blue varistors that is defective?
      Edit: sorry the brown ones are fuses
      korttomaK 1 Reply Last reply
        korttomaK
        korttomaK
        korttoma
        @Cliff-Karlsson the 5.5V SMD varistors I recieved from Aliexpress seller "Unionup Electronic Mall" do not work for me. Now running my circuit with out it instead.
        • Tomas
        • korttomaK korttoma
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @korttoma Thanks for the heads up on Unionup.
          RJ_Make
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            I don't have any ceramic capacitors. Can I replace them with regualr ones?
            • Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              Nevermind the capacitor question I found some ceramic capacitors now. But Is the "BOM" that shows component placement in the beginning of the thread accurate? only the transistor needs to be turned around?
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                @bjornhallberg said:
                @m26872 You're probably right, I just followed the BOM. I'll see if I
                I think the first post should be edited with the right components. In the doc it says
                100nF + 100pF Capacitors 0.02 Euro AliExpress Link
                but in the post is says:C2 100uF capacitor
                I have a couple of 100uF 16v but I guess that wont work, correct?
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  Sorry for spamming but regarding fuse 2. Can someone post a link to a fuse that works well. I got alot of those brown PTC fuses but the holes in the PCB are too small. I tried drilling them up but then I got no contact so I had to solder a separate separate wire from 5v to the fuse to get any power to the arduino and the rest of the components.
                  Or has there been a mistake on my PCB with too small holes for fuse 2?
                    korttomaK
                    korttomaK
                    korttoma
                    #152
                    @Cliff-Karlsson the holes for Fuse2 are to smal and this has been mentioned a few times before in this thread. I drilled mine out with a 0.8mm drill and could then use the recommended fuse without any extra wires.
                    • Tomas
                    • T
                      tomkxy
                      Since the 5.5V varistor is not available from the linked AliExpress shop I wonder whether this varistor would work as well?
                      https://www.conrad.de/de/smd-varistor-we-vs-82537040-4-v-wuerth-elektronik-we-vs-82537040-1-st-1086820.html
                      • zrom69Z
                        zrom69Z
                        zrom69
                        greeted everyone
                        look what concerns island link tests on this HLK-PM01
                          sebas
                          A question about the fuses. The BOM in the Word document links to two 230V fuses, the PTC and slow blow fuse. If I read the schematic correctly one fuse is on the AC side and one is on the DC side. How does a 230V fuse help on the DC side where there should not be more than 5Vdc? Or am I missing something? As I'm quite new to this I'm probably not reading the schematic correctly or missing something :-)
                          • A aproxx
                            For those who wanted to see some pictures of the board:
                            IMG_20150921_194059 (Small).jpg IMG_20150921_194039 (Small).jpg IMG_20150921_194035 (Small).jpg IMG_20150921_194023 (Small).jpg IMG_20150921_192748 (Small).jpg IMG_20150921_192737 (Small).jpg IMG_20150921_192728 (Small).jpg
                            Small notice: These pictures are of a slightly older design. The newer design has a few minor changes like better component placement and a permanent fuse instead of this resettable fuse. But these pictures should at least give you an idea on how everything looks like, and shows how really small it actually is.
                            Also, I reinforced the traces of the 230v lines, which I absolutely recommend to do! (Although I do recommend to do it slightly more professional than I did on this prototype :))
                            the cosmic gateT
                            the cosmic gateT
                            the cosmic gate
                            I really like this design, but it would be even nicer when this fits a ESP8266 :) Maybe the PCB could be even smaller . And it works together with link text .
                            So is there maybe one of the PCB designer guys who can build /draw / design this 230v to ESP8266 PCB ?
                            There's more than meets the eye
                            • Michel - ItM
                              Michel - ItM
                              Michel - It
                              WOW, REALLY GREAT JOB!
                              • B
                                B
                                Brijesh Mishra
                                Hello everyone,
                                This is a gr8 project, i am looking forward to make few sensor for my home. As i don't have any experience with electronics and very new to all these terms and components.
                                I would request anyone of you to, kindly post some pictures of the board with components in place that i can copy and make my boards.
                                **Specially 3 pin regulator and Capacitors **
                                My first assembled board is not working, it looks like m doing something wrong with either the capacitors or the regulator. I checked my NRF24l01 VCC pin and not getting any voltage at all.
                                Please help me guys......
                                Thanks and Regards
                                Brij
                                • B Brijesh Mishra
                                  Hello everyone,
                                  Thanks and Regards
                                  Brij
                                  @the-cosmic-gate has already posted images above.
                                  Perhaps you should post a picture of what you've done?
                                  • B
                                    B
                                    Brijesh Mishra
                                    Thanks a lot for your response, this is what i have done so far.
                                    • the cosmic gateT
                                      the cosmic gateT
                                      the cosmic gate
                                      Could I ask to the smart PCB builder's / designers to make the same 230v PCB but not using an Arduino but one of the ESP8266 versions , the the board could be even smaller and easier to fix in the wholes
                                      B 1 Reply Last reply
                                      • the cosmic gateT the cosmic gate
                                        B
                                        B
                                        Brijesh Mishra
                                        @the-cosmic-gate, greetings to you. Kindly let me know, is there any issue with the component placement in the board. Not sure why it's not working :(.
                                        Brijesh
                                        the cosmic gateT 1 Reply Last reply
                                        • N
                                          N
                                          nunver
                                          @aproxx Great job. Just started to work with mysensors and I was looking for a power supply alternative to mobile phone chargers. Though one question; the board that you included the relay was really interesting. Why did you not proceed on this? Also, do you sell the PCB's?
