  3. which hardware model must to be used for ethernet gateway ?
5 Posts 2 Posters 2.0k Views 2 Watching
    mickaelh51
    wrote on last edited by mickaelh51
    Actually I'm using an Arduino UNO to be the ethernet (MQTT) gateway.
    But, I feel that Arduino UNO is too low when there is many sensors.
    Do you have an experience with UNO or MEGA to be a MQTT Gateway ?
    which hardware to choose ?
    thanks in advance
    Controller: OpenVZ :: OpenHab 1.8.0 :: MQTT Broker
    Gateway: Arduino UNO :: W5100 :: MQTTClient
    Software: MySensors 1.6beta
    • M mickaelh51
      thanks in advance
      Why do you feel that way? Can you give some examples of limits/issues you've encountered using an Uno?
        mickaelh51
        No problem ;)
        I have only 3 sensors in test. But with this nodes I feel my gateway is low.
        When I send an order from MQTT (Ex "On" command to specific relay), it's not in real time (few seconds to execute this order).
        But when I shutdown 2 nodes / 3. I saw the same order seems faster.
        So, my question is: Is there a recommendation for gateway hardware ?
        thanks and happy new year 2016 ;)
        • M mickaelh51
          No problem ;)
          @mickaelh51 If you feel the need for more processing power, an ESP8266 based gateway could be interesting.
            mickaelh51
            ESP8266 is faster than W5100 ok thanks.
            but if I want work with ethernet only ?
