  3. Auto Node ID Assignment Question
5 Posts 3 Posters 2.7k Views
  • T
    tcontrada
    If a sensor node is set up to AUTO configure it's Node ID from the Gateway, how can I determine it's Node ID in order to identify it physically?
    My scenario is I have 5 rooms each with a Temperature Sensor Node.. I need to know which node is in which room.
    Tony
    • E
      E
      ericvdb
      Just name your sensor nodes accordingly to the room they're in
      • sundberg84S
        sundberg84S
        If set to AUTO the controller needs to assign the nodeid. Gateway never assigns nodeid.
        When you present a node to the controller you normally se a log or a new device. Name this like "kitchen temp" or something. The nodeID is for MySensors network, the name is in the controller for your own.
        • T
          tcontrada
          In this case I am not using a Controller, just a Gateway for now. It appears the GW is assigning a Node ID.
          • sundberg84S
            sundberg84S
            Hi!
            Nope - the MySensors GW does not assign any ID but if you use a static ID like (3 in this example) that would work.
            gw.begin(NULL,3)
