  3. RS485/RS232/Serial transport class for mysensors.org
rs485 serialrs485
143 Posts 27 Posters 139.3k Views 27 Watching
  • T
    TimO
    @anti: I'm glad, I'm not the only one! :-)
    I've tried to find the problem, but had no luck.
    What is bugging me: it was working with a early version, before it was merged into development, but I don't see any changes.
    I've not tested the latest / current version though.
    • A
      andriej
      wrote on last edited by andriej
      #37
      Hi!
      Glad to see 'wired' version of MySensor protocol coming.
      One question - how long wires and how many sensors on one pair/multiple pairs will be supported?
      I'm thinking about cabling for new home, which means many meters of cable to every sensor/door/actuator/ligth/meter etc.
      In best scenario - one cat5e - one termination (sensor/node/etc.)
      Currently I'm looking for a cabled version of protocol to support it and be 101% stable (no hiccups and freezes over the protocol), so I can rely on my home.
      MySensors seems to be great to implement, but I'm worried about the signal... I was thinking about letting something around 12-24-30V thru one pair of Cat5 to power all nodes from one power-source (with backup batteries).
      Or - are there any better alternatives for RS485, that doesn't need resistors, have no limitations of 32 devices etc?
      L 1 Reply Last reply
      • A andriej
        Hi!
        L
        L
        LeoDesigner
        wrote on last edited by LeoDesigner
        #38
        @andriej
        According to: https://en.wikipedia.org/wiki/RS-485
        "It offers data transmission speeds of 35 Mbit/s up to 10 m and 100 kbit/s at 1200 m. "
        also check this: https://www.maximintegrated.com/en/app-notes/index.mvp/id/367
        You may design a bus with up to 256 nodes.
        CAT5 is the best choice anyway for any type of communication (I mean you can run regular Ethernet on them too).
        Check the video at the beginning of the post. It's a working example of two remote nodes connected only with one CAT5 cable over 50m. They are working at 115200 - however speed might be up to 1 Mbit/s.
        A 1 Reply Last reply
        • L LeoDesigner
          @andriej
          andriej
          @LeoDesigner but how would I connect all sensors in house and relays too?
          SOme resistors needed? Star topology? Few gateways?
          • A andriej
            L
            L
            LeoDesigner
            @andriej
            The star topology could be a problem. However for low speed nodes this may work anyway.
            You may need something like RS485 hub :) or a GW with many RS485 bus ports.
            Or just a separate MAX485 board for each node. You need to test it.
            • antiA
              antiA
              anti
              @TimO Well... it turns out that the garbage seen on the wire was not garbage, just the binary serial protocol. And the node was desperately attempting to find a parent, with no success.
              FYI this is how I workaround it. But I did not feel like I could fix it for 100% sure.
              The gateway ignored the broadcasts from the node. The following code in MyTransportRS485 triggered for probably wrong reasons (sender=0; nodeid=0;station=broadcast) :
                             if ((_recSender == _nodeId) ||
                                (_recStation != _nodeId &&
                                 _recStation != BROADCAST_ADDRESS)) {
                                        _dev.print(" wrongid: ");
              Since the gateway was not responding correctly to the node broadcasts, I solved the serial communication problem between node and gateway by defining a fixed node Id :
              #define MY_NODE_ID 10
              (ps: the MySensors version used was cloned from git today)
              • antiA
                antiA
                anti
                Replying to myself... Of course the "Controller" MUST be properly connected
                for dynamic nodes IDs to function properly, since it's the controller's job to affect the node ids.
                This explains a part of my original problem.
                • K
                  K
                  kimot
                  I think, that CAN transceiver chip is better then RS485 transceiver chip.
                  Then we dont need direction setting pin and bus state is better determined, becose CAn bus is prepered for bus collisions, RS485 not.
                  I mean only CAN bus transceiver, not CAN controller ! For example MCP2551 or MCP2562.
                  And we can use normal serial library.
                  A L 3 Replies Last reply
                  • K kimot
                    andriej
                    @kimot what would be the CAN topology needed?
                    Does it support star topology? Im looking for a in-home bus over cat5e in walls...
                    Regards
                    K 1 Reply Last reply
                    • K kimot
                      L
                      L
                      LeoDesigner
                      @kimot
                      Just a quick look
                      http://www.aliexpress.com/item/MCP2551-High-Speed-CAN-Communicate-Protocol-Controller-Bus-Interface-Module/32472004400.html?spm=2114.031010208.3.27.bEv7Im&ws_ab_test=searchweb201556_1,searchweb201644_3_79_78_77_82_80_62_81,searchweb201560_1,searchweb1451318400_6148
                      They are five times more expensive.
                      But it might be another option for wired network too.
                      @andrej it is still a line not a star topology.
                      • A
                        andriej
                        Ok so if it's line-wire, then maybe I could wire all cat5e's to one patch-panel, terminate them there and from the patchpanel I could daisy-chain them on one magistral connection and also feed the 12/24V on one pair (i.e. orange/white orange) and data (i.e. blue/white blue).
                        How do you guys think it would work for cables in-home in-wall?
                        I guess the power feed would work ok (even including the voltage drop) but what about the RS485/CAN length?
                        I plan to run cat5 to every switch.
                        Still can't decide if I should connect on-wall switches straight to Arduino (to control relays further) or to use small arduinos inside every wall switch to better control sensors there (temperature on wall) and possibility to program every switch differently. The idea is to get every wire to basement anyway.
                        • A andriej
                          Regards
                          K
                          K
                          kimot
                          @andriej
                          RS485 was not designet for multimaster communication, where 2 devices can communicate on the bus at same time. RS485 bus state at this time is not defined. For example if node on RS485 on one end of bus sends message end perform "control" lisening on bus if recieve the same message( what is with correct circuit of RS485 transsiever immposible ), then this received message can be the same. But if in the same time another node on oposite end of bus sends different message, then node on the middle of bus recieves something random.
                          But CAN bus has allways defined state. It has dominate state and recesive state, so node witch send dominate bit cannot be pushed yb node witch at the same time sends recesive bit. I now, thet this feature we cannot use with normal serial communication, but still we can controll correct sending of datagram by lisening bus by sender. If we recieve the same message what we send, there is 100% shure, that the same message lisens every node on CAN bus. On RS485 this is not garanted. Bus topology is the same end we dont need "dePin". So we can use normal serial library. And CAN transciever is not so expensive as wrote LeoDesigner. Look here:
                          http://www.ebay.com/itm/10PCS-MCP2551-I-SN-IC-TRANSCEIVER-CAN-HI-SPD-8-SOIC-NEW-/171541737564?hash=item27f0af305c:g:nbQAAOSwIBBUZU~k
                          And sorry for my english
                          • K kimot
                            @andriej
                            andriej
                            @kimot Thank you for the information - your english is good enough to understand. :-)
                            I'm just looking for more simple protocol than ethernet to send data from various places - wired.
                            And it seems that, for longer distance and cat5e cable in-wall, ethernet is the only choice :-(
                            • A andriej
                              L
                              L
                              LeoDesigner
                              #49
                              @andriej
                              Just put CAT5e to every place (or even two CAT5e to each TV, room - as I done myself). Later you will decide what kind of signals will travel over CAT5e wire. It can be Ethernet or RS485, CANbus, or something else. Regular twisted pair Ethernet is also has a star topology with central hub/switch. (You may also remember an old Ethernet system with one base cable and terminating resistors on the both ends). For a really long distance - RS485 is the winner anyway - up to 1200m on slow speed.
                              • L LeoDesigner
                                @andriej
                                andriej
                                @LeoDesigner I will put cat5e for 'LAN' purposes to proper socket, but I also want to control my lights not via connecting/disconnecting 230V in-wall, but in central control panel.
                                I was planning to use doorbell push buttons on walls just to give signal to automation and then MCU will set proper relays/dimmers on/off etc.
                                That's why I was thinking about putting cat5e also to on-wall switches, then on 1 pair make the +/-12V signal, another pair for data bus etc. And now I'm looking for most efficient way to connect it everything together.
                                Each room will have temperature sensor for sure (in the switch), some may have dimmers etc. Last idea was to put mini arduinos inside the hole in wall, but I'm afraid of resetting them every once in a while, just because arduino likes to hang itself...
                                • P
                                  P
                                  pjr
                                  @andriej remember to calculate how much current you can take thru cat5e and how much load there can be with one pair.
                                  From wikipedia: "Maximum current per conductor 0.577A". So this would make P=UxI -> 12Vx0.577A=6.92W. There is calculations where one nano can take max 1.4Watts. You could use more wires of the car5e for power or lift voltage upper. 48Vx0.577A=27.70W ;)
                                  • P pjr
                                    andriej
                                    @pjr I'm aware of that :-)
                                    Still struggling with decision either to use the CAT5e just as a loooong cable to (doorbell) switch or use it to PoE small nanos all over the place and run i.e. MQTT on each wall-switch separate.
                                    In second option the RS485 protocol would be the best, because of small form factor (smaller than ethernet port inside switch) and possibility to use MySensors too ;-)
                                    • K kimot
                                      andriej
                                      @kimot what has to be done to prepare MySensors to use CAN?
                                      I'm thinking about ordering some modules for tests. :-)
                                      K 2 Replies Last reply
                                      • T
                                        TimO
                                        Which components do you have in mind? I 'm thinking in that direction too.
                                        • T TimO
                                          andriej
                                          @TimO this small W5100 module: http://www.aliexpress.com/item/TOP-Mini-W5100-LAN-Ethernet-Shield-Network-Module-board-Best/32457200047.html with step-down dc converter. :-)
                                          Cheaper than the PoE standard version.
