  3. Repeater vs st=Fail
Repeater vs st=Fail
16 Posts 5 Posters 5.5k Views 3 Watching
  • D
    doblanch
    wrote on last edited by doblanch
    Thanks for your help...
    We can assume that the issue is on the first hop....
    But the st=fail means, maybe, that the message has not reached GW.... in both case, drop on 1st hop or 2nd Hop(GW) result in the same message...
    The test would be to generate a wifi issue between GW/repeater, and see if the node has a st=fail or st=ok
    I don't have 3 PC to test... May be @hek can answer :-) he made the protocol ...
    It will help a lot in my Troubleshoot. In fact, I have issues with NRF... I tried different, one. I have one working well... now, but still want to confirm in case of...
    This one seems to work
    http://www.ebay.fr/itm/281471682942
    • D
      doblanch
      I answer myself, hope it will help somebody else ...
      @return true Returns true if message reached the **first stop ** on its way to destination.
      indeed, it clarifies my question...
      	* Sends a message to gateway or one of the other nodes in the radio network
      	* @param msg Message to send
      	* @param ack Set this to true if you want destination node to send ack back to this node. Default is not to request any ack.
      	* @return true Returns true if message reached the first stop on its way to destination.
      	bool send(MyMessage &msg, bool ack=false);
      m26872M S 2 Replies Last reply
      • D doblanch
        m26872M
        m26872M
        m26872
        wrote on last edited by m26872
        @doblanch
        Maybe I'm a pedant here, but quite often the message very well reaches it's first stop BUT then this "low level radio-radio ack" does not seem to reach its way back. Don't know why, but that's from my experience.
        D 1 Reply Last reply
        • D doblanch
          Samuel235
          @doblanch Awesome, thank you for providing the answer and not just deserting the forum topic. Like you said, this will aid anyone that is having this issue too. True community here!
          MySensors 2.1.1
          • D
            doblanch
            happy to help :-)
            I still have some issue. My repeater nano freeze after couple of days... it's blinking quickly (RX?/TX?)... and I lost the connectivity. I have to reboot it. Only node connected to this repeater stuck !
            I don't have a cable connnected to it...then I don't know what type of error I'm facing to
            DwaltD 1 Reply Last reply
            • D doblanch
              happy to help :-)
              DwaltD
              DwaltD
              Dwalt
              @doblanch
              Is your repeater using MyS 1.5? I had similar problems with a nano as repeater using MyS 1.4 and after upgrading the repeater node to 1.5, everything worked without lockup or 'lost' nodes.
              • DwaltD Dwalt
                @doblanch
                doblanch
                @Dwalt Hello,
                In fact, I posted a new thread, because I don't understand my problem... (and it's not , 'im sure now, that it's not on the node, but on the repeater 100% sure)
                I use 1.5 (but the one from august, the one just out of the box, I think they had some changes since).. I saw some bug fix (see below the thread corresponding)
                You are using the 1.5 but what is the date of the file in the library (me it was august), I understood, that there was some changes... a bug in the library. My problem is very very similar, but I can be sure 100% because, when repetear stuck, I don't have serial connected to log. However, I see the led blinking a lot meaning that there is a lot of communication happening... a loop for example in a send message :-) If I connnect my USB repeater reboot, and problem disappears..
                From now, I have just disabled the "reset" when plugin usb ( a 120ohm between RST and 5V). Next time I will connect to check what is grabbing on the console.
                see here : Repeater nood keeps looping... and doesnt reach gw
                In the mean time , I upgraded to the 1.5 library, the one from november...
                let's see, but I'm on this issue since 3 months !!! I'm quite lost, and I don't know exactly how to move forward now
                • m26872M m26872
                  @doblanch
                  doblanch
                  @m26872 I agree, sometimes packet reach the next hop, but the ACK does'nt come back ... I saw that... I was receiving the information on my controller, but this message was not acked properly, and I had a st=Fail ....I think it can happen when we are using 2 different type of NRF24 (NRF24+PA+LNA vs NRF24)... one is sending more far , and the ack can't reach because it does not have enough power ...
                  m26872M 1 Reply Last reply
                  • D doblanch
                    m26872M
                    m26872M
                    m26872
                    @doblanch Sure its likely power related, but I'm not using any nRF PA version.
                    • m26872M m26872
                      doblanch
                      @m26872 ok :-(
