  3. 3 in 1 incl battery monitor
60 Posts 11 Posters 37.1k Views 12 Watching
  • sundberg84S
    sundberg84S
    What does your serial or error log tell you when you upload the sketch you have? And which sketch/code do you use at this point?
    • the cosmic gateT the cosmic gate
      I'am not getting this clear / working :(
      Could somebody help me to complete this 3in1 incl battery monitoring sketch working? Thnx
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      @the-cosmic-gate
      I changed your original sketch a little. It now includes a conditional send for the "tripped" values and groups the conditional sends for all values.
      I was not able to test as I'm using a different library for the DHT.
      Have fun..
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define CHILD_ID_MOT 2   // Id of the sensor child
      unsigned long SLEEP_TIME = 30000UL; // Sleep time between reads (in milliseconds)
      int oldBatteryPcnt = 0;
      DHT dht;
      float lastTemp = 0 ;
      float lastHum = 0 ;
      boolean lastTripped = false ;
      boolean metric = true;
      MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
         analogReference(INTERNAL1V1);
         analogReference(INTERNAL);
        gw.begin();
        dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN. DHT22);
        gw.sendSketchInfo("Humidity/Motion", "1.0");
        gw.present(CHILD_ID_MOT, S_MOTION);
        // get the battery Voltage
         #ifdef DEBUG
         Serial.println(sensorValue);
         #ifdef DEBUG
         Serial.print(batteryV);
         Serial.println(" V");
         Serial.print(batteryPcnt);
         Serial.println(" %");
           // Power up radio after sleep
           oldBatteryPcnt = batteryPcnt;
        // Read digital motion value
        if (tripped != lastTripped ) {
        	Serial.println(tripped);
        	gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          Serial.print("T: ");
        if (isnan(humidity)) {
            lastHum = humidity;
            Serial.print("H: ");
            Serial.println(humidity);
        gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
      • the cosmic gateT
        the cosmic gateT
        the cosmic gate
        Thnx a lot @AWI
        there was 1 verification error,
        changed it, to :
        DHT dht;
        float lastHum = 0 ;
          gw.begin();
           #ifdef DEBUG
           #ifdef DEBUG
            if (!metric) {
              lastHum = humidity;
        uploading now
        There's more than meets the eye
        • the cosmic gateT
          the cosmic gateT
          the cosmic gate
          working nice for 2 day's now !
          Thnx a lot @AWI !!!
          • the cosmic gateT
            the cosmic gateT
            the cosmic gate
            Something strange: when I look in the IDE console the battery % is displayed. But using Domoticz there's no battery % display / selectable ? What's wrong , or do I forget something ?
            • icebobI
              icebobI
              icebob
              In Domoticz you can see the battery level in Setup->Devices.
              If you would like to see on a chart, you have to send the battery level or voltage to the controller as a sensor value too. After it, you can see as this:
              • icebobI icebob
                Tronix
                @icebob
                Hi, I'm a newbee just started with MySensors. I built the first temp/hum sensor, and I'm trying to plot the battery level in a graph too. In this discussion you mention that I need to send the battery level to the controller as sensor value. Can you please share with me the code which I should use? Thanks a lot.
                Marco
                • icebobI
                  icebobI
                  icebob
                  Yes, I can.
                  This is the definition of message for battery level:
                  // Battery sensor (A0)
                  #define CHILD_ID_BATTERY 199
                  #define BATTERY_SENSOR_ANALOG_PIN 0
                  MyMessage msgBattery(CHILD_ID_BATTERY, V_VOLTAGE);
                  And this is the sender function:
                  #define VMIN 1.9  // Battery monitor lower level. Vmin_radio=1.9V
                  #define VMAX 3.00  // Vmin<Vmax<=3.44
                  #define VCC_CORRECTION (3.4 / 3.33)
                  int lastBatteryLevel;
                  bool sendBatteryLevel(bool force = false) {
                    int value = analogRead(BATTERY_SENSOR_ANALOG_PIN);
                    float batVoltage  = value * VBAT_PER_BITS / VCC_CORRECTION;
                    int batLevel = static_cast<int>(((batVoltage-VMIN)/(VMAX-VMIN))*100.);
                    if (batLevel != lastBatteryLevel || force) {
                      gw.sendBatteryLevel(batLevel);
                      gw.send(msgBattery.set(batVoltage, 2));
                      lastBatteryLevel = batLevel;
                    return true;
                  • T
                    Tronix
                    Great, thanks for your quick response. Implementing now. Looks good.
                    • the cosmic gateT
                      the cosmic gateT
                      the cosmic gate
                      Running the sketch for 1 Monty (+-), and the AA batteries are dead empty ?
                      I did all the "possible" mods on the arduino ( cut the LED an V ) , what can i do to make this sketch run langer on this 2AA batteries ?
                      Something in the sketch , some fine tuning or something else ?
                      When read the arduino hardware tweaking topics on different forums they dat that running for 1 year ( and more) is possible but how ;-)?
                      • carlierdC
                        carlierdC
                        carlierd
                        Did you measured the current of your circuit ?
                        What motion sensor are you using ? This component may consume a lot of current. Did you check this post ?
                        If you wake-up the arduino every 30 seconds for measurement it's a problem. Every 5 minutes is the minimum I think. I have connected the Vcc pin of the DHT sensors and the Vcc of the LDR to a digital pin of the arduino and when a measurement is done I set the PIN to the HIGH state.
                        First measurement of my sensor gives an IDLE current consumption close to 5uA which is really correct according to elements connected to the arduino (RFM69HW, DHT22 and LDR).
                        David.
                        the cosmic gateT 1 Reply Last reply
                        • bjacobseB
                          bjacobseB
                          bjacobse
                          Yes as Carlierd writes, it's important that the Arduino are controlling the voltage to the external components, like DHT.
                          I might have overlooked, but which component are you using for motion sensing? maybe this component is also power-hungry
                          • icebobI
                            icebobI
                            icebob
                            @the-cosmic-gate Now I measured my dev circuit (Arduino Nano from China (cutted power led and desoldered regulator) + DHT22 + PIR + Battery measure resistor divider) and in gw.sleep (with 1 interrupt for PIR) the power comsumption is ~90uA.
                            It wakes up every minutes, measuring and sending (~100ms and 5 - 20mA).
                            So 100ms with 20mA and 59900ms with 0.09mA. The average current is 120uA and with 2 AA battery it is about 2 years.
                            • E
                              E
                              ericvdb
                              @icebob,
                              whats that app you are using to do the battery calculations?
                              • carlierdC
                                carlierdC
                                carlierd
                                @icebob
                                100ms for measurement and transmission seems very small ! I am at approximately 1500ms.
                                Give me your secret now !! ;)
                                • icebobI
                                  icebobI
                                  icebob
                                  @ericvdb http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2680&dDocName=en545243. It's specified for PIC, but I select SLEEP mode in every cycle, so I can use for any uC.
                                  @carlierd: I have no extra secret. If I measure 3-4 sensor and every values is changed, the loop time is 100ms. Best case is 10-20ms (if every sensors is unchanged). I'm not using delay in the loop.
                                  • carlierdC
                                    carlierdC
                                    carlierd
                                    @icebob: It's true that as I used signing feature, transmission is longer ! and in order to increase a little bit more I send every measure even if they not changed. I will probably upgrade my sketch to add a one-hour message at minimum and do not transfer mesure without change !
                                    • carlierdC carlierd
                                      David.
                                      the cosmic gateT
                                      the cosmic gateT
                                      the cosmic gate
                                      wrote on last edited by the cosmic gate
                                      #29
                                      David.
                                      Hello David,
                                      I tried to meassure , but didn't have the right stuff to do this good enough.
                                      The parts i use for this "project": DHT-22 (connected to D4), HC-SR501 (connected to D3)and connected to the 3.3V pin post , the VVC is connected to the VVC of the arduino pro mini 8 Mhz /3.3 V .
                                      And use the sketch as above:
                                      DHT dht;
                                      float lastHum = 0 ;
                                        gw.begin();
                                         #ifdef DEBUG
                                         #ifdef DEBUG
                                          if (!metric) {
                                            lastHum = humidity;
                                      So how do you connect the DHT / SR501 to the digital pin, and what's the sketch you're using ?
                                      • carlierdC
                                        carlierdC
                                        carlierd
                                        You need to power the motion sensor all time as you want to detect any mouvement and not only every 2 minutes.
                                        Caution, in your sketch, the battery level is sent at the beginning and at the end.
                                        Did you tweak the motion sensor ?? Not tested yet but it seems that modification could (must ?) be done to reduce power consumption (LINK).
                                        Why do you wake-up the arduino every 30 seconds ? For temperature, every 5 or 15 minutes is enough.
                                        • carlierdC
                                          carlierdC
                                          carlierd
                                          @icebob: is you motion sensor often triggered ? I mean, is the sensor placed somewhere where there is a lot of mouvement ? I tried to do such sensor some months ago but my sensors was very often triggered on finally the time is sleep was small and my battery decreased very quickly !
